Bind met ddns en dhcpd problemen
  • imdos
  • Laatst online: 09:50
imdos
I use FreeNAS and Ubuntu
Goed ik probeer dus dynamische updates toe te staan en heb al veel dingen geprobeerd maar het werkt nog niet!
/etc/dhcpd.conf
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
default-lease-time 384000;
max-lease-time 400000;
option subnet-mask 255.255.255.0;
option broadcast-address 192.168.1.255;
option routers 192.168.1.1;
option netbios-name-servers 192.168.1.1;
option domain-name-servers 192.168.1.1;
#option domain-name-servers 192.168.1.1, 62.45.46.46, 62.45.45.45;
option domain-name "imdos.ath.cx";
option netbios-dd-server 192.168.1.1;
option netbios-node-type 8;
ddns-update-style ad-hoc;
ddns-updates on;
ddns-domainname "imdos.ath.cx";
ddns-rev-domainname "in-addr.arpa";
# Start of rndc.conf
key "rndc-key" {
        algorithm hmac-md5;
        secret "NLwvzm0p8JhOuCx3iJCUgw==";
zone 1.168.192.in-addr. {
primary 127.0.0.1;
key rndc-key;
zone imdos.ath.cx{
primary 127.0.0.1;
key rndc-key;
subnet 192.168.1.0 netmask 255.255.255.0 {
        range 192.168.1.100 192.168.1.200;
        ddns-updates on;
        deny client-updates;
host xxx    {
                        hardware ethernet 00:00:b4:bf:02:04;
                        fixed-address 192.168.1.20;
en /chroot/named-in/etc/named.conf
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
options {
        pid-file "/var/run/named.pid";
        directory "/var/named";
        listen-on port 53 {
        127.0.0.1;
        192.168.1.1;
logging {
        category lame-servers { null; };
        //category cname { null; };
key "rndc-key" {
        algorithm hmac-md5;
controls {
       inet 127.0.0.1 port 953
               allow { 127.0.0.1; } keys { "rndc-key"; };
zone "." in {
        type hint;
        file "root.cache";
zone "0.0.127.in-addr.arpa" in {
        type master;
        notify no;
        file "127.0.0.db";
zone "imdos.ath.cx" in {
        type master;
        notify no;
        file "imdos.ath.cx.db";
        //allow-transfer { 192.168.1.2/32; };
        allow-query { 127/8; 192.168.1/24; };
        allow-update { key rndc-key; 127/8; };
        //update-policy { grant * self * A TXT;
zone "1.168.192.in-addr.arpa" in {
        type master;
        notify no;
        file "192.168.1.db";
Zoals je kan zien heb ik al enkele dingen gecomment want dat werkte niet!
Error die ik krijg is
Nov 23 14:50:13 server dhcpd: if IN A malafide.imdos.ath.cx rrset
doesn't exist add 192000 IN A malafide.imdos.ath.cx 192.168.1.200:
RRset already exists.
De named db files lijken me overbodig maar ik kan ze er wel bij plakken
Heb je posting gefix0red ;) -- r3boot
[ Voor 8% gewijzigd door imdos op 25-11-2003 01:11 . Reden: aangepaste config ]
pvoutput. Waarom makkelijk doen, als het ook moeilijk kan! Every solution has a new problem
Krijg je nog messages van de nameserver in je logs? Tevens, kan het zijn dat het adres wat je wilt opvragen al een keer is geregistreerd?
  • imdos
imdos
/usr/sbin/syslogd -a /chroot/named-in/dev/log -a /chroot/named-out/dev/log -m 0
Alles wordt gelogged dus, maar ik zie alleen dit in mijn /var/log/messages
Nov 23 14:46:08 server named[14257]: client 127.0.0.1#45800: updating zone 'imdos.ath.cx/IN':
update failed: 'rrset does not exist' prerequisite not satisfied (YXRRSET)
Die andere melding van m'n startpost komt dus in syslog
Ja klopt die staat ook in de dns ... maar als ik hem er niet in zet voegde hij ook niets toe! Ik krijg deze melding al tijden nl. maar snap niet wat er fout gaat :'(
[ Voor 21% gewijzigd door imdos op 23-11-2003 17:08 . Reden: update ]
  • imdos
imdos
ik ben al verder nu!
via deze url http://ccs.cla.kobe-u.ac.jp/Jouhou/97/ajichi/appendix.htm kwam ik erachter wat er precies gebeurde. En bleek dat nsupdate dus de eerste server uit je /etc/resolv.conf pakte en dat was mijn nameserver van de provider! Dat is dus meteen ff aangepast.
Helaas werkt het nog niet helemaal maar met die website zit ik op de goede hoogte volgens mij
Handmatig aapassen werkt nu wel!
Nov 24 18:20:53 server named[254]: client 192.168.1.1#34082: updating zone
 'imdos.ath.cx/IN': delete all rrsets from a name
Nov 24 18:21:34 server named[254]: client 192.168.1.1#34082: updating zone
'imdos.ath.cx/IN': adding an RR
[ Voor 28% gewijzigd door imdos op 24-11-2003 18:30 . Reden: update ]
  • imdos
imdos
Nieuwe update ... heb wat zitten vergelijken en vroeten en uit mijn db files de betreffende pc gehaald en nu werkte het wel!
Enkel rest me nu nog een probleem .... de reverse zone wordt niet geupdate :(
Iemand die mij een laatste sprankje hoop kan geven ... op got vond ik een thread met deny client-updates; in m'n /etc/dhcpd.conf maar dat werkt dus niet |:( :'(
  • imdos
imdos
http://www.cisco.com/univ...nr/nr50/nrug/09dyndns.pdf
Hier staat een stukje in over win2k machine's die geen ptr record zouden updaten, kan iemand die er meer van weet dit bevestigen?
  • imdos
imdos
kickit!
  • imdos
imdos
Woei .... het werkt iig met een linux client die ik heb opgetuigd als test-server! Misschien omdat de entry al bestond dat er niets toegevoegd werd ofzo ...
Maar Windows blijft nog vreemd iig
