[Ervaringen] nVidia nForce UDP v3.13
  • 35 views sinds 30-01-2008
  • bassGunner
  • Laatst online: 01-12-2024
Ja hoor, eindelijk is hij dan uit, de nieuwe drivers voor alle nVidia nForce-mobo bezitters. Allereerst de release notes:
Release Notes
WHQL certified kit for nForce, nForce2, and nForce3
First release of NVIDIA IDE driver for Windows XP and Windows 2000
General compatibility fixes
Audio Improvements:
Realtek ALC655 codec support added
Fix for BSOD on loading DLS files
Reduced susceptibility to audio glitches under heavy system load; additional fixes for 6 channel GetPosition glitches
ASIO support for recording at sample rates other than 48kHz; lower and more predictable latency
Fixes for NOLF. The 3D minimum and maximum distance and the roll off factor were not being taken into account for air absorption. Also modified reverb gain so that the max distance was taken into account
Fix for EAX reverbs; initialized EAX reverbs to off when querying for the EAX listener interface; updated EAX property handlers to ignore invalid parameters instead of range limiting -- this matches Creative EAX behavior
Windows XP Driver Versions
Audio driver 3.66 (WHQL)
Audio utilities 3.66
Ethernet driver 3.63 (WHQL)
GART driver 3.34 (WHQL)
Memory controller driver 3.38 (WHQL)
SMBus driver 3.38 (WHQL)
IDE In-the-box driver 3.58 (WHQL)
IDE 2.0 NVIDIA driver 3.66 (WHQL)
Display driver 52.16 (WHQL)
Installer 3.77
Windows 2000 Driver Versions
Installer 3.77
Nog enkele installation notes:
If you are performing an uninstall of your current nForce drivers, your system will have to re-enumerate all devices and restart prior to install of your new package. Multiple restarts may be required; please comply with all instructions to reboot. Failure to do so may cause the install to fail the installation of needed components resulting in system reliability issues.
Windows XP users must install Service Pack 1 prior to attempting to install this package. Failure to do so will result in the inability to support USB 2.0.
Audio drivers will not install on the following nForce2 products: Chaintech 7NJS. Please use the drivers that come with these products to enable audio functionality.
En dan natuurlijk de link:
http://www.nvidia.com/object/nforce_udp_winxp_3.13
Draai de drivers nu zo'n 15 minuten, kan er dus nog niet veel over zeggen, behalve dat er zich tot nu toe geen problemen hebben voorgedaan.
Ik heb de drivers gewoon over de oude geen geinstalleerd, er geen problemen van gekregen en ik lees vaak dat dit prima kan.
En ja, beetje korte intro, maar ik heb lichtelijke haast op het moment. :P
[ Voor 3% gewijzigd door bassGunner op 03-11-2003 19:02 ]
  • chucky666
chucky666
d.y.w.play?
een OW voor blaten in de IT? laat IT dan maar voortaan links liggen :(
  • Vincentio
Ook maar even in deze thread:
3 ervaring draadjes van nForceshq.com:
IDE drivers
Audio
Andere dingen over 3.13
  • bassGunner
De site www.nforcershq.com ligt bijna op z'n gat op dit moment, op het Drivers gedeelte van hun forum zitten nu echt gigantisch veel mensen te kijken/posten :+
  • BalusC
BalusC
Carpe diem
Iemand anders heeft wat later een topic gestart: [rml][ Ervaringen] nVidia nForce 3.13 UDP WHQL driver package[/rml]
Aangezien daar meer reacties in staan, sluit ik dit topic maar :)
