Ik heb een bepaalde sms site: 1stwap en als ik me inlog en ik klik op send sms om een nieuw smsje te scrijven die in een nieuw vesnter komt dan komt er te staan dat ik geen cookies accepteer...maar die staan allemaal gewoon op accepteren!
En het vreemde is dat ik er zo af en toe WEL in kom en gewoon kan versturen!
Kan iemand me helpen!?
[update] De foutmelding:
Ooops,... You've got a Problem !
If you were brought to this Page, ask yourself the following questions:
Did you leave your browser idle for a long time?
Your session time for accessing this page has ended.
Just Login again!.
Are you using a Browser that doesn't support cookies, or do you have cookies disabled?
Your browser must support cookies, and the options for cookies must be enabled.
Steps to enable cookies:
Internet Explorer 5 (or higher)
1. Click Tools, and then Internet Options...
2. Click the Security tab.
3. Select the Internet zone.
4. On Default Levels, select a security level other than High. -or-
on Custom Level, scroll to the Cookies section, and then click Enable for both cookies options.
Internet Explorer 4.x
1. Click View, and then Internet Options...
2. Click the Advanced tab.
3. Scroll to the Security section.
4. Under Cookies, select always accept Cookies.
Netscape Navigator
1. Click Edit, and then Preferences...
3. Under Cookies, select Accept all cookies.
If you see a Windows message notifying you, that a Web site is trying to send you a cookie when you try to sign in, please choose Continue otherwise Windows will reject your request.
Just Login again!.
Netscape Navigator
[ Voor 68% gewijzigd door Verwijderd op 10-11-2003 08:58 ]
