Ik zie in een aantal hubs de laatste tijd waarschuwing als deze:
WARNING!!!!!
We have found strange things in Public hubs lately.
18 hubs with same Share in the hubs 222 TB and 599 users in all of them.
It's even the same IP address but different ports. From port 410 to 570.
This might be hubs that attempt to logg IPs from those who connect to them.
This can have been put together on a 100 Mbit line from companies that want to close DC++.
We don't know this for a fact but it's so suspisious that we recommend you to stay clear of them.
We don't want you to get letters from your ISP for using DC++.
I would never go into such a hub!!
If you are an expert in hiding your IP and so good in using a computer that you will never be traced,
feel free to check it out and report back to the operators in here.
But you should then use one IP that is either RIAA or Microsoft IP.
Best regards from the operators
Dit wordt dus ook lekker... DC ook al pleite straks. Wat vinden jullie hiervan?
WARNING!!!!!
[ Voor 3% gewijzigd door SkyStreaker op 19-11-2003 20:33 ]
StabilityMatrix Discord -> (persistent invite linkje)
