[Mandrake 9.2] Problemen met starten van X
  • silentsnake
  • Laatst online: 04-09 18:49
Ik draai een Mandrake 9.2 doos hier (secure versie van de kernel), en als ik startx intik dan krijg ik dit:
[root@node-c-0ab6 root]# startx
Using authority file /root/.Xauthority
Writing authority file /root/.Xauthority
XFree86 Version 4.3.0
Release Date: 9 May 2003
X Protocol Version 11, Revision 0, Release 6.6
Build Operating System: Linux 2.4.18-23mdksmp i686 [ELF]
Build Date: 10 September 2003
        Before reporting problems, check http://www.XFree86.Org/
        to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
         (++) from command line, (!!) notice, (II) informational,
         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/XFree86.0.log", Time: Wed Oct 29 22:35:59 2003
(==) Using config file: "/etc/X11/XF86Config-4"
Using vt 8
giving up.
xinit:  Broken pipe (errno 32):  unable to connect to X server
xinit:  No such process (errno 3):  Server error.
Ga ik naar de XFree86.0.log krijg ik dit:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
(==) ServerLayout "layout1"
(**) |-->Screen "screen1" (0)
(**) |   |-->Monitor "monitor1"
(**) |   |-->Device "device1"
(**) |-->Input Device "Keyboard1"
(**) Option "XkbModel" "pc105"
(**) XKB: model: "pc105"
(**) Option "XkbLayout" "en_US"
(**) XKB: layout: "en_US"
(WW) Option "XkbOptions" requires an string value
(==) Keyboard: CustomKeycode disabled
(**) |-->Input Device "Mouse1"
(**) FontPath set to "unix/:-1"
(==) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(**) Option "AllowMouseOpenFail"
Using vt 8
(--) using VT number 8
(II) Open APM successful
(II) Module ABI versions:
        XFree86 ANSI C Emulation: 0.2
        XFree86 Video Driver: 0.6
        XFree86 XInput driver : 0.4
        XFree86 Server Extension : 0.2
        XFree86 Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
        compiled for 4.3.0, module version = 1.0.0
        Module class: XFree86 Font Renderer
        ABI class: XFree86 Font Renderer, version 0.4
Ik dacht dat het wel handig was om m'n config file ook te posten:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
# File generated by XFdrake.
# Refer to the XF86Config man page for details about the format of
# this file.
Section "Files"
    # Multiple FontPath entries are allowed (they are concatenated together)
    # By default, Mandrake 6.0 and later now use a font server independent of
    # the X server to render fonts.
    FontPath "unix/:-1"
EndSection
Section "ServerFlags"
    AllowMouseOpenFail # allows the server to start up even if the mouse doesn't work
    #DontZoom # disable <Crtl><Alt><KP_+>/<KP_-> (resolution switching)
    #DontZap # disable <Crtl><Alt><BS> (server abort)
EndSection
Section "Module"
    Load "dbe" # Double-Buffering Extension
    Load "v4l" # Video for Linux
    Load "extmod"
    Load "type1"
    Load "freetype"
    Load "glx" # 3D layer
    Load "dri" # direct rendering
EndSection
Section "DRI"
    Mode 0666
EndSection
Section "InputDevice"
    Identifier "Keyboard1"
    Driver "Keyboard"
    Option "XkbOptions" ""
EndSection
    Identifier "Mouse1"
    Driver "mouse"
    Option "Protocol" "PS/2"
    Option "Device" "/dev/psaux"
    Option "Emulate3Buttons"
    Option "Emulate3Timeout" "50"
EndSection
Section "Monitor"
    Identifier "monitor1"
    VendorName "Iiyama"
    ModelName "Iiyama AS4314UT 17inches"
    HorizSync 24.0-80.0
    VertRefresh 56.0-75.0
    # Sony Vaio C1(X,XS,VE,VN)?
    # 1024x480 @ 85.6 Hz, 48 kHz hsync
    ModeLine "1024x480"    65.00 1024 1032 1176 1344   480  488  494  563 -hsync -vsync
    # TV fullscreen mode or DVD fullscreen output.
    # 768x576 @ 79 Hz, 50 kHz hsync
    ModeLine "768x576"     50.00  768  832  846 1000   576  590  595  630
    # 768x576 @ 100 Hz, 61.6 kHz hsync
    ModeLine "768x576"     63.07  768  800  960 1024   576  578  590  616
EndSection
Section "Device"
    Identifier "device1"
    VendorName "3Dfx Interactive, Inc."
    BoardName "Voodoo Banshee (generic)"
    Driver "tdfx"
    Option "DPMS"
EndSection
Section "Screen"
    Identifier "screen1"
    Device "device1"
    Monitor "monitor1"
    DefaultColorDepth 16
    Subsection "Display"
        Depth 8
        Virtual 1024 768
    EndSubsection
        Depth 15
        Virtual 1024 768
    EndSubsection
        Depth 16
        Virtual 1024 768
    EndSubsection
        Depth 24
        Virtual 1024 768
    EndSubsection
EndSection
Section "ServerLayout"
    Identifier "layout1"
    InputDevice "Keyboard1" "CoreKeyboard"
    InputDevice "Mouse1" "CorePointer"
    Screen "screen1"
EndSection
Ik heb zoals je misschien al gezien had een Diamond Monster Fusion, die de Voodoo Banshee chipset gebruikt. Verder wordt m'n monitor ook netjes herkent met de correcte instellingen zoals te zien is. X heeft het wel altijd gedaan tot op een paar dagen geleden. M'n doos stond een paar dagen aan en sinds dien wilt X niet meer opstarten. Nou is het niet zo'n super ramp als X het vertikt aangezien het toch een server is, maar ik zou toch wel graag willen weten wat hier nou precies aan de hand is. Zelf heb ik geen flauw idee wat ik hier aan moet doen. De rest van z'n services draait ie wel netjes (Apache, MySQL, SSH, Webmin enz), en X start ook wel volgens het boot schermpje. Zelf denk ik niet dat het echt aan de instellingen kan liggen aangezien X het wel altijd gedaan heeft. Ik heb ook al een reboot gedaan maar dat hielp ook niet....Ik hoop dat ik genoeg info heb gepost, en als je nog wat anders wilt weten twijfel niet.
Alvast bedankt.
Heb je mischien nog een X sessie openstaan? Je probeert als 'root' X op te starten, mischien is er nog een gebruiker die X open heeft staan?
  • deadinspace
  • Laatst online: 09-09 13:51
deadinspace
The what goes where now?
silentsnake schreef op 29 oktober 2003 @ 22:52:
Secure versie as in? Als ik me niet vergis, dan was het met sommige patches (grsec bv) lastig om XFree86 te draaien.
Probeer anders te testen met 'X' ipv 'startx'. Gezien de error gaat het dan waarschijnlijk nog niet werken, maar hij probeert dan alleen XFree86 te starten, en niet je X session. En hoe minder er gebeurt, hoe makkelijker het is te debuggen.
Wat je ook nog kunt doen is
strace -o strace.log -f X
En dan de input van strace.log (of de laatste ~100 regels) online zetten.
Heb je in die tijd iets veranderd? Nieuwe kernel geinstalleerd wellicht?
  • Paultje3181
  • Laatst online: 09:39
Je start op VT8. Is hier een reden voor? Standaard start je nl. op VT7. Het kan zijn dat je dit ergens verkeerd hebt ingesteld. Of dat iemand anders al op je VT7 zit.
  • silentsnake
Sorry voor de wat late reactie, ik had gister geen tijd om achter de compu te kruipen.
Nee, ik heb helemaal geen X sessie open staan. Als ik ctrl-alt-F7 doe krijg ik gewoon een zwart schermpje.
Als LILO laad dan krijg ik 2 opties (om Linux te booten dan): linux-secure en gewoon linux. Start ik de gewone linux op dan staat internet delen standaard uit. Dit moet ik dan weer opnieuw aanzetten. Ik denk dus dat ie linux-secure gewoon standaard er voor zorgt dat internet delen aanstaat met de nodige beveiliging. Toevallig had ik Mandrake 9.1 op een dual Xeon geinstalleerd en dan maakt ie er standaard linux-enterprise van zodat ie support heeft voor dual-CPU (niet dat dat zo belangrijk is nou).
Dan krijg ik dit:
[root@node-c-0ab6 init.d]# X
(==) Log file: "/var/log/XFree86.0.log", Time: Fri Oct 31 09:26:18 2003
Using vt 8
Killed
[root@node-c-0ab6 /]# strace -o strace.log -f X
(==) Log file: "/var/log/XFree86.0.log", Time: Fri Oct 31 09:13:16 2003
Using vt 7
Nee, het enige wat ik in die tijd heb veranderd is een MySQL backup er overheen gezet vanuit een SQL bestand en wat website inhoud gemaakt. Verder niks. Ik stop de dm (display manager) altijd standaard als ik de doos niet gebruik. Dit in verband met andere zaken. Als ik dm normaal gesproken start dan start X ook altijd automatisch, maar nu gebeurt er gewoon helemaal niks als ik deze start.
Umm...:? Wat is dat? (Ik ben nog niet echt een ervaren Linux gebruiker) Ik draai nog wel eens SSH verbindingen naar m'n doos vanuit me stage, als je dat soms bedoelt. Maar ik laat (geloof ik) nooit geen verbindingen open staan.
Ik hoop dat ik bij deze wat meer info heb kunnen geven.
[ Voor 19% gewijzigd door silentsnake op 31-10-2003 09:30 ]
  • hammerhead
  • Laatst online: 08:21
silentsnake schreef op 31 oktober 2003 @ 09:24:
Using vt 7
Die code had je al laten zien :) Wat je nog even moet neerzetten is de inhoud van de strace.log bestand wat aangemaakt is nadat je dus X hebt geprobeerd op te starten. Daar staat als het goed is wat meer informatie in.
Aviation is proof that given the will, we have the capacity to achieve the impossible.
--Eddie Rickenbacker
  • silentsnake
Die code had je al laten zien Wat je nog even moet neerzetten is de inhoud van de strace.log bestand wat aangemaakt is nadat je dus X hebt geprobeerd op te starten. Daar staat als het goed is wat meer informatie in.
Umm...waar vind ik die precies? Ik heb er wel 1tje in me root folder gevonden maar die is leeg.
En er is wel degelijk een klein verschil. In de 1ste die ik gepost had staat "using vt 8" en bij de 2e staat "using vt 7" Wat het verschil is weet ik ook niet hoor :?
[ Voor 21% gewijzigd door silentsnake op 31-10-2003 09:36 ]
  • Paultje3181
VT8 en VT7 zijn twee verschillende Virtual Terminals. Standaard staat ingesteld dat VT 1 tm 6 voor de terminals zijn en de 7 voor grafisch. Je kunt dan nog extra beeldschermen opengooien (bijv. VT8).
Hier zit volgens mij bij jou de fout... startx probeert op VT8 te starten, maar VT8 is niet aangemaakt en je proces wordt gekilled.
Zoek eens uit waarom er VT8 staat ipv VT7.
Succes iig
Misschien heel erg stom: maar probeer eens CTRL+ALT+F8 en kijk eens wat ie dan doet...
[ Voor 11% gewijzigd door Paultje3181 op 31-10-2003 14:00 ]
Of probeer anders: X -probeonly >& startx.out
Wat staat er in startx.out?
  • silentsnake
@Paultje
Als ik thuis ben zal ik ff kijken...het zou toch niet waar zijn als dat het probleem is...
In ieder geval wel wat geleerd vandaag :)
@ sintaugustinus
startx.out geeft hetzelfde weer als de reply die hammerhead had gegeven (het stuk in het code-venster dan)..alleen staat er vt8 ipv vt7
  • silentsnake
Er draait verder nergens geen vt (heb F7 tot F12 gecheckt)
Ik zal hier m'n running processes ff posten ...misschien dat een belangrijke niet opstart ofzo. Ik heb de processes van MySQL en Apache er ff tussenuit gehaald want ik neem niet aan dat die belangrijk zijn
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
    1 ?        S      0:04 init
    2 ?        SW     0:00 [keventd]
    3 ?        SW     0:00 [kapmd]
    4 ?        SWN    0:00 [ksoftirqd_CPU0]
    5 ?        SW     0:00 [kswapd]
    6 ?        SW     0:00 [bdflush]
    7 ?        SW     0:00 [kupdated]
    8 ?        SW     0:00 [kinoded]
    9 ?        SW<    0:00 [mdrecoveryd]
   13 ?        SW     0:01 [kjournald]
  145 ?        SW     0:00 [khubd]
  275 ?        SW     0:00 [kjournald]
  699 ?        S      0:01 /sbin/ifplugd -w -b -i eth0
  700 ?        SW     0:00 [eth0]
  771 ?        S      0:01 /sbin/ifplugd -w -b -i eth1
  772 ?        SW     0:00 [eth1]
  903 ?        S      0:00 portmap
  917 ?        S      0:02 syslogd -m 0
  925 ?        S      0:00 klogd -2
  980 ?        S      0:00 xfs -port -1 -daemon -droppriv -user xfs
 1598 ?        S      0:00 named -u named
 1599 ?        S      0:00 named -u named
 1607 ?        S      0:00 named -u named
 1608 ?        S      0:00 named -u named
 1609 ?        S      0:00 named -u named
 1622 ?        S      0:00 /usr/sbin/sshd
 1646 ?        S      0:00 xinetd -stayalive -reuse -pidfile /var/run/xinetd.pid
 1661 ?        S      0:00 /usr/sbin/dhcpd -cf /etc/dhcpd.conf -lf /var/lib/dhcp/dhcpd.leases -q eth0
 1733 ?        S      0:02 sendmail: accepting connections
 1749 ?        S      0:00 sendmail: Queue runner@01:00:00 for /var/spool/clientmqueue
 1765 ?        S      0:00 crond
 1813 ?        S      0:01 /usr/bin/perl /usr/libexec/webmin/miniserv.pl /etc/webmin/miniserv.conf
 1829 ?        S      0:00 smbd -D
 1839 ?        S      0:03 nmbd -D
 1999 ?        S      0:00 /usr/bin/perl /usr/sbin/advxsplitlogfile
 2060 ?        S      0:00 login -- jorn
 2061 tty2     S      0:00 /sbin/mingetty tty2
 2062 tty3     S      0:00 /sbin/mingetty tty3
 2063 tty4     S      0:00 /sbin/mingetty tty4
 2064 tty5     S      0:00 /sbin/mingetty tty5
 2065 tty6     S      0:00 /sbin/mingetty tty6
21322 ?        S      0:00 /usr/bin/kdm -nodaemon
21868 tty1     S      0:00 -bash
21938 tty1     S      0:00 su
21939 tty1     S      0:00 bash
21991 ?        S      0:00 sshd: jorn [priv]
21993 ?        S      0:00 sshd: jorn@pts/0
21995 pts/0    S      0:00 -bash
22036 pts/0    S      0:00 su
22040 pts/0    S      0:00 bash
22072 pts/0    R      0:00 ps ax
En dit krijg ik als ik startkde intik:
xset:  unable to open display ":0"
xsetroot:  unable to open display ':0'
xmodmap:  unable to open display ':0'
startkde: Starting up...
ksplash: cannot connect to X server :0
kded: cannot connect to X server :0
ERROR: KUniqueApplication: Registering failed!
ERROR: Communication problem with kded, it probably crashed.
kdeinit: Can't connect to the X Server.
kdeinit: Might not terminate at end of session.
kcminit: cannot connect to X server :0
knotify: cannot connect to X server :0
DCOP aborting call from 'anonymous-22139' to 'knotify'
ERROR: Communication problem with knotify, it probably crashed.
ksmserver: cannot connect to X server :0
startkde: Shutting down...
KLauncher: Exiting on signal 1
startkde: Running shutdown scripts...
startkde: Done.
Tja en verder zou ik het eigenlijk niet weten. Misschien X opnieuw compileren? Als je nog iets wilt weten of een mogelijke suggestie/oplossing heb hoor ik het maar al te graag.
Iig bedankt alvast voor de aandacht :)
[ Voor 16% gewijzigd door silentsnake op 31-10-2003 22:09 ]
  • silentsnake
hmmm
Als ik kded intik krijg ik dit:
FATAL: DCOP communication problem!
Aborted
Ziet er goed uit *ahem*.
[ Voor 19% gewijzigd door silentsnake op 31-10-2003 22:20 ]
  • deadinspace
deadinspace
Hm, ik ken Mandrake niet goed, dus ik weet niet wat ze voor een features in die -secure versie hebben gestopt. Misschien dat de exacte kernel-naam (die kan uname -a je vertellen) wat meer duidelijkheid schept.
Using vt 8
Killed
Killed? Nou wil ik die strace output zeker zien :P
Using vt 7
Strace is een programma dat van een ander programma kan laten zien welke system calls het maakt (en de args en return value daarvan). Dat print hij standaard naar stdout, en als je -o file opgeeft, dan schrijft hij het weg in file. Als je dus 'strace -f X' doet, dan moet je de output geven, en als je 'strace -o strace.log -f X', dan moet je de inhoud van strace.log geven.
Het nadeel van een output file is dat je die weer helemaal moet openen ipv in een keer te zien wat het programma doet, het voordeel is dat de output van het programma en van strace gescheiden zijn, en dat je de output makkelijk kunt bewaren en uitbgebreid bestuderen.
Je hebt dus -o gebruikt, maar die file is leeg zeg je. Is misschien je HD (of in ieder geval een van je partities) vol? Dat zou sowieso veel verklaren ;)
Paultje3181 schreef op 31 oktober 2003 @ 13:58:
Dat zou geen probleem mogen zijn... XFree86 kan op een willekeurige ongebruikte VT draaien, en mag er gewoon overslaan.
silentsnake schreef op 31 oktober 2003 @ 21:47:
enz...
Mja, al die progs kunnen niet connecten met de X server. En da's niks gek, want die wil juist niet starten ;)
Vreemd probleem dit en niets bruikbaars te vinden op Google als je zoekt op errno en xfree. Je zou nog in je xinit.log kunnen kijken ( xinit >& xinit.log) maar voor de rest zou ik het niet weten.
Het enige wat ook maar iets van toepassing is 'http://archive.erdelynet.com/ssh-l/2003-06/msg00100.php'.
Dus verwijder in je /temp de .X11-unix en ...For that reason, any
other user can also do startx. That seems to solve the
problem. So the problem is that the permissions got changed
somehow. I'm pretty sure it happened when I setup sshd......
Succes
nu ga ik lekker even helemaal OT reageren, shame on me :o maar voor 9.2 moest je toch dokken ?
  • silentsnake
Dit is de output: Linux node-c-0ab6.a2000.nl 2.4.22-10mdksecure #1 SMP Thu Sep 18 11:31:52 CEST 2003 i686 unknown unknown GNU/Linux
Deze had ik al eens gepost :) Maar ik zal hem nog een keertje posten:
(==) Log file: "/var/log/XFree86.0.log", Time: Sat Nov  1 18:55:57 2003
Using vt 8
Nee ze zijn niet vol. M'n root partitie zit op 21%,m'n /var/www partitie zit op 2% en m'n home partitie op 5%
Volgens mij heb ik geen xinit.log...ik kan hem nergens vinden. Ook niet met het locate command en als ik daarvoor updatedb intik.
Helaas werkt dit ook niet...
Maar iig bedankt voor al jullie moeite. Ik hoop toch wel dat dit op te lossen is...
nu ga ik lekker even helemaal OT reageren, shame on me maar voor 9.2 moest je toch dokken ?
Wie heeft dat je ooit wijsgemaakt? Mandrake brengt altijd pakketen uit waarvoor je kan betalen en waar je support bij kan krijgen. Je kan ook losse cd's of dvd's kopen als je geen breedband verbinding heb of als je gewoon je favo distributie will supporten :) Mandrake zou net als RedHat en Suse altijd wel gratis download versies uitbrengen, neem ik aan.
[ Voor 13% gewijzigd door silentsnake op 01-11-2003 19:19 ]
  • deadinspace
deadinspace
silentsnake schreef op 01 november 2003 @ 19:16:
Hmm, -10mdksecure. Zegt me verder niks. Maargoed, als Mandrake het erbij heeft geleverd, dan zullen ze vast wel gecontroleerd hebben of het werkt.
Nee, lees de rest van mijn post ook ;)
Het gaat me om wat strace te melden heeft. Als je '-o file' weglaat, dan schrijft hij dat naar het scherm, maar als je '-o file' gebruikt, dan wordt het weggeschreven naar file. Aangezien je '-o strace.log' gebruikte, zou de strace output in strace.log moeten staan.
[/quote]Nee ze zijn niet vol. M'n root partitie zit op 21%,m'n /var/www partitie zit op 2% en m'n home partitie op 5%[/quote]
Dan is het vreemd dat die file leeg is. Probeer het nog eens, als root "strace -o strace.log -f X", en kijk dan of strace.log in de huidige directory leeg is.
  • silentsnake
Nou je zult het niet geloven, maar ik deed een reboot omdat m'n internet was weggevallen en opeens wou X wel weer starten :)
Vraag me niet hoe dat kan, maar wat maakt het uit, hij werkt weer :)
iig allemaal hartelijk bedankt voor al jullie hulp.
