[update voor gentoo artikel]mail van de debian list
  • Zwerver
Heej Guys,
ik heb van de debian security list DSA 404-1 gekregen en die gaat over de (waarschijnlijk gebruikte) manier waarop de rsync server van gentoo is gehacked:
Debian Security Advisory DSA 404-1 security@debian.org
http://www.debian.org/security/ Martin Schulze
December 4th, 2003 http://www.debian.org/security/faq
Package : rsync
Vulnerability : heap overflow
Problem-Type : remote
Debian-specific: no
CVE ID : CAN-2003-0962
The rsync team has received evidence that a vulnerability in all
versions of rsync prior to 2.5.7, a fast remote file copy program, was
recently used in combination with a Linux kernel vulnerability to
compromise the security of a public rsync server.
While this heap overflow vulnerability could not be used by itself to
obtain root access on an rsync server, it could be used in combination
with the recently announced do_brk() vulnerability in the Linux kernel
to produce a full remote compromise.
Please note that this vulnerability only affects the use of rsync as
an "rsync server". To see if you are running a rsync server you
should use the command "netstat -a -n" to see if you are listening on
TCP port 873. If you are not listening on TCP port 873 then you are
not running an rsync server.
For the stable distribution (woody) this problem has been fixed in
version 2.5.5-0.2.
For the unstable distribution (sid) this problem has been fixed in
version 2.5.6-1.1.
However, since the Debian infrastructure is not yet fully functional
after the recent break-in, packages for the unstable distribution are
not able to enter the archive for a while. Hence they were placed in
my home directory on the security machine:
<http://klecker.debian.org/~joey/rsync/>
We recommend that you upgrade your rsync package immediately if you
are providing remote sync services. If you are running testing and
provide remote sync services please use the packages for woody.
Uit het feit dat rsync lek is en dat er weer gebruik gemaakt is van de do_brk() bug lijkt het me logisch om dit bij het gentoo news te zetten van vanacht?
Woonachtig Down Under. Ik negeer je insults niet, maar tegen de tijd dat ik ze lees zijn ze meestal niet relevant meer
  • Alex
  • Laatst online: 28-02 19:26
(jarig!)
Hmm volgens mij hebben we hier de nieuws submit voor. :)
Deze post is bestemd voor hen die een tegenwoordige tijd kunnen onderscheiden van een toekomstige halfvoorwaardelijke bepaalde subinverte plagiale aanvoegend intentioneel verleden tijd.
- Giphart
  • Harm
Er staat al wat over rsync in de NieuwsQ: klik. Ik heb geen idee of dit over hetzelfde gaat, maar dat moet je zelf maar even zien :).
  • Zwerver
Alex de Groot schreef op 04 december 2003 @ 23:07:
daar kan je alleen een link doorgeven, en toen ik keek was er nog geen webarchive beschikbaar van dit sec item
@harm
het lijkt erop, maar de link naar gentoo is er niet :)
  • Robin
Het staat inmiddels klaar in de Q om verwerkt te worden door een nieuwsposter. Of het daadwerkelijk de frontpage haalt kan ik niet zeggen, maar wel met grote waarschijnlijkheid :).
