[SAMBA] PDC & XP
Hi,
Ik ben druk bezig geweest met het maken van een PDCtje
dit is me smb.conf (gecopyed uit mooie samba topic :)
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
# Globale parameters
[global]
        log file = /var/log/samba/samba.log.%m
        passwd chat debug = Yes
        passwd chat = *New*UNIX*password* %n\n *Retype*new*UNIX*password* \
        socket options = TCP_NODELAY SO_SNDBUF=8192 SO_RCVBUF=8192
        logon drive = Q: “GEWENSTE DRIVELETTER, DIT ZAL BIJ JE XP CLIENT VERSCHIJNEN”
        domain master = Yes
        time server = Yes
        encrypt passwords = Yes
        veto files = /Network Trash Folder/TheVolumeSettingsFolder/lost+found/
        logon home = \\HILFINGER\profiles\win9x\%U\.profile “MAP WAAR POLICY GEGEVENS WORDEN GESAVED VOOR WIN 9X CLIENTS”
        passwd program = /usr/bin/passwd %u
        wins support = true
        dns proxy = No
        netbios name = HILFINGER
        server string = PDC SAMBA
        logon script = login.bat “LOGIN SCRIPT, DIT BEVINDT ZICH IN DE MAP VAN DE SHARE NETLOGON”
        unix password sync = Yes
        logon path = \\HILFINGER\profiles\%U
        workgroup = MSHOME
        os level = 64
        add user script = /usr/sbin/useradd -s " " -d /dev/null -g machines -M %u \ “IS NODIG WANNEER JE SAMBA ZELF DE USER AAN WILT LATEN MAKEN”
        bind interfaces only = Yes
        max log size = 250
        domain admin group = @admins “GOOI HIER JE ROOT USER O.I.D. IN”
        domain logons = Yes
        log level = 2
[netlogon]
        create mask = 0644
        comment = Login service
        writeable = yes
        path = /home/netlogon
        write list = root
[profiles]
        writeable = yes
        path = /home/profiles
        force directory mode = 0777
        force create mode = 0600
        create mask = 0600
        comment = Roaming profiles directory
        directory mask = 0777
[homes]
    comment = Home directory geshared naar logondrive
    read only = No
    create mask = 0755
    directory mask = 0775
    browseable = No
Als ik nu inlog via me client pc (user root) loopt hij door en geeft melding van zwevend profile, so far so good...
dan druk ik op ok ... hoor windows theme.... en dan REBOOT ?
hij start opnieuw op , dus ik denk dat hij de profiles niet goed kan weg schrijven maar rechten op de profile map & netlogon map staan goed
Help !
Update (samba.log files)
[root@kbl-gs4104 samba]# cat samba.log.laptop
[2003/11/09 16:56:29, 1] smbd/password.c:pass_check_smb(545)
  Couldn't find user 'tommy' in passdb.
[2003/11/09 16:56:29, 2] smbd/reply.c:reply_sesssetup_and_X(975)
  NT Password did not match for user 'tommy'!
[2003/11/09 16:56:29, 2] smbd/reply.c:reply_sesssetup_and_X(985)
  Defaulting to Lanman password for tommy
[2003/11/09 16:56:29, 1] smbd/reply.c:reply_sesssetup_and_X(1001)
  Rejecting user 'tommy': authentication failed
[2003/11/09 16:56:34, 2] smbd/server.c:exit_server(461)
  Closing connections
[2003/11/09 17:01:25, 1] smbd/password.c:pass_check_smb(545)
[2003/11/09 17:01:25, 2] smbd/reply.c:reply_sesssetup_and_X(975)
[2003/11/09 17:01:25, 2] smbd/reply.c:reply_sesssetup_and_X(985)
[2003/11/09 17:01:25, 1] smbd/reply.c:reply_sesssetup_and_X(1001)
[2003/11/09 17:01:31, 2] smbd/server.c:exit_server(461)
  Closing connections
  Closing connections
  Closing connections
[ Voor 38% gewijzigd door Verwijderd op 09-11-2003 17:04 ]
  • Mitch
  • Laatst online: 15-01 23:26
ik zou zeggen, ga je logs een doorspitten, op zowel je samba server als je xp client, warschijnlijk kom je ddar wel wat tegen (anders log level ophoog gooien).
  • elevator
elevator
Officieel moto fan :)
Een Windows PC reboot in principe niet als hij zijn profiel niet kan ophalen, maar zou een foutmelding moeten geven dat je met een tijdelijk profiel bent aangelogd.
Erg vreemd als je inlogt als root.....
  • Kippenijzer
  • Laatst online: 03-09 09:21
Kippenijzer
McFallafel, nu met paardevlees
heet de pc weermee je in wil loggen toevallig tommy? Heb je wel een machine account aangemaakt?
Kippenijzer schreef op 09 november 2003 @ 17:15:
nope client pc naam is " LAPTOP"
laptop$:x:504:503:\laptop:/dev/null:/bin/false
Tevens krijg ik als ik met een nieuwe user inlog de vraag (migratie van windows 3.x) en dan kan ik win.ini en control.ini kopieren maar daarna is het ook weer reboten
Client logs
[code]
De automatische certificaatinschrijving voor lokaal systeem kan geen contact krijgen met de Active Directory 0x8007054b. Het opgegeven domein bestaat niet of kan geen contact maken met dit domein.
. De inschrijving wordt niet uitgevoerd.
Zie Help en ondersteuning op http://go.microsoft.com/fwlink/events.asp voor meer informatie.
Windows kan het klassenregisterbestand niet uit het geheugen verwijderen omdat het momenteel door een andere toepassing of service wordt gebruikt. Het bestand wordt uit het geheugen verwijderd als het niet meer wordt gebruikt.
[ Voor 69% gewijzigd door Verwijderd op 09-11-2003 17:28 ]
Verwijderd schreef op 09 november 2003 @ 17:18:
Client logs
Even vanaf de grond af: kan je zonder dat script en profile gedoe inloggen?
Pas daarna de rest gaan proberen, ander sta je binnen de kortste keren een oplossing te zoeken voor het verkeerde probleem.
Weet je zeker dat je ingelogd hebt als root zoals je hierboven beweerde?
De fout mbt user tommy gaat echt om het inloggen van iemand met een gebruikersnaam tommy. Toon in iedergeval de goede informatie.
Heb je de user accounts voor samba wel aangemaakt?
Dat er gebruikeraccounts bestaan op de linux bak wil nog niet zeggen dat die accounts ook gebruikt worden voor de controle door samba.
Een veel gemaakte fout is nl dat 'unix password sync' niet betekent dat automatische de toeganggegevens voor linux overgenomen worden naar samba.
Idd.....
Het werkt
ik had de rechten niet goed van me loginscript waardoor de client pc... tja rebooten
Maaru thanks !
