Ik heb alles van de volgende tekst gedaan, maar het lukt met niet om m'n BP6 mobo hoger als 2.3v te krijgen. Kan iemand mij er misschien bij helpen die het wel is gelukt met z'n BP6?
THE ABIT BIOS TRICK _ STEP BY STEP FOR NEWBIES !
On request :-)
1 : First of all download the desired bios and flashprogram (awdflash.exe).
2: Execute the downloaded .exe bios file.
3: Format a diskette with the copy systemfiles command.
( Or go to the Dos prompt and write : format a:/s )
4: Copy the .bin file you got after excecuting the .exe bios file to the floppy.
Write down the name of the .bin file ( i.e. Bh6_kg.bin )
5: Copy the awdflash.exe program to the floppy.
6: Reboot the computer.
7: When the computer beeps (post's) and starts counting your ram push delete to get into the bios.
Step 1: Set your bios settings to default - remember the cpu speed too.
Step 2: Set voltage to user defined and thereafter boost it up to 2.3 Volts.
Step 3: In the Bios Features Setup; set the boot sequence to : a,c,scsi.
and enable " Boot Up Floppy Seek"
Step 4: Save settings and restart.
Now the computer will start from the floppy.
When you see your floppy drive ( A:) you are ready to flash the bios .
1:Type awdflash and the flashprogram starts.
2:Type in the name of the .bin file(i.e BH6_kg.bin) - or the one you wrote down previously ; and Enter.
3: The flash program will ask you if you want to save the old bios - answer yes !
4: Save the old bios to the floppy with any name you like - I use "old" .
5: After the flash program have saved the old bios it will ask you if you want to program the bios - answer NO.
6: The flash program will now terminate and return to your floppy drive.
( What you have done now is to save your old bios - and you now have the opportunity to flash back to the previously bios again. When you do the bios trick you dont have the opportunity to save the bios. )
Now you are ready to trick your bios voltage settings !
7:The trick is NOT to start the flashprogram as you did previously : lets say you have downloaded the kg bios and now you have a file called Bh6_kg.bin on your floppy - Right ?
8: Type excactly as follows for the BH6kg.bios : awdflash.exe bh6_kg.bin /py /sn /cc
9:Another example - if you downloaded the BH6jj.bios : awdflash.exe bh6_jj.bin /py /sn /cc
10: Restart and go into your bios settings - now you will see that 2.3Volts is set to be default for your Celeron.
Frank Monroe advises you not to go higher than 2.5 Volts - I also reccommend to read his faq .
I have my C366 at 2.6 Volts and it's been running almost perfectly for three months, I've had crashes in test programs.
But everything in my machine is taken to the limit so I don't know what causes these random crashes.
@Nils H Gjendem '99
Famous last words : If you destroy anything - blame yourself !
If you succeed send me a mail - and thank me for writing this for you in my spare time !
Remember - I could have been drinking beer and having a good time instead :-)
On request :-)
@Nils H Gjendem '99
