[PCMark04] Ervaringen
  • 49 views sinds 30-01-2008
Er is weer een nieuw benchmarkprogramma op de markt, dit keer gaat het om PcMark04, de opvolger van pcmark2002
Mischien kan dit het grote "Wat is jouw pcmark04 score-topic"worden
Ik laat het aan de mods anders mag er weer een slotje op
Afbeeldingslocatie: http://www.futuremark.com/products/pcmark04/images/pcmark04_logo_box.jpg
PC Performance Analysis
PCMark™04 is the latest version of the popular PCMark series. PCMark04 is an application-based benchmark and a premium tool for measuring overall PC performance. It uses portions of real applications instead of including very large applications or using specifically created code. This allows PCMark04 to be a smaller installation as well as to report very accurate results. As far as possible, PCMark04 uses public domain applications whose source code can be freely examined by any user.
Pro Online ResultBrowser
The Pro Online ResultBrowser (ORB) is designed and developed specially for PCMark04 Pro and PCMark04 Business users. In addition to the normal functionalities you can do multiple comparisons, get detailed system info, use dynamic compare URLs and much much more. The Pro ORB extends PCMark04 to the extreme!
The extended PCMark04 ORB features are only available via PCMark04 Pro and PCMark04 Business.
Key PCMark04 Pro and Business Features
System Test Suite, presenting the PCMark score.
Memory Test Suite, giving Memory score.
CPU Test Suite, giving CPU score.
Graphics test suite giving a Graphics score
HDD Test Suite and HDD score.
Customizable test run including multithreaded tests.
Online services. Submit your results and compare them to PCMark04 results from all over the world.
Minimum System requirements
x86 compatible processor, 1000MHz
128MB system memory
60MB of hard disk space (and additional 130 MB free space for HDD testing)
DirectX 7 generation graphics adapter that is fully DirectX 7 compliant.
Microsoft Windows 2000 or XP operating system
DirectX9.0 or later
Download de free versie hier:
http://www.futuremark.com/download/?pcmark04.shtml
  • Okyah
Okyah
wespachterrrrrfilm..
PCMark '04/
Er is hier gisterenavond ook een topique over geopend :)
Alone at last
Just nostalgia and I
We were sure to have a blast
  • Rafe
  • Laatst online: 27-06-2025
Zie Okyah, twee topics over hetzelfde programma is wat dubbelop natuurlijk :)
