[fedora 1]wine compileren
  • a casema user
  • Laatst online: 09:14
Tijdens 'make' van wine (versie 20031118) krijg ik de volgende foutmelding.
gcc -c -I. -I. -I../../include -I../../include -D__WINESRC__ -D_WINX32_ -D_REENTRANT -fPIC -Wall -mpreferred-stack-boundary=2 -fno-strict-aliasing -gstabs+ -Wpointer-arith -g -O2 -o cookie.o cookie.c
In file included from /usr/include/openssl/ssl.h:179,
from internet.h:36,
from cookie.c:39:
/usr/include/openssl/kssl.h:136: error: syntax error before '*' token
/usr/include/openssl/kssl.h:149: error: syntax error before '*' token
/usr/include/openssl/kssl.h:150: error: syntax error before '*' token
/usr/include/openssl/kssl.h:151: error: syntax error before '*' token
/usr/include/openssl/kssl.h:152: error: syntax error before '*' token
/usr/include/openssl/kssl.h:153: error: syntax error before '*' token
/usr/include/openssl/kssl.h:155: error: syntax error before '*' token
/usr/include/openssl/kssl.h:157: error: syntax error before '*' token
/usr/include/openssl/kssl.h:159: error: syntax error before '*' token
/usr/include/openssl/kssl.h:167: error: syntax error before '*' token
In file included from internet.h:36,
from cookie.c:39:
/usr/include/openssl/ssl.h:909: error: syntax error before "KSSL_CTX"
/usr/include/openssl/ssl.h:931: error: syntax error before '}' token
make[2]: *** [cookie.o] Fout 1
make[2]: Weggaan uit map `/usr/local/wine-20031118/dlls/wininet'
make[1]: *** [wininet] Fout 2
make[1]: Weggaan uit map `/usr/local/wine-20031118/dlls'
make: *** [dlls] Fout 2
Het lijkt mij een openssl probleem, maar ik daarvan de nieuwste versie op mijn pc staan.
openssl-0.9.7a-23
openssl-devel-0.9.7a-23
Iemand een idee ?
Fedora Core 1
kernel 2.4.23-rc3
Taaaa taa taa taaaa taa taa ta taaataaaaa.
  • Lancer
  • Laatst online: 08:11
Lancer
What the......
Zelfde resultaat met gcc 3.2?
CC=gcc32
export CC
De prelink feature van Fedora breekt wine. Om wine te laten lopen edit /etc/sysconfig/prelink en zet prelink uit. Run daarna /etc/cron.daily/prelink
[ Voor 14% gewijzigd door Lancer op 22-11-2003 17:36 ]
Je kunt niet in een systeem meten zonder het systeem te beinvloeden.... (gevolg van de Heisenberg onzekerheidsrelatie)
  • a casema user
ik kan met CC-gcc32 .configure nieteens runnen omdat die een foutmelding geeft. (dan gcc niet vinden)
ik heb ook de volgende gcc versie
gcc-g77-3.3.2-1
gcc-java-3.3.2-1
libgcc-3.3.2-1
gcc-c++-3.3.2-1
gcc-gnat-3.3.2-1
gcc-3.3.2-1
Wat staat er in /usr/include/openssl/kssl.h op regel 136?
(ik heb deze error al eerder gehad geloof ik maar dan moet ik eerst even weten wat er ook alweer stond, en ik draai atm geen Linux)
  • a casema user
dit is regel 136 t/m 167 van kssl.h
krb5_octet FAR *key;
} KSSL_CTX;
#define KSSL_CLIENT 1
#define KSSL_SERVER 2
#define KSSL_SERVICE 3
#define KSSL_KEYTAB 4
#define KSSL_CTX_OK 0
#define KSSL_CTX_ERR 1
#define KSSL_NOMEM 2
/* Public (for use by applications that use OpenSSL with Kerberos 5 support */
krb5_error_code kssl_ctx_setstring(KSSL_CTX *kssl_ctx, int which, char *text);
KSSL_CTX *kssl_ctx_new(void);
KSSL_CTX *kssl_ctx_free(KSSL_CTX *kssl_ctx);
void kssl_ctx_show(KSSL_CTX *kssl_ctx);
krb5_error_code kssl_ctx_setprinc(KSSL_CTX *kssl_ctx, int which,
krb5_data *realm, krb5_data *entity);
krb5_error_code kssl_cget_tkt(KSSL_CTX *kssl_ctx, krb5_data **enc_tktp,
krb5_data *authenp, KSSL_ERR *kssl_err);
krb5_error_code kssl_sget_tkt(KSSL_CTX *kssl_ctx, krb5_data *indata,
krb5_ticket_times *ttimes, KSSL_ERR *kssl_err);
krb5_error_code kssl_ctx_setkey(KSSL_CTX *kssl_ctx, krb5_keyblock *session);
void kssl_err_set(KSSL_ERR *kssl_err, int reason, char *text);
void kssl_krb5_free_data_contents(krb5_context context, krb5_data *data);
krb5_error_code kssl_build_principal_2(krb5_context context,
krb5_principal *princ, int rlen, const char *realm,
int slen, const char *svc, int hlen, const char *host);
krb5_error_code kssl_validate_times(krb5_timestamp atime,
krb5_ticket_times *ttimes);
krb5_error_code kssl_check_authent(KSSL_CTX *kssl_ctx, krb5_data *authentp,
  • GiLuX
  • Laatst online: 12-11-2025
waarom niet gewoon de fedora rpm van sourceforge pakken?
daarna wel even het volgende aanpassen in /etc/sysconfig/prelink
PRELINK_OPTS=-mR
naar
PRELINK_OPTS="-mR --no-exec-shield"
ivm exec-shield errors
"I disagree with what you are saying, but I will defend to the death your right to say it." -- not clear who
  • a casema user
GiLuX schreef op 22 november 2003 @ 19:18:
PRELINK_OPTS=-mR
naar
Ik wist niet dat er ook RPMs beschikbaar waren voor fedora.
Maar deze zijn er inderdaad en werken ook goed. Bedankt.
