locaal netwerk verbinding valt soms uit
Hey Guys,
Ik zit met het volgende probleem af en toe valt mijn netwerk uit en een paar minuten of na een reboot is hij weer terug. Ik heb de volgende log:
Dec 1 08:38:54 darkstar kernel: eth0: transmit timed out, tx_status 00 status e000.
Dec 1 08:40:54 darkstar kernel: eth1: transmit timed out, tx_status 00 status e000.
Dec 1 09:58:54 darkstar kernel: eth0: transmit timed out, tx_status 00 status e000.
Dec 1 11:12:54 darkstar kernel: eth0: transmit timed out, tx_status 00 status e000.
Dec 1 12:23:54 darkstar kernel: eth0: transmit timed out, tx_status 00 status e000.
Dec 1 14:38:54 darkstar kernel: eth0: transmit timed out, tx_status 00 status e000.
Dec 1 16:26:54 darkstar kernel: eth0: transmit timed out, tx_status 00 status e000.
Dec 1 16:28:11 darkstar sshd[969]: warning: /etc/hosts.allow, line 13: missing ":" separator
Dec 1 16:28:11 darkstar sshd[969]: warning: /etc/hosts.allow, line 14: missing ":" separator
Dec 1 16:28:11 darkstar sshd[969]: warning: /etc/hosts.allow, line 15: missing ":" separator
Dec 1 16:28:11 darkstar sshd[969]: warning: /etc/hosts.allow, line 15: missing newline or line too long
Dec 1 16:42:54 darkstar kernel: eth0: transmit timed out, tx_status 00 status e000.
Dec 1 17:11:54 darkstar kernel: eth0: transmit timed out, tx_status 00 status e000.
Dec 1 17:12:54 darkstar kernel: eth0: transmit timed out, tx_status 00 status e000.
Dec 1 17:44:43 darkstar sshd[2795]: warning: /etc/hosts.allow, line 13: missing ":" separator
Dec 1 17:44:43 darkstar sshd[2795]: warning: /etc/hosts.allow, line 14: missing ":" separator
Dec 1 17:44:43 darkstar sshd[2795]: warning: /etc/hosts.allow, line 15: missing ":" separator
Dec 1 17:44:43 darkstar sshd[2795]: warning: /etc/hosts.allow, line 15: missing newline or line too long
Dec 1 17:44:43 darkstar afpd[144]: warning: /etc/hosts.allow, line 13: missing ":" separator
Dec 1 17:44:43 darkstar afpd[144]: warning: /etc/hosts.allow, line 14: missing ":" separator
Dec 1 17:44:43 darkstar afpd[144]: warning: /etc/hosts.allow, line 15: missing ":" separator
Dec 1 17:44:43 darkstar afpd[144]: warning: /etc/hosts.allow, line 15: missing newline or line too long
Dec 1 17:44:43 darkstar inetd[66]: could not getpeername
Dec 1 17:44:43 darkstar afpd[2797]: dsi_stream_read(-1): Connection reset by peer
Dec 1 17:44:43 darkstar afpd[2797]: dsi_tcp_open: invalid header
Kan iemand mij misschien vertellen wat er precies aan de hand is en of dit op te lossen is?
Ik draai slackware 8.1 met dhcpd versie: isc-dhcpd-V3.0pl2.
En heb verder 2 nics (nieuwe) een 3com 3c905c)
  • Tony Vroon
  • Laatst online: 13-06-2020
Tony Vroon
Werkt nu ergens anders
Deze posting is niet genoeg om je te helpen, m'n kristallen bol is in reparatie, sorry :)
Graag de output van:
uname -a
dmesg -s 65535 | grep noacpi
dmesg -s 65535 | grep usepirqmask
lspci
"Wie is deesen figuur, hier ten topic aangheduidt als 'hij', wiens mededelinghe soo eenen consternatie weet te ontluycken :? " -- dion_b
Okeej hier de output:
root@darkstar:~# uname -a
Linux darkstar 2.4.18 #4 Fri May 31 01:25:31 PDT 2002 i686 unknown
(leverde geen output op)
(ook geen output)
root@darkstar:~# lspci
00:00.0 Host bridge: VIA Technologies, Inc. VT8367 [KT266]
00:01.0 PCI bridge: VIA Technologies, Inc. VT8367 [KT266 AGP]
00:05.0 VGA compatible controller: Alliance Semiconductor Corporation ProVideo 6422 (rev 02)
00:07.0 Ethernet controller: 3Com Corporation 3c905C-TX/TX-M [Tornado] (rev 78)
00:0a.0 Ethernet controller: 3Com Corporation 3c905C-TX/TX-M [Tornado] (rev 78)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8233A ISA Bridge
00:11.1 IDE interface: VIA Technologies, Inc. Bus Master IDE (rev 06)
00:11.2 USB Controller: VIA Technologies, Inc. USB (rev 23)
00:11.3 USB Controller: VIA Technologies, Inc. USB (rev 23)
00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT8233 AC97 Audio Controller (rev 40)
00:11.6 Communication controller: VIA Technologies, Inc. AC97 Modem Controller (rev 78)
wat vreemd is is dat eth1 wel zonder storing werkt (zelfde merk (internet) maar eth0 niet:
[ Voor 14% gewijzigd door Verwijderd op 01-12-2003 18:12 ]
  • ge-flopt
Heb je ook naar etc/hosts.allow gekeken en dan met name naar regel 13,14 en 15? Daar klopt ook iets niet.
Yep hier nog even de dump:
(volges mij is de error een bug in the source code van de 3com driver....
# hosts.allow This file describes the names of the hosts which are
# allowed to use the local INET services, as decided by
# the '/usr/sbin/tcpd' server.
# Version: @(#)/etc/hosts.allow 1.00 05/28/93
# Author: Fred N. van Kempen, <waltje@uwalt.nl.mugnet.org
# End of hosts.allow.
proftpd
192.168.0.98
192.168.0
*.thuis.nl
keb hem ff opgeschoont wat er stond was nie tmeer nodig en klopte niet keb nu alleen nog mijn domein erin:
*.thuis.nl
[ Voor 38% gewijzigd door Verwijderd op 01-12-2003 18:27 ]
  • Zwerver
tja het lijkt op of een brakke kabel, of een brakke netwerkkaart(driver) switch de kabels van eth0 en 1 eens?
Woonachtig Down Under. Ik negeer je insults niet, maar tegen de tijd dat ik ze lees zijn ze meestal niet relevant meer
look at me dmesg:
Flags: bus-master 1 full 1 dirty 89092 current 89102 restart_tx 0.
Transmit list 0fae49b0 vs. cfae4a40, packet ID 00.
0: @cfae4a00 length 800005ea status 90010000
1: @cfae4a10 length 800005ea status 90010004
2: @cfae4a20 length 800005ea status 90010008
3: @cfae4a30 length 800005ea status 9001000c
4: @cfae4a40 length 800005ea status 90000010
5: @cfae4a50 length 800005ea status 90000014
6: @cfae4a60 length 800005ea status 90000018
7: @cfae4a70 length 800005ea status 9000001c
8: @cfae4a80 length 800005ea status 90000020
9: @cfae4a90 length 800005ea status 90000024
10: @cfae4aa0 length 80000070 status 90000028
11: @cfae4ab0 length 800005ea status 9000002c
12: @cfae4ac0 length 800005ea status 90000030
13: @cfae4ad0 length 800005ea status 90000034
14: @cfae4ae0 length 800005ea status 90010038
15: @cfae4af0 length 800005ea status 9001003c
dit heeft eth1 en eth0 allebij :(
  • PowerSp00n
  • Laatst online: 21:21
PowerSp00n
There is no spoon
  • ge-flopt
zet eens achter:
proftpd
192.168.0.98
192.168.0
een : zoals de foutmelding boven aangeeft.
ik heb de host.allow dus schoongemaakt dus dat is niet meer nodig.
mijn dmesg geeft nu een goede output na een reboot.
dmesg:
Linux version 2.4.18 (root@midas) (gcc version 2.95.3 20010315 (release)) #4 Fri May 31 01:25:31 PDT 2002
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000000fff0000 (usable)
BIOS-e820: 000000000fff0000 - 000000000fff8000 (ACPI data)
BIOS-e820: 000000000fff8000 - 0000000010000000 (ACPI NVS)
BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
On node 0 totalpages: 65520
zone(0): 4096 pages.
zone(1): 61424 pages.
zone(2): 0 pages.
Kernel command line: auto BOOT_IMAGE=Linux ro root=302 hdd=ide-scsi
ide_setup: hdd=ide-scsi
Initializing CPU#0
Detected 1533.444 MHz processor.
Console: colour VGA+ 80x25
Calibrating delay loop... 3060.53 BogoMIPS
Memory: 255092k/262080k available (1536k kernel code, 6600k reserved, 426k data, 228k init, 0k highmem)
Dentry-cache hash table entries: 32768 (order: 6, 262144 bytes)
Inode-cache hash table entries: 16384 (order: 5, 131072 bytes)
Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
Buffer-cache hash table entries: 16384 (order: 4, 65536 bytes)
Page-cache hash table entries: 65536 (order: 6, 262144 bytes)
CPU: Before vendor init, caps: 0383fbff c1c3fbff 00000000, vendor = 2
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 256K (64 bytes/line)
CPU: After vendor init, caps: 0383fbff c1c3fbff 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU: After generic, caps: 0383fbff c1c3fbff 00000000 00000000
CPU: Common caps: 0383fbff c1c3fbff 00000000 00000000
CPU: AMD Athlon(tm) XP 1800+ stepping 02
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
Checking for popad bug... OK.
POSIX conformance testing by UNIFIX
mtrr: v1.40 (20010327) Richard Gooch (rgooch@atnf.csiro.au)
mtrr: detected mtrr type: Intel
PCI: PCI BIOS revision 2.10 entry at 0xfdaf1, last bus=1
PCI: Using configuration type 1
PCI: Probing PCI hardware
Unknown bridge resource 0: assuming transparent
PCI: Using IRQ router default [1106/3147] at 00:11.0
PCI: Hardcoded IRQ 14 for device 00:11.1
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
VFS: Diskquotas version dquot_6.4.0 initialized
Journalled Block Device driver loaded
Detected PS/2 Mouse Port.
pty: 512 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with HUB-6 MANY_PORTS MULTIPORT SHARE_IRQ SERIAL_PCI enabled
ttyS00 at 0x03f8 (irq = 4) is a 16550A
ttyS01 at 0x02f8 (irq = 3) is a 16550A
Real Time Clock Driver v1.10e
block: 128 slots per queue, batch=32
RAMDISK driver initialized: 16 RAM disks of 7777K size 1024 blocksize
Uniform Multi-Platform E-IDE driver Revision: 6.31
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller on PCI bus 00 dev 89
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: Unknown VIA SouthBridge, contact Vojtech Pavlik <vojtech@suse.cz>
keyboard: Timeout - AT keyboard not present?(ed)
keyboard: Timeout - AT keyboard not present?(f4)
hda: MAXTOR 6L040J2, ATA DISK drive
hdd: PCRW804, ATAPI CD/DVD-ROM drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
ide0: probed IRQ 14 failed, using default.
ide1 at 0x170-0x177,0x376 on irq 15
ide1: probed IRQ 15 failed, using default.
hda: 78177792 sectors (40027 MB) w/1819KiB Cache, CHS=4866/255/63
ide-floppy driver 0.97.sv
Partition check:
hda: hda1 hda2
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
loop: loaded (max 8 devices)
SCSI subsystem driver Revision: 1.00
request_module[scsi_hostadapter]: Root fs not mounted
md: linear personality registered as nr 1
md: raid0 personality registered as nr 2
md: raid1 personality registered as nr 3
md: raid5 personality registered as nr 4
raid5: measuring checksumming speed
8regs : 2344.800 MB/sec
32regs : 1942.000 MB/sec
pIII_sse : 1272.000 MB/sec
pII_mmx : 3588.000 MB/sec
p5_mmx : 4588.000 MB/sec
raid5: using function: pIII_sse (1272.000 MB/sec)
md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
LVM version 1.0.1-rc4(ish)(03/10/2001)
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 2048 buckets, 16Kbytes
TCP: Hash tables configured (established 16384 bind 16384)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 228k freed
Adding Swap: 248968k swap-space (priority -1)
Linux PCMCIA Card Services 3.1.33
kernel build: 2.4.18 #1 Wed May 8 13:51:37 PDT 2002
options: [pci] [cardbus]
Intel ISA/PCI/CardBus PCIC probe:
no bridges found.
Databook TCIC-2 PCMCIA probe: not found.
ds: no socket drivers loaded!
parport0: PC-style at 0x378 (0x778) [PCSPP,TRISTATE,EPP]
parport0: irq 7 detected
parport0: Printer, HEWLETT-PACKARD DESKJET 940C
lp0: using parport0 (polling).
lp0: compatibility mode
NET4: AppleTalk 0.18a for Linux NET4.0
pci-scan.c:v1.11 8/31/2002 Donald Becker <becker@scyld.com> http://www.scyld.com/linux/drivers.html
3c59x.c:v0.99Xf 11/17/2002 Donald Becker, becker@scyld.com
http://www.scyld.com/network/vortex.html
eth0: 3Com 3c905C Tornado at 0xe800, 00:04:75:f2:6e:66, IRQ 10
8K buffer 5:3 Rx:Tx split, autoselect/Autonegotiate interface.
MII transceiver found at address 24, status 782d.
Using bus-master transmits and whole-frame receives.
eth1: 3Com 3c905C Tornado at 0xe400, 00:04:75:e3:9d:fe, IRQ 11
ip_tables: (C) 2000-2002 Netfilter core team
ip_conntrack (2047 buckets, 16376 max)
Bij deze is het verhaal hopelijk opgelost en ligde het mss aan de host.allow echt vaag maargoed. :)
Ik zal iig even kijken/testen en als hij het dan nog doet de 3com driver update......
alvast bedankt en jullie horen nog van mij!
  • PowerSp00n
PowerSp00n
There is no spoon
ge-flopt schreef op 01 december 2003 @ 18:55:
zet eens achter:
proftpd
192.168.0.98
192.168.0
Nog even om het duidelijk te maken...
[deamon] : [client]
Helaas het probleem is nog steeds niet opgelost...
als ik dmesg intoets krijg ik de bovendste output + dit:
Flags: bus-master 1 full 1 dirty 1124738 current 1124748 restart_tx 0.
Transmit list 0cc1db00 vs. cfae4a20, packet ID 4e.
1: @cfae4a10 length 800003f1 status 90010004
2: @cfae4a20 length 800005ea status 90000008
3: @cfae4a30 length 80000282 status 9000000c
5: @cfae4a50 length 80000282 status 90000014
9: @cfae4a90 length 8000050d status 90000024
10: @cfae4aa0 length 80000282 status 90000028
12: @cfae4ac0 length 800005ea status 90010030
13: @cfae4ad0 length 800005ea status 90010034
het gaat hier met name om de regel: eth0: transmit timed out, tx_status 00 status e000.
Iemand een oplossing? Ik denk dat ik de driver ga updaten...
Helaas, mijn netwerk valt nog steeds regelmatig weg.
Ik heb nu inmiddels mijn 3com kaartje vervangen naar een realtek kaartje.
Nu krijg ik de meldingen van een oversized ethernet frame status 700455e9.
Keb nu inmiddels de mtu aangepast (via de search van got) gevonden en ik krijg de error niet meer. Wel is mijn netwerk al een x uitgevallen, ik denk dat ik binnekort de kabels ga vervangen.
Wat voor ervaringen hebben jullie met soorten nic's onder slackware 8.1?
EyeWiTTneSS
