• SindaPaus
  • Laatst online: 15-11 11:14
SindaPaus
Cabar di Loca, Puta's!
De Diva GEM GB4000
Afbeeldingslocatie: http://www.daisymm.com/images/divagem/6667_8376.jpg
Linkje
New Diva model coming
Diva Gem, the latest DM digital audio player, will be available in November. It is a compact device combining MP3 player, FM radio and stereo recorder. Up to 256MB built-in memory, SD/MMC card slot and the Li-Ion battery, provide for long time of continuous playback.
Diva Gem GB series can be also used as a Bluetooth hands-free
Chic, miniature, advanced and vociferous: this is the new Diva digital audio player. You can listen to MP3 and AAC music from your internal memory or SD/MMC card, scan radio programs and record with a single button-pressing from the FM tuner or the built-in microphone.
How about a Bluetooth inside?
fanaticAfbeeldingslocatie: http://www.daisymm.com/images/divagem/divagem_fanatic_m.jpgstardustAfbeeldingslocatie: http://www.daisymm.com/images/divagem/divagem_m.jpgglamourAfbeeldingslocatie: http://www.daisymm.com/images/divagem/divagem_glamour_m.jpg
Diva GEM digital audio layer + FM radio + stereo recorder
• The tiniest player with both built-in memory (up to 256MB) and MMC/SD card slot
• Multiformat support: MP3 and AAC
• FM tuner integrated, live capture from the radio function directly in AAC
• Bluetooth Hands-free feature*
• Backlit graphic LCD and easy navigation through menus and playlists
• Multilanguage menu
• Various playback modes
• 4 equalizer presets & one 10-band custom
• Sensitive mic, voice operation recording (VOR), file folder system
• Over 14h continuous play on the Li-Ion battery
• Embedded charger, charges via USB or DC
• USB Removable Drive when connected to PC or Mac
• Driver-free for Windows 2000/Me/XP
_____________________________
*Diva GEM GB4000 models only
  • Listen to your favourite mp3 music and radio stations on the go
  • Record whatever you like from the radio or the environment around you
  • Answer you calls without picking up the mobile or interrupting the music, with the Bluetooth integrated*
  • Navigate through the music and radio stations without drawing the device out of your pocket
  • Use the user-friendly menu in your language to manage your playlists and various player and recorder options
  • Diva Gem is ergonomic: 25 g, lipstick-size, both with built-in memory and SD/MMc slot, durable Li-Ion battery and easy charging
Ook weer een leuk playertje! :9~ Met bluetooth!
Het maakt het er niet makkelijker op in mijn keus voor een bepaalde speler. :|
Weet iemand of ie al te koop is? Ik heb 'm nog nergens kunnen vinden (Maakt het wel weer makkelijker in mijn keus :P)
I don't know, rocket fire at long range - somehow it lacks that personal touch.
Vergis je je niet ? er komen twee versies:
Diva GEM GB dus ZONDER Bluetooth > komt uit in december 2003
Diva GEM GB 4000 MET Bluetooth > komt uit in maart 2004
Diva = made in Bulgarije en erg plastic-achtig er zijn op dit moment mooiere spelers (denk ik).
[ Voor 14% gewijzigd door Verwijderd op 04-12-2003 20:02 ]
  • SindaPaus
SindaPaus
Heb je deze dan ook al bekeken (met z'n plastic-achtigheid)?
Komen er misschien nog meer spelertjes uit met bluetooth?
  • themodfather
  • Laatst online: 25-01 11:38
themodfather
J.C.B.
1. wat is het nut van bluetooth
2. wat gaat die ongeveer kosten
The ModFather
  • SindaPaus
SindaPaus
themodfather schreef op 04 december 2003 @ 16:30:
  1. Zoals ik vertelde in mijn openingspost: "Answer you calls without picking up the mobile or interrupting the music, with the Bluetooth integrated"
    Dus als je geen telefoon hebt met Bluetooth, heb je er (nog) weinig aan. Misschien kun je ook wel met een Bluetooth adapter in je pc, files overbrengen.
  2. Nog geen idee, hij komt deze maand uit. We zullen zien.
  • THUNDER-21
  • Laatst online: 06-03-2025
Hier is hij al te koop maar ik weet niet of het de Bleutooth versie is.
http://www.misterq.nl/Nederlands/misterqwinkel.htm
ee oja iemand enig ervaring met de bestellingen bij deze winkel?
[ Voor 22% gewijzigd door THUNDER-21 op 05-12-2003 02:29 ]
THUNDER-21 schreef op 05 december 2003 @ 02:28:
Is NIET de BLUETOOTH versie ! die komt pas in het tweede kwartaal 2004 (informatie Diva) daarom heb ik de MobiBLU DAH1000 128MB :p gekocht die ziet er (persoonlijk) ook nog wat strakker uit
[ Voor 18% gewijzigd door Verwijderd op 05-12-2003 11:11 ]
[quote]Verwijderd schreef op 05 december 2003 @ 11:08:
Heb je die prijzen trouwens gezien wat belachelijk 32 of 64MB daar koop je een iRiver met 128MB voor.
[ Voor 41% gewijzigd door Verwijderd op 05-12-2003 11:14 ]
  • SindaPaus
SindaPaus
[quote]Verwijderd schreef op 05 december 2003 @ 11:13:
Voordeel is wel dat ze uitbreidbaar zijn.
  • Azrael
  • Laatst online: 10-10 13:58
Tja dat is de MPIO FL100 ook..
Zal dus ff wachten worden tot ze goed leverbaar zijn voordat ze concurrerend worden.
  • themodfather
themodfather
J.C.B.
ik ga hem zeker kopen (als de sint morgenavond niet er al een meebreng)
mooi uiterlijk, fm radio, uitbrijdbaar
dus BOEIEND dat ie wat duurder is
The ModFather
  • mentalmadnizz
  • Laatst online: 19-11 14:38
mentalmadnizz
Deze nick was hip in de 90's.
Ik ga denk ik toch voor de MSI megastick. kan ook veel, en is veel goedkoper. Daty ie wat mooier uitziet boeit mij niet. hij zit toch in mijn broekzak. De MSI heeft 128mb, is niet uitbreidbaar, maar dast maakt toch niet uit. 128mb is ruim voldoende voor mijn gebruik.
Turbo Turbo!! | www.analogaudio.nl
  • themodfather
themodfather
J.C.B.
weet iemand trouwens wanneer de 256mb versie zonder bluetooth uitkomt
op die site staan alleen maar de 32mb versie en de 64mb versie
The ModFather
  • SindaPaus
SindaPaus
* SindaPaus durft niet met zekerheid te zeggen: Ik denk deze maand.
damn zeg, zit ik al tijden te wachten op de opvolger van de diva, slikt deze geen compact flash.
dat vind ik nogal een misser eerlijk gezegd
(of zit ik er nu helemaal naast en hebben beide diva's niets met elkaar te maken?)
  • Azrael
CF is gewoon te groot voor dit soort spelertjes..
  • SEFje
  • Laatst online: 09-03 11:51
Ook jammer dat-ie geen support heeft voor wat meer codec's, bij spelers met een dergelijke hoeveelheid geheugen is WMA toch best wel belangrijk IMHO. Komt nog eens bij dat je volgens mij van bedrijven zoals Diva geen super firmware upgrades hoeft te verwachten (een beetje een generalisering; ik heb geen Diva producten, maar toch...)
Op het eerste gezicht lijkt het een super speler, maar na even nadenken vraag ik me af: Is de accu te verwisselen (die is namelijk na 2 maanden intensief gebruik helemaal gaar).
Heeft iemand m al, ik ben wel geintresseerd maarja er zijn ook nog andere spelers natuurlijk.
ik neem aan van wel, anders koopt niemand hem toch?
de voorganger deed het trouwens gewoon met een penlight.
  • SindaPaus
SindaPaus
Verwijderd schreef op 09 december 2003 @ 09:44:
Zo te horen heb jij 'm al geprobeerd, aangezien jij weet te vertellen dat de accu na 2 maanden gaar is. Vertel er eens wat meer over. :)
  • BadVibes
  • Laatst online: 06-02-2016
Correctie:
Diva GEM G4000 serie = ZONDER Bluetooth
Diva GEM GB4000 serie = MET Bluetooth
  • Luxx
  • Laatst online: 03-10 21:38
Luxx
Hijs nu het zeil gezwind...
Ik weet niet, ik vind hem er wel oke uit zien. Door dat ruwe plastic lijkt ie een beetje robuust. Ik heb nu de oude diva, mocht die het ooit begeven zal ik deze ook eens goed bekijken. MAar ja, zolang deze het nog doet....
offtopic: iemand een batterijklepje voor de oude diva in de aanbieding
HYEHEHEHEEHHEEHee, hier had iets zinnigs kunnen staan, maar dat is niet.
  • Shyne
  • Laatst online: 20-11 11:52
Luxx schreef op 10 december 2003 @ 20:53:
Jij ook al :X
Tja wat kan je der over zeggen
De oude modellen zijn goedkope duurzame spelertjes die het vrijwel altijd doen :)
Ik heb hem zojuist besteld (de rooie). Voor mij is van belang dat hij zo klein mogelijk is, dat hij uitbreidbaar is (SD geheugen net als mijn cam, daar heb ik al kaartjes voor liggen) en dat er een accu in zit. Die normale batterijtjes zijn niks voor mij omdat ik veel te lui ben die dingen op te laden. Als ik hem alleen ff aan de stekker hoef te hangen dan is hij zo overnacht op te laden samen met m'n mobiel. Lekker makkelijk.
  • SindaPaus
SindaPaus
Heb je eentje met Bleutooth? Waarvandaan? Voor welke prijs? :)
Nee, gewoon de normale zonder bluetooth.
Okay, ik heb hem. Geluid is goed, bouwkwaliteit ook. Wat mij tegenvalt is dat joystickje, dat werkt echt niet zo fijn. Gewoon knopjes zouden handiger zijn geweest. Gelukkig hoef je hem alleen te gebruiken bij het switchen van nummers en settings. Die settings verander ik toch nooit als ik ze eenmaal heb ingesteld en met welk liedje hij begint maakt mij niks uit. Letters met backlight aan zijn niet zo donker als je zou denken na het zien van de plaatjes.
De bijgeleverde headset is geintegreerd met een of ander keycord. Pokkeding dus, die kan je wel meteen vervangen.
Al met al een fijne mp3 speler.
  • Shiver23
Shiver23
Wat sta je nou te kijken!
Weet iemand of de Bluetooth versie inmiddels als ergens leverbaar is?
PSN: Shiver23
  • ArmEagle
  • Laatst online: 06-11 14:08
ArmEagle
Duzz.
Cees Zevenbergen van MisterQ zegt dat hij binnen 2 weken een aantal Diva GB40128 verwacht. Oftwel de Diva GEM 128MB met bluetooth.
Alleen zoek ik een 256 MB variant en weet ik nog net zeker OF ik wel BT wil.
Ik vraag me alleen nog wel af of de mensen die hem nu thusi hebben bij MisterQ hebben besteld of niet.
Ik kon MisterQ niet aan de pricewatch toevoegen, omdat de moderators er niet van overtuigd waren of dit wel een betrouwbare webwinkel is. (Geen adres/telefoongegevens of KVK nummer. Tel.nummer vonden ze geen goed idee (?!?) maar ik heb in een mailtje wel een gekregen..).
De website (en Cees) zegt dat MisterQ een initiatief is van 2 andere bedrijven en die hebben (zegt Cees) wel een KvK nummer. En hij zegt dat zonderKvK nummer je minder last hebt van allerlei regeltjs.
Maar goed.. wat ik graag wil weten is of mensen ooit al iets bij MisterQ hebben besteld en idd ook hebben ontvangen. Of anders waar de mensen (die hierboven gepost hebben) hun Diva GEM speler hebben gekocht.
Want volgens mij is MisterQ op dit moment de enige die Diva GEM spelers verkoopt.
[ Voor 6% gewijzigd door ArmEagle op 26-05-2004 17:58 ]
  • willem7q
Nu nog USB 2.0, en ik koop er een :-)
Ik ben nog altijd op zoek naar de combinatie:
-uitbreidbaar geheugen (liefst CF)
-USB 2.0
-schermpje met ID3
-plug&play
Dit en de Nex Kube komen nog het meest in de buurt. Maar de Diva heeft geen USB 2.0, en de Nex Kube heeft geen schermpje.
  • ArmEagle
ArmEagle
Duzz.
USB 2.0 zou misschien leuk zijn, maar met 1.0 duurt het ongeveer 5 minuten dat 256MB gevuld is. Dat vind ik geen probleem. Bovendien heeft mn moederbord toch geen USB 2.0 ;)
  • willem7q
Kent iemand de theoretische maximumcapaciteit van SD-kaartjes? (ik kan het niet vinden op http://www.sdcard.org/).
Bij CF is dat 137GB. (http://www.compactflash.org/).
  • ArmEagle
ArmEagle
Duzz.
geen idee, i heb het idee iets van 512MB / 1GB
Maar ik las ergens dat een mp3speler zelf een max had wat vooropslag capaciteit hij kon gebruiken.
Wat niet betekend dat alle mp3spelers een max hebben.
MAar goed, niemand ooit wat bij MisterQ besteld en gekregen?
  • willem7q
ArmEagle schreef op 28 mei 2004 @ 11:49:
Bij SD-kaartjes zitten ze in de praktijk al aan 1GB, bij CF al aan 4 of 6GB. Bij CF kan ik mij voorstellen dat de capaciteiten nog wel een tijdje zullen blijven stijgen (tot maximum 137GB dus). Maar geldt dat voor SD ook? Kunnen we in de toekomst kaartjes van zeg maar 10GB en meer verwachten? Of zit er een limiet op? (kwestie van een beetje future-proof te zijn als ik iets koop ;)).
ArmEagle schreef op 28 mei 2004 @ 11:49:Maar ik las ergens dat een mp3speler zelf een max had wat vooropslag capaciteit hij kon gebruiken.
Weet iemand daar meer over? Ik denk dat ik over CF gelezen heb dat er een soort processor ingebouwd is in de kaartjes zelf, waardoor de maximale capaciteit niet (?) afhankelijk is van de mp3-speler. Geldt zoiets ook voor SD?
Soms zie je bij specificaties inderdaad staan: "geheugen uitbreidbaar dmv SD met een maximum van 512Mb". Maar is dat dan omdat er op dat moment geen grotere kaartjes bestaan dan 512Mb, of is het echt omdat die speler geen grotere kaartjes ondersteunt?
  • willem7q
SD is second only to CF in capacity, with projections of 16GB by the end of 2005
bron: http://www.pcmag.com/article2/0,1759,1213532,00.asp
Niet slecht...
  • willem7q
De accu is te wisselen (bron: http://www.daisymm.com/do...h%20sw.4.16%20hw.2.10.pdf)
  • ArmEagle
ArmEagle
Duzz.
rest alleen nog het wachten op meer verkoopadressen in benelux/duitsland.
[ Voor 9% gewijzigd door ArmEagle op 03-06-2004 15:01 ]
