Welke ADSL Win98 patch? PPPoE?
  • 110 views sinds 30-01-2008
sguide_tweak_98_ME (updated 11/23/00) - Generic Registry patch for Windows 98/98SE and Windows ME (includes a fix for 98SE ICS, as well as corrected SackOpts location). This is an updated version of mtupatch98, it's an .inf file that tweaks the Registry and adds all the optimum settings for Cable modem, DSL, or any similar broadband connection. To install, extract the file, then just right-click and choose "Install" from the
Pull-down menu. You need to reboot for changes to take effect.
sguide_tweak_98_ME_PPPoE (updated 11/23/00) - Registry patch for Windows 98/98SE or Windows ME using PPPoE. (includes a fix for 98SE ICS, as well as smaller MaxMTU, corrected for PPPoE). The patch adds all the optimum settings for Cable modem, DSL, or any similar
broadband connection that has PPPoE implemented. To install, extract the file, then just right-click and choose "Install" from the Pull-down menu. You need to reboot for changes to take effect. The PPPoE patch generally applies to some xDSL lines, it is not for use with Cable modems. For additional info on PPPoE check out our Terms & definitions page.
Ik heb ADSL van planet, maar welke speedup patch moet ik nou nemen?
als je win98 hebt krijg je problemen met mxstream....zie adsl topic
  • topper
  • Laatst online: 24-01-2023
Op donderdag 07 december 2000 14:10 schreef Tha-Master het volgende:
Volgens mij moet je de bovenste hebben
specs
  • qless
  • Laatst online: 11:19
qless
...vraag maar...
PPPoE = Voor adsl in belgie, en cable wanadoo met com21
PPtP = Voor adsl in nederland (mxstream)
Website
Drones: Air 3s, Mini 4 Pro, Avata 2
Camera's: Canon R6, Canon 5d2, Dji Osmo Action 4
Objectieven: 8 fisheye, 14f2.8, 24f2.8, 50f1.8, 135f2, 17-40f4, 24-105f4, 70-300f4-5.6, 150-600f5-6.3, 25f2.8-2.5x-5x
PPPoE ook voor colt-telecom SDSL.
