• Klaus_1250
  • Laatst online: 04-08 11:42
Zojuist viel de internetverbinding weg, wat niet ongewoon is bij @home. Wat wel ongewoon was wat ik vervolgens in het log van de Surfboard modem aantrof:
(je moet van onderen naar boven lezen)
031202032857 8-Debug M579.3 CM Cert Upgrade Disabled. Motorola CM certificate present
031202032857 8-Debug X501.4 Provisioned Unit Update skipped. Image is current.
031202032857 8-Debug I503.0 Cable Modem is OPERATIONAL
031202032856 8-Debug F502.1 Bridge Forwarding Enabled.
031202032856 8-Debug F502.3 Bridge Learning Enabled.
031202032856 8-Debug B918.0 Baseline Privacy is skipped
031202032854 6-Notice X518.7 Configuration - MMFMME - Update Disabled - No valid CVC
031202032854 8-Debug I500.1 DOCSIS 1.0 Registration Completed
031202032854 7-Information I500.4 Attempting DOCSIS 1.0 Registration
031202032854 7-Information D509.0 Retrieved TFTP Config File SUCCESS
031202032822 7-Information D507.0 Retrieved Time....... SUCCESS
************ 7-Information D511.0 Retrieved DHCP .......... SUCCESS
************ 5-Warning D3.0 DHCP WARNING - Non-critical field invalid in response
************ 4-Error D530.8 DHCP - Invalid Log Server IP Address.
************ 5-Warning D520.2 DHCP Attempt# 2 BkOff: 5s Tot DSC:2 OFF:1 REQ:1 ACK:1
************ 3-Critical D1.0 DHCP FAILED - Discover sent, no offer received
************ 7-Information D0.0 DHCP CM Net Configuration download and Time of Day
************ 7-Information T500.0 Acquired Upstream .......... SUCCESS
************ 8-Debug T503.1 Acquire US with status OK, powerLevel 49, tempSid 328
************ 8-Debug T505.0 Acquired Upstream with status OK
************ 3-Critical R2.0 No Ranging Response received - T3 timeout
************ 7-Information T501.0 Acquired Downstream (140000000 Hz)........ SUCCESS
************ 8-Debug T509.0 Acquired DS with status OK, DS Freq 140000000, US Id 1
************ 7-Information I510.0 *** BOOTING *** SB4200E-1.4.8.17-SCM01-NOSH
************ 8-Debug M575.3 Embedded DOCSIS Root Key installed
************ 7-Information M567.0 Log cleared because it contained entries in an old format
Is @home aan het overschakelen op DOCSIS? Snelheden op Speedtest waren waren iets trager als normaal, maar de afgelopen maanden is het sowieso bij mij alleen maar langzamer gegaan...
  • Canard
  • Laatst online: 16-08 18:54
Onderstaand de log van mijn Motorola
031201234904 8-Debug M579.3 CM Cert Upgrade Disabled. Motorola CM certificate present
031201234904 8-Debug X501.4 Provisioned Unit Update skipped. Image is current.
031201234904 8-Debug I503.0 Cable Modem is OPERATIONAL
031201234904 8-Debug F502.1 Bridge Forwarding Enabled.
031201234904 8-Debug F502.3 Bridge Learning Enabled.
031201234904 8-Debug B918.0 Baseline Privacy is skipped
031201234903 6-Notice X518.7 Configuration - MMEMME - Update Disabled - No valid CVC
031201234903 8-Debug I500.1 DOCSIS 1.0 Registration Completed
031201234903 7-Information I500.4 Attempting DOCSIS 1.0 Registration
031201234903 7-Information D509.0 Retrieved TFTP Config File SUCCESS
031201234903 7-Information D507.0 Retrieved Time....... SUCCESS
************ 5-Warning D520.2 DHCP Attempt# 1 BkOff: 5s Tot DSC:1 OFF:1 REQ:1 ACK:1
************ 8-Debug T503.1 Acquire US with status OK, powerLevel 46, tempSid 2656
************ 7-Information T501.0 Acquired Downstream (132000000 Hz)........ SUCCESS
************ 8-Debug T509.0 Acquired DS with status OK, DS Freq 132000000, US Id 3
Om de log naar boven te halen ga je naar http://192.168.100.1 --> tabblad Logs
[ Voor 3% gewijzigd door Canard op 02-12-2003 13:34 ]
  • Brickman
  • Laatst online: 09-08 06:27
Regio: Venlo
SB4200E
Dit is mijn log:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
031125094606 5-Warning D521.0 DHCP Lease Renewal Failure.
031121214601 5-Warning D521.0 DHCP Lease Renewal Failure.
031116151413 7-Information M552.0 Unit Update - No need to update. Image is current.
031116151413 7-Information F502.1 Bridge Forwarding Enabled.
031116151413 7-Information F502.3 Bridge Learning Enabled.
031116151413 7-Information B518.0 Baseline Privacy is skipped
031116151412 7-Information I500.0 Registration Completed
031116151412 7-Information I0.0 REG-RSP Registration Response
031116151412 7-Information I0.0 REG-REQ Registration Request
031116151412 7-Information D509.0 Retrieved TFTP Config File SUCCESS
031116151412 7-Information D507.0 Retrieved Time....... SUCCESS
************ 8-Debug T503.1 Acquire US with status OK, powerLevel 50, tempSid 5272
************ 8-Debug T509.0 Acquired DS with status OK, DS Freq 140000000, US Id 3
************ 7-Information I510.0 *** BOOTING *** SB4200E-0.4.4.2-SCM01-NOSH
031116151322 7-Information H501.1 HFC: Shutting Upstream Down
031116151322 2-Alert T507.0 Received Async Error Range Failed
031116151322 3-Critical H501.8 HFC: T4 Timer Expired
031116151256 7-Information H501.6 HFC: TRC SYNC Recovery OK
031116151255 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031116151255 7-Information H501.12 HFC: FEC LOCK recovery OK
031113041551 7-Information H501.6 HFC: TRC SYNC Recovery OK
031113041550 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031113041550 7-Information H501.12 HFC: FEC LOCK recovery OK
031113020619 7-Information H501.6 HFC: TRC SYNC Recovery OK
031113020618 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031113020618 7-Information H501.12 HFC: FEC LOCK recovery OK
031113020618 7-Information H501.6 HFC: TRC SYNC Recovery OK
031113020617 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031113020617 7-Information H501.12 HFC: FEC LOCK recovery OK
031113020617 7-Information H501.6 HFC: TRC SYNC Recovery OK
031113020616 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031113020616 7-Information H501.12 HFC: FEC LOCK recovery OK
031113020616 7-Information H501.6 HFC: TRC SYNC Recovery OK
031113020615 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031113020615 7-Information H501.12 HFC: FEC LOCK recovery OK
031113020615 7-Information H501.6 HFC: TRC SYNC Recovery OK
031113020613 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031113020613 7-Information H501.12 HFC: FEC LOCK recovery OK
031113020613 7-Information H501.15 HFC:FEC LOCK recovery OK
031113003338 7-Information H501.6 HFC: TRC SYNC Recovery OK
031113003336 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031113003336 7-Information H501.12 HFC: FEC LOCK recovery OK
031113003336 7-Information H501.6 HFC: TRC SYNC Recovery OK
031113003335 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031113003335 7-Information H501.12 HFC: FEC LOCK recovery OK
031113000646 7-Information H501.6 HFC: TRC SYNC Recovery OK
031113000644 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031113000644 7-Information H501.12 HFC: FEC LOCK recovery OK
031109235121 7-Information H501.6 HFC: TRC SYNC Recovery OK
031109235120 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031109235120 7-Information H501.12 HFC: FEC LOCK recovery OK
031107205403 7-Information M552.0 Unit Update - No need to update. Image is current.
031107205403 7-Information F502.1 Bridge Forwarding Enabled.
031107205403 7-Information F502.3 Bridge Learning Enabled.
031107205403 7-Information B518.0 Baseline Privacy is skipped
031107205402 7-Information I500.0 Registration Completed
031107205402 7-Information I0.0 REG-RSP Registration Response
031107205402 7-Information I0.0 REG-REQ Registration Request
031107205402 7-Information D509.0 Retrieved TFTP Config File SUCCESS
031107205402 7-Information D507.0 Retrieved Time....... SUCCESS
************ 8-Debug T503.1 Acquire US with status OK, powerLevel 49, tempSid 3231
031107205340 1-Emergency D522.0 DHCP Lease Expired.
031107003550 5-Warning D521.0 DHCP Lease Renewal Failure.
031107003545 5-Warning D521.0 DHCP Lease Renewal Failure.
031107003540 5-Warning D521.0 DHCP Lease Renewal Failure.
031107003535 5-Warning D523.0 DHCP Rebinding Timer Event.
031106013254 7-Information H501.6 HFC: TRC SYNC Recovery OK
031106013253 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031106013253 7-Information H501.12 HFC: FEC LOCK recovery OK
031106013253 7-Information H501.6 HFC: TRC SYNC Recovery OK
031106013252 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031106013252 7-Information H501.12 HFC: FEC LOCK recovery OK
031106013252 7-Information H501.6 HFC: TRC SYNC Recovery OK
031106013251 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031106013251 7-Information H501.12 HFC: FEC LOCK recovery OK
031106013251 7-Information H501.6 HFC: TRC SYNC Recovery OK
031106013250 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031106013250 7-Information H501.12 HFC: FEC LOCK recovery OK
031106013250 7-Information H501.6 HFC: TRC SYNC Recovery OK
031106013249 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031106013249 7-Information H501.12 HFC: FEC LOCK recovery OK
031106013249 7-Information H501.6 HFC: TRC SYNC Recovery OK
031106013248 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031106013248 7-Information H501.12 HFC: FEC LOCK recovery OK
031106013248 7-Information H501.6 HFC: TRC SYNC Recovery OK
031106013247 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031106013247 7-Information H501.12 HFC: FEC LOCK recovery OK
031106013247 7-Information H501.6 HFC: TRC SYNC Recovery OK
031106013246 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031106013246 7-Information H501.12 HFC: FEC LOCK recovery OK
031106013246 7-Information H501.6 HFC: TRC SYNC Recovery OK
031106013245 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031106013245 7-Information H501.12 HFC: FEC LOCK recovery OK
031106013245 7-Information H501.6 HFC: TRC SYNC Recovery OK
031106013243 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031106013243 7-Information H501.12 HFC: FEC LOCK recovery OK
031106013243 7-Information H501.6 HFC: TRC SYNC Recovery OK
031106013242 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031106013242 7-Information H501.12 HFC: FEC LOCK recovery OK
031106013242 7-Information H501.6 HFC: TRC SYNC Recovery OK
031106013241 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031106013241 7-Information H501.12 HFC: FEC LOCK recovery OK
031106013241 7-Information H501.6 HFC: TRC SYNC Recovery OK
031106013239 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031106013239 7-Information H501.12 HFC: FEC LOCK recovery OK
031106013239 7-Information H501.15 HFC:FEC LOCK recovery OK
031104114135 5-Warning D521.0 DHCP Lease Renewal Failure.
031104114130 5-Warning D521.0 DHCP Lease Renewal Failure.
031104114125 5-Warning D521.0 DHCP Lease Renewal Failure.
031101022902 7-Information M552.0 Unit Update - No need to update. Image is current.
031101022902 7-Information F502.1 Bridge Forwarding Enabled.
031101022902 7-Information F502.3 Bridge Learning Enabled.
031101022902 7-Information B518.0 Baseline Privacy is skipped
031101022901 7-Information I500.0 Registration Completed
031101022901 7-Information I0.0 REG-RSP Registration Response
031101022901 7-Information I0.0 REG-REQ Registration Request
031101022901 7-Information D509.0 Retrieved TFTP Config File SUCCESS
031101022901 7-Information D507.0 Retrieved Time....... SUCCESS
031101022833 7-Information H501.1 HFC: Shutting Upstream Down
031101022833 2-Alert T507.0 Received Async Error Range Failed
031101022833 3-Critical H501.8 HFC: T4 Timer Expired
031031205345 5-Warning D521.0 DHCP Lease Renewal Failure.
031028085340 5-Warning D521.0 DHCP Lease Renewal Failure.
031024205335 5-Warning D521.0 DHCP Lease Renewal Failure.
031021085330 5-Warning D521.0 DHCP Lease Renewal Failure.
031017205325 5-Warning D521.0 DHCP Lease Renewal Failure.
031008094751 7-Information M552.0 Unit Update - No need to update. Image is current.
031008094750 7-Information F502.1 Bridge Forwarding Enabled.
031008094750 7-Information F502.3 Bridge Learning Enabled.
031008094750 7-Information B518.0 Baseline Privacy is skipped
031008094749 7-Information I500.0 Registration Completed
031008094749 7-Information I0.0 REG-RSP Registration Response
031008094749 7-Information I0.0 REG-REQ Registration Request
031008094749 7-Information D509.0 Retrieved TFTP Config File SUCCESS
031008094749 7-Information D507.0 Retrieved Time....... SUCCESS
031007055741 7-Information F502.1 Bridge Forwarding Enabled.
031007055741 7-Information F502.3 Bridge Learning Enabled.
031007055741 7-Information B518.0 Baseline Privacy is skipped
031007055740 7-Information I500.0 Registration Completed
031007055740 7-Information I0.0 REG-RSP Registration Response
031007055740 7-Information I0.0 REG-REQ Registration Request
Dit staat er bij mij bij help boven aan:
Software Version: SB4200E-0.4.4.2-SCM01-NOSH
Hardware Version: 3
MIB Version: II
GUI Version: 1.0
VxWorks Version: 5.3
This page provides an overview of the Configuration Manager, and brief troubleshooting information.
[ Voor 4% gewijzigd door Brickman op 02-12-2003 16:14 ]
Thinkpad T500 | Synology HowTo's (CouchPotato, Sickbeard, Periscope, Headphones)
  • FlashBang
  • Laatst online: 11:36
FlashBang
Hoi.
Ziet er ook niet goed uit:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
031128070049 7-Information H501.6 HFC: TRC SYNC Recovery OK
031128070048 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031128070048 7-Information H501.12 HFC: FEC LOCK recovery OK
031128065953 7-Information H501.6 HFC: TRC SYNC Recovery OK
031128065951 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031128065951 7-Information H501.12 HFC: FEC LOCK recovery OK
031126193717 7-Information M552.0 Unit Update - No need to update. Image is current.
031126193717 7-Information F502.1 Bridge Forwarding Enabled.
031126193717 7-Information F502.3 Bridge Learning Enabled.
031126193717 7-Information B518.0 Baseline Privacy is skipped
031126193716 7-Information I500.0 Registration Completed
031126193716 7-Information I0.0 REG-RSP Registration Response
031126193716 7-Information I0.0 REG-REQ Registration Request
031126193716 7-Information D509.0 Retrieved TFTP Config File SUCCESS
031126193716 7-Information D507.0 Retrieved Time....... SUCCESS
************ 8-Debug T503.1 Acquire US with status OK, powerLevel 49, tempSid 822
************ 7-Information T501.0 Acquired Downstream (506000000 Hz)........ SUCCESS
************ 8-Debug T509.0 Acquired DS with status OK, DS Freq 506000000, US Id 3
031126193532 7-Information H501.1 HFC: Shutting Upstream Down
031126193532 2-Alert T507.0 Received Async Error Range Failed
031125020519 7-Information H501.6 HFC: TRC SYNC Recovery OK
031125020517 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031125020517 7-Information H501.12 HFC: FEC LOCK recovery OK
031125020419 7-Information H501.6 HFC: TRC SYNC Recovery OK
031125020418 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031125020418 7-Information H501.12 HFC: FEC LOCK recovery OK
031125014545 7-Information H501.6 HFC: TRC SYNC Recovery OK
031125014544 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031125014544 7-Information H501.12 HFC: FEC LOCK recovery OK
031125014500 7-Information H501.6 HFC: TRC SYNC Recovery OK
031125014459 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031125014459 7-Information H501.12 HFC: FEC LOCK recovery OK
031115215526 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115215524 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115215524 7-Information H501.12 HFC: FEC LOCK recovery OK
031115215433 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115215431 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115215431 7-Information H501.12 HFC: FEC LOCK recovery OK
031115123507 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115123505 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115123505 7-Information H501.12 HFC: FEC LOCK recovery OK
031115114445 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115114443 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115114443 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112733 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112732 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112732 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112635 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112634 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112634 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112634 7-Information H501.15 HFC:FEC LOCK recovery OK
031115112632 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112632 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112522 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112520 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112520 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112510 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112508 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112508 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112448 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112447 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112447 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112447 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112446 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112446 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112446 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112445 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112445 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112445 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112444 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112444 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112444 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112443 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112443 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112443 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112442 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112442 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112442 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112441 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112441 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112441 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112440 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112440 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112440 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112439 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112439 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112439 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112438 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112438 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112438 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112437 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112437 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112437 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112436 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112436 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112436 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112435 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112435 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112435 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112434 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112434 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112434 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112433 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112433 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112433 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112432 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112432 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112432 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112431 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112431 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112431 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112430 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112430 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112430 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112429 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112429 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112429 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112428 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112428 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112428 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112427 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112427 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112427 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112426 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112426 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112426 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112425 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112425 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112425 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112424 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112424 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112424 7-Information H501.15 HFC:FEC LOCK recovery OK
031115112323 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112322 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112322 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112148 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112147 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112147 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112147 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112146 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112146 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112146 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112145 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112145 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112145 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112144 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112144 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112144 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112143 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112143 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112143 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112142 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112142 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112142 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112141 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112141 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112141 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112140 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112140 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112140 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112139 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112139 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112139 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112138 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
031115112138 7-Information H501.12 HFC: FEC LOCK recovery OK
031115112138 7-Information H501.6 HFC: TRC SYNC Recovery OK
031115112137 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
Dit staat er bij mij bij help:
Hardware Version: 3
MIB Version: II
GUI Version: 1.0
  • Klaus_1250
Brickman schreef op 02 december 2003 @ 13:42:
Deze software had ik dus tot vanmiddag ook, maar is nu dus geupdate. Wat me opvalt is trouwens dat deze nieuwe versie BEDUIDEND langzamer is. In plaats van dat hij met een hoge snelheid iets begint te downloaden totdat de CAP erin springt, begint ie nu juist langzaam en kruipt langzaam omhoog tot ca. 350 kB/s...
  • Canard
Klaus_1250 schreef op 02 december 2003 @ 13:48:
Ik zal het vandaag of morgen bij mij eens testen...
bij mij zit er nog steeds een cap van 320 op dus wees blij dat je nog 350 haalt.
  • IceStorm
  • Laatst online: 19-08 20:35
IceStorm
This place is GoT-like!!!
Zie bij mij niet echt wat vreemds (als in, het meeste heb ik wel eens vaker gezien bij mijn weten). Laatste zijn allemaal DHCP lease renewal failures :).
  • Maestro.mosjuh
SB4200E-0.4.4.2 is de laatste bij mij bekende juiste firmware, ik had tot 5 minuten geleden nog niet van v1.4.8.17 gehoord.
diegene met de nieuwe versie; hebben jullie gisteren of vandaag de stroom even van de modem afgehaald oid?
wat bedoel je hiermee?
misschien handig als iedereen ook meer info post (welk gebied woon je; en welk type motorola: 4200 of 5100)
[ Voor 16% gewijzigd door Maestro.mosjuh op 02-12-2003 16:12 ]
At the beginning there was nothing. So God said 'apt-get install light'.
  • Klaus_1250
Maestro.mosjuh schreef op 02 december 2003 @ 16:11:
Ik ook niet, vandaar dat ik dit hier post
Gebeurde automatisch, dus ik heb de stroom er niet af gehaald. Was gewoon aan het internetten toen de verbinding voor een paar minuten wegviel.
In de log-output staan dingen als:
Deze heb ik nog niet eerder gezien volgens mij, vandaar dat ik me afvraag of @home op een nieuw systeem/standaard aan het overschakelen is...
Roosendaal, type staat in de log-output (Motorola SB4200E).
  • Klaus_1250
IceStorm schreef op 02 december 2003 @ 14:33:
DHCP server is echt brak (evenals de mail- en news-server en de service van @sloom). Altijd als mijn verbinding eruit ligt, komt het omdat ik geen DHCP-lease kan krijgen :(
  • Maestro.mosjuh
de motorola's zijn ('gewoon') van het type docsys (altijd al geweest)
dus @home schakelt daar niet 'opeens' op over.
  • Klaus_1250
Verwijderd schreef op 02 december 2003 @ 14:28:
Ik wil gewoon weer de (download)snelheid die ik had! Meer betalen en steeds minder krijgen, dat kan toch niet? Waarom word de consument altijd de dupe van dit soort mismanagement en is er niemand die is een keer ingrijpt...
  • Klaus_1250
Maestro.mosjuh schreef op 02 december 2003 @ 16:24:
Ze ondersteunen de standaard, dat weet ik, maar dan hoeven ze er toch niet per sé gebruik van te maken? Maar het kan inderdaad zijn dat ze altijd van DOCSIS 1.0 gebruik hebben gemaakt, maar dat dat gewoon nooit in de logs zo naar voren kwam...
  • MrEdge_
  • Laatst online: 17-11-2023
Klaus_1250 schreef op 02 december 2003 @ 16:26:
Tja, volgens de website van @home haal je meer dan ze beloven, dus daar kun je niet over klagen. Verder is het topic nummertje zoveel over de te lage snelheid bij @home.
  • Shiver23
Shiver23
Wat sta je nou te kijken!
Meer dat ze inderdaad nu beloven.
De snelheid van ADSL gaat steeds verder omhoog en de snelheid van @Home gaat steeds verder naar beneden.
Zo hou je geen klant meer over natuurlijk.
PSN: Shiver23
  • MrEdge_
Shiver23 schreef op 02 december 2003 @ 16:38:
Daar zit natuurlijk wel een kern van waarheid in, maar op dit moment is alleen de uploadsnelheid en verbinding iets om moeilijk over te doen. Iets waar veel mensen niet veel van merken. Maar dat ze steeds minder voordelen te bieden hebben t.o.v. adsl providers, dat mag duidelijk zijn.
  • Maestro.mosjuh
MrEdge_ schreef op 02 december 2003 @ 16:33:
volgens mij is dit topic nummer 1 over de firmwareupgrade van de motorola modems op @home
maar het buigt idd nu wel af naar een discussie over de snelheid van @home....
  • Zap
Zap
Weet je zeker dat dit niet ten gevolge van meetonnauwkeurigheden van bijvoorbeeld IE is? Wanneer er weinig data is gedownload (in het begin) kan de gemiddelde snelheid nog niet nauwkeurig berekend worden.. Een cap is een cap lijkt me (en geldt altijd, niet pas na X KB), alleen bij grotere hoeveelheden data komt het effect ervan pas tot uiting :)
Alle @home Motorola modems maken gebruik van de DOCSIS 1.0 standaard, het zijn gewoon DOCSIS modems (dat kan niet ineens na een firmware upgrade veranderen). Dit DOCSIS netwerk draait naast het al oudere COM21-platform, dat logischerwijs alleen met COM21 modems werkt :)
Waarschijnlijk dus idd een nieuwe firmwareversie, maar met welke 'verbeteringen' ?
MrEdge_ schreef op 02 december 2003 @ 16:42:
Daar zit natuurlijk wel een kern van waarheid in, maar op dit moment is alleen de uploadsnelheid en verbinding iets om moeilijk over te doen. Iets waar veel mensen niet veel van merken. (...)
En wat dacht je van de mailserver, newsserver, FTP/webserver en helpdesk? Zijn nou ook niet bepaald betrouwbaar en degelijk te noemen.. ;)
[ Voor 19% gewijzigd door Zap op 02-12-2003 16:59 ]
Ik wil ook ff spamme met mijn log :D
Time Priority Code Message
031130062356 5-Warning D103.0 DHCP RENEW WARNING - Field invalid in response
031130062356 4-Error D530.8 DHCP - Invalid Log Server IP Address.
031128045040 8-Debug M579.3 CM Cert Upgrade Disabled. Motorola CM certificate present
031128045040 8-Debug X501.4 Provisioned Unit Update skipped. Image is current.
031128045040 8-Debug I503.0 Cable Modem is OPERATIONAL
031128045039 8-Debug F502.1 Bridge Forwarding Enabled.
031128045039 8-Debug F502.3 Bridge Learning Enabled.
031128045039 8-Debug B918.0 Baseline Privacy is skipped
031128045037 6-Notice X518.7 Configuration - MMFMME - Update Disabled - No valid CVC
031128045037 8-Debug I500.1 DOCSIS 1.0 Registration Completed
031128045037 7-Information I500.4 Attempting DOCSIS 1.0 Registration
031128045037 7-Information D509.0 Retrieved TFTP Config File SUCCESS
031128045037 7-Information D507.0 Retrieved Time....... SUCCESS
************ 8-Debug T503.1 Acquire US with status OK, powerLevel 53, tempSid 358
************ 8-Debug T509.0 Acquired DS with status OK, DS Freq 140000000, US Id 5
Software Version: SB4200E-1.4.8.17-SCM01-NOSH
Hardware Version: 3
MIB Version: II
GUI Version: 1.0
Regio Tilburg..
  • Maestro.mosjuh
wat ik raar vind is de grote sprong in de versienummering...
van
0.4.4.2(p dacht ik)
naar
1.4.8.17
  • IceStorm
IceStorm
Zijn die timestamps eigenlijk nog om te rekenen?
(sorry, enigsinds off-topic ;)).
  • Xandrios
  • Laatst online: 17-08 17:33
Jongens, gaan we er geen opsomtopic van maken? Aub alleen je log posten als er ook daadwerkelijk iets bijzonders te zien is :)
  • Nick Name
  • Laatst online: 13:17
Nick Name
SinFest!
IceStorm schreef op 02 december 2003 @ 17:01:
jazeker: 031128045037 is 2003 11 28 04:50:37
[ Voor 184% gewijzigd door Nick Name op 02-12-2003 17:07 ]
http://www.sinfest.net | Q: Does it ever get windy in Australia? I have never seen it rain on TV, so how do the plants grow? (UK) A: We import all plants fully grown and then just sit around watching them die
  • DJ^
DJ^
hmmz
031130062356
30-11-2003 06:23:56
niet zo moeilijk toch.
hmmz
  • IceStorm
IceStorm
Zucht, daar had ik zelf op kunnen komen bij nader inzien |:(
Huh kan je de log van je com21 modem ook bekijken of kan dit alleen voor Motorola modems?
  • Nick Name
Nick Name
SinFest!
kleine wijzigingen, niet meer beschikbaar (via HTML) zijn de volgende data:
Ranging Service ID, Symbol Rate, QAM, NACO (Network Access Control Object), HFC ip (HFC MAC is wel beschikbaar)
Edit: de twee remoteaccess poorten staan nu ook op stealth...
Ik zal morgen eens kijken of SNMP LAN-side nog te bereiken is als het modem geen verbinding met @Home heeft...
daar gaat mijn automatisch Surboard-log/data/status tracker...jammer
[ Voor 43% gewijzigd door Nick Name op 02-12-2003 18:05 ]
  • Maestro.mosjuh
Verwijderd schreef op 02 december 2003 @ 17:13:
een com21 heeft zowiezo geen log; laat staan dat je hem (zelf) kan bekijken...
  • Zap
Zap
Het Com21 modem werkt als een soort transparante bridge, en heeft daarom in tegenstelling tot de Motorola modems geen ingebouwde web- en DCHP-server.. Je kunt dus niet op een soortgelijke manier logs en configuratiegegevens uitlezen.
Ze hebben vaak wel een seriele poort (achter een klepje of afdekplaatje), welke je mbv. een terminal kan aansturen.. Maar echt veel interessants kun je er niet mee volgens mij :)
  • Maestro.mosjuh
Zap schreef op 02 december 2003 @ 17:22:
je zou de fec waarden enzo uit kunnen lezen (kijken of het signaal goed is).
  • Klaaz Vaak
  • Laatst online: 03-01 19:17
Maestro.mosjuh schreef op 02 december 2003 @ 17:38:
Eventueel mac etc aan kunnen passen, dmv console commands
  • Brickman
Daar zit php logica in.
031130062356
Sat Oct 04 19:14:44 2003
Klaaz Vaak schreef op 02 december 2003 @ 17:43:
Ja ik heb zelfs gehoord dat mensen hun download/upload limiet konden veranderen op die manier. Maar hm via de seriele poort is niet leuk, zou ik nog een kabel naar het modem beneden moeten neerleggen, laat maar.. Zo'n log of iets via SNMP was super geweest :)
Motorola modems werken hier in het noorden des lands niet schijnt het (mijn vriendin kreeg er per ongeluk een toegestuurd)
  • DJ^
DJ^
hmmz
Brickman schreef op 02 december 2003 @ 17:51:
Nix php, zie mijn post boven ;)
Waarom denken jullie allemaal zo moeilijk? :)
Verwijderd schreef op 02 december 2003 @ 18:10:
Flauwekul, hier in Delfzijl gebruik ik ook gewoon een motorola modem.
[ Voor 56% gewijzigd door DJ^ op 02-12-2003 19:22 ]
hmmz
  • Nick Name
Nick Name
SinFest!
ff een kleine update (SNMPwalk uitgevoerd):
voorheen kon je als het modem niet op kabelnetwerk was aangesloten poort 23 (telnet), 80 (www), 513 (remote login) en SNMP (161 als ik mij niet vergis) zien en in geval van www en SNMP benaderen. Na de firmware en softwareupgrade van het modem zijn poort 23 en 513 volledig in stealthmode.
Software Version (oud): 0.4.4.2p
Bootrom version (nieuw): SB4200E-0.4.3.4-SCM03-NOSH
Software Revision (nieuw): SB4200E-1.4.8.17-SCM01-NOSH
VxWorks is het OS van de SB4200E
VxWorks (oud): 5.3.1
VxWorks (nieuw): 5.4
sysObjectID is ook aangepast
(ik heb van zowel de oude als de nieuwe situatie een complete SNMP dump, maar het is niet echt zinnig om alle verschillen hier te posten...overigens lijkt een groot deel (label experimental.83.1.....) niet langer beschikbaar te zijn)
[ Voor 6% gewijzigd door Nick Name op 02-12-2003 23:35 ]
  • lordsnow
  • Laatst online: 12:01
lordsnow
I know nothing
DJ^ schreef op 02 december 2003 @ 19:19:
Dat kan wel, maar er zijn wel een aantal plaatsen in Nederland waar geen DOCSIS modems aan te sluiten zijn, en dan moet men een Com21 gebruiken.
  • Nick Name
Nick Name
SinFest!
Maestro.mosjuh schreef op 02 december 2003 @ 16:58:
naar 1.4.8.17
op basis van de gegevens (lees firmware) op http://www.tcniso.net/Nav/Firmware/SB/ zou je wellicht kunnen concluderen dat dit een DOCSIS 1.1 versie zou kunnen zijn (er wordt duidelijk gebroken met de DOCSIS 1.0 en EuroDOCSIS versienummer-opbouw).
Dat in de logfiles uitsluitend DOCSIS 1.0 wordt genoemd sluit die mogelijke conclusie niet uit (eerst krijgen de modems een update krijgen en pas later schakelt de server van @Home zelf over)
Ik heb nog nergens kunnen achterhalen wat de verschillen in de firmware en OS zijn...anyone?
  • Klaus_1250
Nick Name schreef op 04 december 2003 @ 14:39:
Daar zat ik ook aan te denken. In principe moeten eerst alle modems geupdate worden, om het netwerk te kunnen upgraden naar DOCSIS 1.1 Ik ga er vanuit dat deze update onderdeel is om dadelijk een 4 keer hogere upload mogelijk te maken?
  • Brickman
Klaus_1250 schreef op 05 december 2003 @ 12:41:
Ik hoop het.
Ik heb nog steeds de versie van EuroDOCSIS erop zitten. Schiet niet echt op. :?
Afbeeldingslocatie: http://hosting.ambience.nl/brickman/got/motorola_comparison.jpg
[edit]
Op de site van Motorola (Consumer) staat de SURFboard SB4200E. De SB4200E staat alleen op het gedeelte voor 'Broadband Service Providers' maar daar staat weer geen tabel met een vergelijking. :?
[ Voor 25% gewijzigd door Brickman op 05-12-2003 19:32 ]
  • Nick Name
Nick Name
SinFest!
Brickman schreef op 05 december 2003 @ 14:46:
De firmware is zo'n 800KB groot...ik kan mij voorstellen dat @Home niet wil dat iedereen met een Surboard in (bijvoorbeeld) dezelfde week dat bestand van de server haalt. (exclusief overhead heb je het over zo'n 7.6GB per 10.000 gebruikers)
(BTW: in je tabel gaat het over de SB4200...je moet eigenlijk een vergelijking hebben met de SB4200E)
[ Voor 11% gewijzigd door Nick Name op 05-12-2003 20:45 . Reden: heel slordig: er stond kb ipv KB...tisk ;) ]
  • MARTIJN_
  • Laatst online: 11-07 17:05
MARTIJN_
vier keer hoger zit er niet.
het verschil tussen docsis 1.0 en 1.1 is QoS
What are the key differences between DOCSIS 1.0 and 1.1?
To summarize, DOCSIS 1.1 builds upon 1.0, but also includes the following features:
* Quality of Service
* Dynamic Services
* Concatenation
* Fragmentation
* Payload Header Suppression
* IP Multicast
* CM Authentication
* SNMPv3
* View-based access control and management (VACM)
* CM Account Management
* Fault Management
* Secure Software
De docsis standaard 1.0 en 1.1 hebben de bandbreedte.
The DOCSIS Downstream Channel
Property : Description
Modulation : 64 and 256 QAM (ITU Annex B with variable interleaving
Carrier : 50 MHz - 750 MHz
Bandwidth : 6 MHz
Data Rate : 27 or 36 Mbps
Framing : MPEG-2
FEC : Reed Solomon
Encryption : DES
The DOCSIS Upstream Channel (DOCSIS 1.0 & 1.1)
Modulation : QPSK or 16-QAM
Carrier : 5 MHz - 42 MHz
Bandwidth : Variable, 200 KHz. - 3.2 MHz
Data Rate : 320 Kbps - 10 Mbps
FEC : Reed Solomon
Encryption : DES
Alleen als er Docsis 2.0 wordt ingevoerd gaat de snelheid ver omhoog, maar hier zijn nieuwe modem voor nodig.
Docsis 2.0 heeft een upstream van max 30.72 Mbit/s (64QAM in 6.4 MHz)
en een downstream van ook 36 Mbps.
PGEQRZEM
  • Nick Name
Nick Name
SinFest!
MARTIJN_ schreef op 06 december 2003 @ 00:35:
Ik was dit ook al tegengekomen, maar ik had het bewust niet gepost. Ik heb nog geen bevestiging kunnen vinden dat deze firmware inderdaad (euro)DOCSIS1.1 mogelijkmaakt.
Ik heb wel meer indirecte aanwijzingen gevonden:
op enkele sites kwam naar voren dat firmware met soortgelijke versienummering enkele beveiligingsmaatregelen introduceerden die ook in de DOCSIS 1.1 standaard terug te vinden zijn...
Nog even een stukje van CISCO over de verschillen (met name het tweede deel lijkt wel interessant)
quote: CISCO
The major difference between DOCSIS 1.0 and DOCSIS 1.1 is that DOCSIS 1.0 uses Service ID (SID) to identify cable modems and the devices behind them, while DOCSIS 1.1 uses Service Flows. It also has improved MAC framing features and improved provisioning and authorization with advanced BPI+ features.
Service Flows are the fundamental unit in DOCSIS 1.1 for QoS provisioning. DOCSIS 1.1 allows multiple service flows per cable modem. This means that different types of traffic like data, voice, and video can be separately identified on the same cable modem in order to provide specialized QoS treatment as per traffic needs.
BRON
voor de mensen die zich altijd al afvroegen waar dat NOSH voor staat in de firmware naam: NO SHELL...dat integenstelling tot firmware met SHELL aan het einde ;-) De CLI is ook in de NOSH-versie gewoon beschikbaar
[ Voor 3% gewijzigd door Nick Name op 06-12-2003 21:58 ]
  • Klaus_1250
Zijn er eigenlijk al @home abbonees met een Motorola SB5100?
  • Nick Name
Nick Name
SinFest!
Klaus_1250 schreef op 06 december 2003 @ 01:54:
weet ik niet...
wel grappig is dat de SB5100 niet DOCSIS1.0 gecertificeerd is, maar wel voor DOCSIS1.1...(terwijl 1.1 wel downwards compatible is met 1.0) ;)
  • lordsnow
lordsnow
I know nothing
Ja
  • Maestro.mosjuh
Afbeeldingslocatie: http://forum.fok.nl/i/s/yes_new.gif
genoeg mensen hebben al de (zwarte) 5100
  • PolarBear
van
0.4.4.2(p dacht ik)
naar
1.4.8.17
Waar een mens zich druk om kan maken. :O
  • Ascathon
  • Laatst online: 18-08 20:19
Ik heb al sinds september 2003 de SB4200e, en ik heb nog steeds versie 0.4.3.4 (of zoiets).
Weet iemand hoe dat dan kan? Ik heb het basis abo.
En kan misschien iemand uitleggen wat de oorzaak is van het volgende:
050105022410 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
050105022410 7-Information H501.12 HFC: FEC LOCK recovery OK
050105022410 7-Information H501.15 HFC:FEC LOCK recovery OK
050105015537 7-Information H501.6 HFC: TRC SYNC Recovery OK
050105015536 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
050105015536 7-Information H501.12 HFC: FEC LOCK recovery OK
050105015536 7-Information H501.15 HFC:FEC LOCK recovery OK
050105014652 7-Information H501.6 HFC: TRC SYNC Recovery OK
050105014651 3-Critical H501.4 HFC: LOST TRC SYNC- trying to recover
050105014651 7-Information H501.12 HFC: FEC LOCK recovery OK
050105014651 7-Information H501.15 HFC:FEC LOCK recovery OK
(sorry, maar ik weet niet hoe ik zo snel die
[ Voor 80% gewijzigd door Ascathon op 07-01-2005 19:05 ]
