Soldier Of Fortune 2 foutmelding
Ik heb net soldier of fortune 2 verkregen. :9~ Ik heb de game gewoon geinstalleerd en zo! dat ging allemaal zeer soepeltjes! :)
nu het volgende:
als ik de game wil spelen geeft ie de volgende foutmelding!:
SOF2 0.13 win-x86 Feb 21 2002
Initialising zone memory .....
------- Filesystem Initialization --------
Current search path:
c:/progra~1/soldie~1/base/therest.pk3 (8176 files)
c:/progra~1/soldie~1/base/textures1234.pk3 (10528 files)
c:/progra~1/soldie~1/base/textures0.pk3 (2837 files)
c:/progra~1/soldie~1/base/skins.pk3 (3333 files)
c:/progra~1/soldie~1/base/musicandsound.pk3 (3499 files)
c:/progra~1/soldie~1/base/mp.pk3 (392 files)
c:/progra~1/soldie~1/base/models.pk3 (4096 files)
c:/progra~1/soldie~1/base/maps.pk3 (457 files)
C:PROGRA~1SOLDIE~1/base
33318 files in pk3 files
couldn't exec myconfig.cfg
couldn't exec autoexec.cfg
---------- Getting System Info -----------
OS: Microsoft WinXP (NT)
RDTSC instruction supported
SSE2 enabled processor
Extended name: Intel(R) Pentium(R) 4 CPU 1.60GHz
Pentium IV running at 1582 MHz
255MB physical memory available
couldn't exec scalability/user_Melle.cfg
--------- Client Initialization ----------
Loading renderer.....
--------- Initializing Renderer ----------
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:WINDOWSSystem32opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...shutting down QGL
...unloading OpenGL DLL
Error during initialization SYSTEM ERROR
------------- Input Shutdown -------------
Wat kan ik hieraan doen om dit te verhelpen! Iedereen heeft me al lekker zitten maken met dit spel en nu wil ik het graag spelen ook! 8)7 :'( :'(
HELP ME OUT PLS!
BvD!
Greetz,
Mindcontroller
  • The Will
  • Registratie: Mei 2001
  • Laatst online: 18-10 19:01
Ik mis je systeem specs. Heb je al geprobeerd de nieuwste drivers voor je videokaar te installeren?
There is no magic.
Misschien ligt het aan de ILLEGALE VERSIE die je hebt gedowned?
  • sdomburg
  • Laatst online: 03-09-2024
Download 'm opnieuw of nog beter koop 'm.
  • The Will
Misschien kun je eerst eens nadenken voordat je als een kip zonder kop op de eerste regel afgaat. Er gaat iets fout bij het initialisen van de OpenGL driver, dat heeft NIKS met het feit dat hij illegaal verkregen is te maken.
Zoals je in de SPV FAQ kan lezen, zijn topics over illegale games toegestaan, zolang het probleem niet ligt aan het feit dat het spel illegaal is.
There is no magic.
  • dominic
  • Laatst online: 11-10 17:51
dominic
will code for food
The Will schreef op 05 december 2003 @ 17:08:
Sorry hoor maar als je dit als forumcrew toestaat ben je toch als forum echt fout bezig (=strafbaar).. Om dan ons voor 'kip zonder kop' uit te maken vind ik kortzichtig..
Download my music on SoundCloud
Maar wat kan ik der nu aan doen dan?
Ligt het dan wel aan de videokaart? moet ik nieuwe drivers installeren?
  • The Will
dominic schreef op 05 december 2003 @ 17:11:
Dus puur en alleen omdat iemand zegt dat hij het illegaal heeft zouden wij niet mogen helpen? Als iemand het niet zegt is er niks aan de hand? Beetje krom imho, en daarom hebben we het ook veranderd. Wij leveren gewoon support op games, en fouten die daarbij optreden. Dat ligt echt niet altijd aan het feit dat het spel illegaal is, meestal is het gewoon een driver issue. Niks illegaals aan imho.
Deze discussie kan in LA worden voortgezet als daar behoefte aan is, niet hier.
@ MindController, probeer dat eerst eens, en post even wat voor systeem je hebt.
[ Voor 6% gewijzigd door The Will op 05-12-2003 17:15 ]
There is no magic.
dus ik moet ff nieuwe drivers installeren?? van de videokaart??
edit* ik heb een p4 1600 256mb ram nVidia NV11 64mb video kaart
[ Voor 19% gewijzigd door Verwijderd op 05-12-2003 17:17 ]
  • The Will
Je moet even mijn post lezen, lijkt me een beter idee, en dan vooral dit zinnetje:
Ja, je moet nieuwe drivers installeren.
[ Voor 12% gewijzigd door The Will op 05-12-2003 17:18 ]
There is no magic.
ik zal ze wel ff installeren en laat het wel ff weten of hij het doet!
alvast bedankt (Y)!
greetz
  • sdomburg
En wie zegt dat die slechtgecrackte game de opengl driver verkeerd inlaad? Je moet gewoon eerst uitsluiten dat het aan de rip ligt. Argh sorry, zie ICQ
Om de TS toch op weg te helpen: Heb je via chipset? Zo ja, ff de laatste hyperion drivers installen, zo heb ik problemen met counterstrike in opengl ooit opgelost gekregen :)
[ Voor 15% gewijzigd door sdomburg op 05-12-2003 17:53 ]
The Will got it all right :)!
thnx man! hij draait als een klokje :D
