iTunes DRM pas op pc toegevoegd?
ik las op www.ircspy.com het volgende
en dan gaat het mij om de vetgedrukte text. (de rest heb ik maar gepost omdat het wel een beetje interesant is)
Begrijp ik goed dat de DRM pas op je pc word toegevoegd aan het bestand?
Jon Lech Johansen, better known as DVD Jon for his authorship of the DeCSS decryption software, has turned his attention to Apple's locked music format.
While he hasn't decrypted the DRM which Apple uses, he has produced a simple Windows command line utility which will install a DLL which dumps the output of a QuickTime stream to a file. The short C program is called "QuickTime for Windows AAC memory dumper". (To compile the program requires MinGW and MSYS from here.)
An application called MyTunes already performs much the same function, but Johansen's is open source. He therefore unveils the DLL entry point, and the exit hole. So let the fun and games commence: until OS vendors bring in portions of the 'trusted' architecture which Intel is building, such illuminating capers (such Great Deeds) are possible. ( This isn't, as we foolishly thought earlier, the analog hole: the software isn't capturing the output of the sound card - it's intercepting QuickTime playback before it has a chanced to be 0wn3d (or however you spell it), by Hollywood. But it sets up an interesting confrontation.
A similar arms took place in the early 1990s, when IBM used a similar technique to wrap its OS/2 for Windows product, a rival operating system, around Windows 3.1. IBM wanted to halve the steet price of its rival operating system, and at the time a big chunk of that OS price went to back to Microsoft, because as part of their messy divorce, IBM had agreed to bundle Windows into every copy of OS/2. So the IBM product, which came without Windows (and thus the Redmond royalty) could be sold much cheaper. But it relied on being able to run the copy of Windows that was there, so needed to know the entry points of the key Microsoft system DLLs.
A brief arms race ensued in which Microsoft rapidly brought out new versions of the operating system (and in this day and age, how often do you hear that?) which shifted the entry points a little each time, so IBM's programmers had to go back and work out where they were all over again
