Zorgen dat je iig de modem drivers voor je T310 geinstalleerd heb, dan kan je gewoon inbellen (volgens mij moet je in windows dan inbelnummer G gebruiken, wil je gebruik maken van GPRS)
Good luck.
T310 Drivers, scripts and patches
Please select the download you want from the list below
Sony Ericsson Modem Scripts
Modem drivers for Sony Ericsson T300/T306/T310/T312/T316.
Download the modemscripts to make it easier to use IR (Infrared connection) on Windows XP/2000.
Sony Ericsson Dial-Up suite version 1.5.5
Dial-Up Networking Wizard is free software that will guide you through the creation of GPRS and HSCSD dial-up connections for your personal computer to connect to the internet or to a corporate network.
The following languages are supported: Danish, German, English, Spanish, French, Italian, Dutch, Norwegian, Finnish, Swedish, Traditional Chinese, Simplified Chinese.
Modem drivers for Sony Ericsson phones.
te vinden op
http://www.sonyericsson.c...SD_V&MN=Drivers&noredir=1
Met een beetje moeite had je die zelf ook best kunnen vinden.
Voor 72% gewijzigd door
stfn345 op 04-11-2003 22:17
