[RTCW] Single Player wil niet opstarten
  • 333 views sinds 30-01-2008
  • LollieStick
  • Laatst online: 10-09 11:48
Ik heb RTCW geinstallleerd en nu heb ik het probleem dat als ik de singleplayer mode opstart, het spel crasht bij het grijze scherm (dus nog voor de intro). Dit scherm krijg ik ook bij de multiplayer maar daar vliegt ie wel door naar het spel.
In de console zie ik dit staan:
Wolf 1.32 win-x86 May 1 2002
----- FS_Startup -----
Current search path:
C:\Program Files\Return to Castle Wolfenstein - Game of The Year Edition\main\sp_pak4.pk3 (21 files)
C:\Program Files\Return to Castle Wolfenstein - Game of The Year Edition\main\sp_pak3.pk3 (14 files)
C:\Program Files\Return to Castle Wolfenstein - Game of The Year Edition\main\sp_pak2.pk3 (232 files)
C:\Program Files\Return to Castle Wolfenstein - Game of The Year Edition\main\pak0.pk3 (4775 files)
C:\Program Files\Return to Castle Wolfenstein - Game of The Year Edition/main
5042 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec wolfconfig.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found AMD w/ 3DNow!
Bypassing CD checks
----- Client Initialization -----
Cmd_AddCommand: map_restart already defined
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...103 PFDs found
...hardware acceleration found
...PIXELFORMAT 9 selected
...creating GL context: succeeded
...making context current: succeeded
Initializing OpenGL extensions
...using GL_EXT_texture_compression_s3tc
...using GL_EXT_texture_env_add
...using WGL_EXT_swap_control
...using GL_ARB_multitexture
...using GL_EXT_compiled_vertex_array
...WGL_3DFX_gamma_control not found
...GL_ATI_pn_triangles not found
...ignoring GL_EXT_texture_filter_anisotropic
...using GL_NV_fog_distance
GL_VENDOR: NVIDIA Corporation
GL_RENDERER: GeForce4 Ti 4200/AGP/SSE/3DNOW!
GL_VERSION: 1.4.1
GL_EXTENSIONS: GL_ARB_depth_texture GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shadow GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_window_pos GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_paletted_texture GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_shared_texture_palette GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_vertex_array GL_HP_occlusion_test GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_fence GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NVX_ycrcb GL_SGIS_generate_mipmap GL_SGIS_multitexture GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
GL_MAX_TEXTURE_SIZE: 4096
GL_MAX_ACTIVE_TEXTURES_ARB: 4
PIXELFORMAT: color(32-bits) Z(24-bit) stencil(8-bits)
MODE: 3, 640 x 480 fullscreen hz:60
GAMMA: software w/ 0 overbright bits
CPU: AMD w/ 3DNow!
rendering primitives: single glDrawElements
texturemode: GL_LINEAR_MIPMAP_NEAREST
picmip: 1
picmip2: 2
texture bits: 0
multitexture: enabled
compiled vertex arrays: enabled
texenv add: enabled
compressed textures: enabled
ATI truform: disabled
NV distance fog: enabled
Fog Mode: GL_EYE_RADIAL_NV
Initializing Shaders
...loading 'scripts/ai.shader'
...loading 'scripts/alpha.shader'
...loading 'scripts/blacksmokeanim.shader'
...loading 'scripts/blacksmokeanimb.shader'
...loading 'scripts/characters.shader'
...loading 'scripts/clipboard.shader'
...loading 'scripts/common.shader'
...loading 'scripts/cursorhints.shader'
...loading 'scripts/decals.shader'
...loading 'scripts/eerie.shader'
...loading 'scripts/expblue.shader'
...loading 'scripts/explode1.shader'
...loading 'scripts/fijets.shader'
...loading 'scripts/firest.shader'
...loading 'scripts/flamethrower.shader'
...loading 'scripts/funnel.shader'
...loading 'scripts/gfx.shader'
...loading 'scripts/heat.shader'
...loading 'scripts/lights.shader'
...loading 'scripts/liquid.shader'
...loading 'scripts/maxx.shader'
...loading 'scripts/menu.shader'
...loading 'scripts/metal.shader'
...loading 'scripts/models.shader'
...loading 'scripts/netest.shader'
...loading 'scripts/oldwolf.shader'
...loading 'scripts/organics.shader'
...loading 'scripts/particle.shader'
...loading 'scripts/q3view.shader'
...loading 'scripts/sfx.shader'
...loading 'scripts/signs.shader'
...loading 'scripts/skin.shader'
...loading 'scripts/sky.shader'
...loading 'scripts/solo.shader'
...loading 'scripts/surfaces.shader'
...loading 'scripts/terrain.shader'
...loading 'scripts/test.shader'
...loading 'scripts/twiltb.shader'
...loading 'scripts/twiltb2.shader'
...loading 'scripts/ui.shader'
...loading 'scripts/ui_hud.shader'
...loading 'scripts/ui_notebook.shader'
...loading 'scripts/ui_wolf.shader'
...loading 'scripts/viewflames.shader'
...loading 'scripts/walls.shader'
...loading 'scripts/z_light.shader'
----- finished R_Init -----
WARNING: R_FindImageFile could not find 'ui/assets/SMOKE-16bit.tga' in shader 'console'
Shader console has a stage with no image
WARNING: R_FindImageFile could not find 'ui/assets/wolficonback4.tga' in shader 'console2'
Shader console2 has a stage with no image
------- sound initialization -------
Initializing DirectSound
locked hardware. ok
----- Sound Info -----
sound system is muted
1 stereo
32768 samples
16 samplebits
1 submission_chunk
22050 speed
0x9da8060 dma buffer
No background file.
Sound memory manager started
Parsing menu file:ui/main.menu
Parsing menu file:ui/setup.menu
Error: file ui/setup.menu, line 1: file ui\menudef.h not found
Parsing menu file:ui/controls.menu
Parsing menu file:ui/cdkey.menu
Parsing menu file:ui/system.menu
Error: file ui/system.menu, line 1: file ui\menudef.h not found
Parsing menu file:ui/options.menu
Error: file ui/options.menu, line 1: file ui\menudef.h not found
Parsing menu file:ui/credit.menu
Parsing menu file:ui/connect.menu
Parsing menu file:ui/quit.menu
Parsing menu file:ui/vid_restart.menu
Parsing menu file:ui/snd_restart.menu
Parsing menu file:ui/rec_restart.menu
Parsing menu file:ui/default.menu
Parsing menu file:ui/error.menu
Parsing menu file:ui/serverinfo.menu
Parsing menu file:ui/quitcredit.menu
Parsing menu file:ui/resetscore.menu
Parsing menu file:ui/buy_pop.menu
Parsing menu file:ui/multiplayer_pop.menu
Parsing menu file:ui/play.menu
Parsing menu file:ui/load.menu
Parsing menu file:ui/mods.menu
Error: file ui/mods.menu, line 1: file ui\menudef.h not found
Parsing menu file:ui/briefing.menu
UI menu load time = 10 milli seconds
ERROR: menu file not found: ui/ingame.txt, using default
RE_Shutdown( 0 )
----- R_Init -----
GL_VERSION: 1.4.1
CPU: AMD w/ 3DNow!
picmip: 1
picmip2: 2
texture bits: 0
texenv add: enabled
UI menu load time = 11 milli seconds
recursive error after: menu file not found: ui/ingame.txt, using default
Het vreemde is dat ik het spel net geinstalleerd heb en het spel voorheen altijd prima gewerkt heeft. Het schijnt ook het geval te zijn dat het spel niet lekker werkt met diverse display drivers. Echter, met versie 45.23, 52.16, 53.03 werkt het niet dus zoek ik het probleem op dit moment ergens anders.
Kan iemand mij helpen?
Thanks a lot!
Systeem:
Asus A7N8X-X
Athlon XP 2400+
Point of View Geforce 4 Ti4200 (64MB)
Soundblaster Audigy
WD 120GB Harddisk 8MB
512 MB DDR Samsung
RTCW met en zonder patches geprobeerd. CD-versie is Game of The Year v1.33
  • Damian
  • Laatst online: 11:27
Damian
Insane Obtrusion
uhm tjah, hij zegt dat er een bestand ontbreekt.
Je hebt gecheckt of het bestand er wel staat of nie ?
  • LollieStick
ja, en op de pc beneden werkt het prima met dezelfde cd's en hetzelfde type dvd-speler.
Het bestand kan ik nergens terug vinden. Beneden ook niet :?
[ Voor 30% gewijzigd door LollieStick op 22-11-2003 16:01 ]
  • LollieStick
*schop*
