[PC][MMORPG][BETA] FungWan
  • 479 views sinds 30-01-2008
  • Uhmmie
  • Laatst online: 17-10 23:28
Fung Wan Online
Enter into a world of epic adventure, a world where heroes are made and legends are created. From Ma Wing Sing’s magnificent martial arts comic book, we bring you Fung Wan Online. Set against the backdrop of Ancient China, the comic’s famous heroes and villains are brought to life in a fully interactive 3D experience.
In the world of martial arts, Tian Xia (also known as Tin Ha) is the greatest clan. Led by the power hungry Xiong Ba and assisted by his powerful lieutenants Wind and Cloud, Tian Xia has dominated the martial arts world with an iron fist for the last twenty years. All of the other clans were forced to kneel before its supremacy, or to face destruction. Recently, a conflict between Xiong Ba and his two lieutenants, forced Wind and Cloud to flee from Tian Xia and disappear into the wilderness. With the disappearance of Wind and Cloud, the other clans began to grow restless as their fear in Tian Xia falters. Although the clans are not powerful enough to challenge Tian Xia, they await the opportunity to snatch the power long hoarded by Xiong Ba. Old grudges and rivalries flares into open fighting among the clans. Skirmishes have started to break out as each clan begins to maneuver its forces into position. As the unrest amongst the clans grow, other predators begin to turn their eyes towards them. In the northern desert, the Blue Moon Clan has long gathered its power, waiting for the right time to wrest power and land from the clans. To the east, a power hungry dictator, the Godless, leads a band of Japanese warriors in search of conquest. The balance of powers are about to change. It is a time for greatness, a time for heroes and legends.
BETA Subscription
• Als eerste moet je jezelf hier registreren voor de beta..
• Vervolgens ga je hier de beta client downloaden..
• Daarna instaleer je de client en ga je de patches downloaden..
• Vervolgens wordt het wachten tot je je username en password per mail toe gestuurd krijgt..
Maar waar het dan om in deze game?
Net als in bijna iedere andere mmorpg gaat het er in FWO om, om je character steeds verder te ontwikkelen, zodat je je medespelers kunt redden of afslachten (vrij PK systeem).. Om je een klein beeld te geven wat er allemaal mogelijk is heb ik enkele punten uit de beginners guide en de Officieële Site gequote over de punten waarmee je jou character uniek maakt van de rest.. Hiernaast is er nog veel meer mogelijk zoals een zeer uitgebreide guild systeem waardoor je ook weer sterker kunt worden, allerlei soorten magical effecten, etc, etc.. Maar als ik dat allemaal hier ga quoten denk ik dat deze post nogal zeer lang en on overzichtelijk wordt.. Kortom dit is nog lang niet alles :D..
Attributes used in character’s basic builds
Strength
Enables the use of the Saber type weapons
Increases your base damage by 1 damage for every 2 points added.
Increases your defense against the ‘Entanglement’ effect
Increases your total weight allowance by 1 weight for every 2 points added.
Agility
Enables the use of both Staff and Sword type weapons.
Increases your base Defense rating by 1 point for every 2 points added.
Increases your defense against the ‘Slow’ effect.
Acts as a sub increment multiplier in your chances in Blocking of critical attacks.
Constitution
Increases your based Hit Points value for every 5 points added.
Increases your base Hit Points regeneration for every 8 points of constitution.
Increases your defense against the ‘Stun’ effect.
Increase your chances in Blocking of critical attacks.
Mind
Increases your base Chi Points value for every 5 points added.
Increases your base Chi Regeneration value for every 8 points of Mind.
Increases your defense against the ‘Confusion’ effect.
Increases your chances in executing critical attacks.
Perception
Enables the use of both Bow and Sword type weapons.
Increases your base Attack rating by 1 point for every 2 points added.
Increases your defense against the ‘Blind’ effect.
Acts as a sub increment multiplier in your chances in executing critical attacks
The 5 elements
Fung Wan is based on the 5 elements. The 5 elements can consist of offensive attributes or defensive attributes. Offensive attributes are referred to as Elemental based attacks while defensive attributes are referred to as Elemental resistances. You are able to choose your character’s based element during your ‘Character Creation’ process.
The Fire Element
The Fire Element is represented as ‘Red’ colored effects. The opposite of the Fire Element is the Cold Element. A character of the Cold Element has a ‘Weakness’ against the Fire Element. Highest possible resistance attainable for the Fire Element is 75% reduction of damage at 100 Fire Resistance value.
The Cold Element
The Cold Element is represented as ‘Blue’ colored effects. The opposite of the Cold Element is the Fire Element. A character of the Fire Element has a ‘Weakness’ against the Cold Element. Highest possible resistance attainable for the Cold Element is 75% reduction of damage at 100 Cold Resistance value.
The Poison Element
The Poison Element is represented as ‘Green’ colored effects. The opposite of the Poison Element is the Lightning Element. A character of the Poison Element has a ‘Weakness’ against the Lightning Element. Highest possible resistance attainable for the Poison Element is 75% reduction of damage at 100 Poison Resistance value.
The Lightning Element
The Lightning Element is represented as ‘Yellow’ electric colored effects. The opposite of the Lightning Element is the Poison Element. A character of the Lightning Element has a ‘Weakness’ against the Poison Element. Highest possible resistance attainable for the Lighting Element is 75% reduction of damage at 100 Lightning Resistance Value. The Lightning Element also causes the disruption of Chi when inflicted on an opponent.
The Physical Element
The Physical Element is represented as ‘Brownish’ colored effects. The Physical Element is a special Element. It has weakness against all other Elements but it also inflicts more damage against all the other Elements. A character of the Physical Element has ‘Weakness’ against all 4 other Elements. However he has resistance against Physical based attacks, which inflicts the most damage. Highest possible resistance attainable for the Physical Element is 50% reduction of damage at 100 Physical Resistance Value. Resistance against the Physical Element is vital in Melee combats.
Skill System
Fung Wan Online features a Skills System which will allow you to determine what kind of character you are to build in terms of supporting your overall built. You can choose to be a forger, a brewer, a crafter or a more combat focus character with some other skills.
When creating a new character, you must select 3 skills. Sprinting is given to your PC by default. To possess additional skills, your PC can purchase them from trainers (merchant NPC) from villages at any game levels.
In order to use the skills, either a) right-click on the skill icons in the Skill Window, or b) left-click to transfer the icon to a quick slot. You can also activate the skills by right clicking on the skill icons.
There are 11 skills that you can learn in the game. Each of these skills have their own advantages and it is your choice in how you are to build your character accordingly. Skills do not effect your character’s base attributes or stats.
Resuscitate
This skill enables you to resuscitate a fellow fallen player. For every 1 ranking allocated to this skill, a duration of 6 seconds is increased accordingly.
Identify item
This skill enables you to identify items found or dropped by creatures. Items found are always ‘Unidentified’. This skill will enable you to identify the items without a cost. Your identify skill must be of the same level as the item in order for the item to be identified.
Evaluate opponent
This skill enables you to ‘Evaluate’ your opponents. Similar to the ‘Evaluate’ menu, you will be able to evaluate details stats of your opponent. The higher your evaluate skills, the more details you will be able to evaluate.
Stealth/prowl
This skill will enable you to go into ‘prowl’ or ‘invisible’ mode. This will allow you to avoid the hostile creatures from attacking you. The higher your Prowl skill, the higher your chances of evading hostile creatures. You cannot participate in any combats during ‘Prowl’. You can only walk or stand still while in ‘Prowl’ mode. Chi will constantly be used during ‘Prowl’ mode.
Detect hidden
This skill will enable you to ‘Detect’ hidden PCs with the ‘Prowl’ skill. Mainly used only in Player Vs Player combats. You will require the same or higher skills to detect another player with the same skills in ‘Prowl’. Chi will constantly be used during ‘Detect’ mode.
Pickpocket
This skill will allow you to ‘Pickpocket’ another creature or player. Pick pocking will allow you to steal certain items from creatures and whatever items the other player have in his / her inventory. You can only Pickpocket at a range of 5meters and it will take a duration of 6seconds. Should you be successful, the victim will only realize it after 1minute prior to the pickpocket. Should you fail, the victim will be immediately notified with the pickpocket’s name. The higher your skills, the higher the chances in pick pocketing.
Sprinting
This skill will enable you to travel the lands of Fung Wan at a faster pace. The higher your skill in ‘Sprinting’, the faster you can sprint. During ‘Sprinting’, Chi will constantly be used.
Weapon Forging
This skill will enable you to forge weapon components into weapons so as to empower them.
For every 21 skills, you will be able to forge up to 2 component weapons
For every 41 skills, you will be able to forge up to 3 components weapons
For every 61 skills, you will be able to forge up to 4 components weapons
For every 81 skills, you will be able to forge up to 5 components weapons
You can purchase weapon components from Blacksmiths or certain weapon sellers. In order to forge a weapon higher than level 81, you will require more than 81 ranking to the Weapon Forging skill. There is no 100% success rate in forging of weapons. The higher the components, the more the components, the lower the success rate for a perfect forge.
Brewing Medicine
This skill will enable you to brew special medicines which regular merchants do not sell. The more herbs combined, the stronger the medicine. You will be able to obtain formulas or recipes of different herb combinations by means of special ‘Recipe Scrolls’ dropped by creatures. You can purge herbs from Doctors.
Crafting Jewelry
This skill will enable you to craft special jewelries such as amulets and rings which regular merchants do not sell. The more jewelry components combined, the more powerful the jewelry. You will be able to obtain formulas or techniques of different component combinations by means of special ‘Technique Scrolls’ dropped by creatures. You can purchase Jewelry components from Tailors.
Crafting Wearable
This skill will enable you to craft special wearable items such as greaves and bracers which regular merchants do not sell. The more wearable components combined, the more powerful the wearable. You will be able to obtain formulas or techniques of different component combinations by means of special ‘Technique Scrolls’ dropped by creatures. You can purchase Wearable components from Tailors.
Taunt
This skill acts like a lure for creatures. Should you use it, there will be a high probability that the creature which you use the skill on will turn against you.
A short introduction for each stance
This is a basic description of the characteristics of each stances and how they were designed and meant to be.
The Saber Stance
- Features the most damage inflicted by melee attacks.
- Features the most damage enhancing buffs
- Uses Berserk as both and offensive and defensive ability
- More of a single hitting stance
Recomended Attributes:
Strength(Required)
Constitution
Mind
The Sword Stance
- Features the most powerful resistance debuff powers of 3 different elements
- Features the most offensive Chi element attacks, master of the Chi element.
- Features a mix of between power and technical built.
Agility(Required)
Perception(Required)
Constitution
Strength
Sub Mind
The Staff Stance
- Known as the power base stance, master of powers
- Features the highest Defense Rating
- Features very offensive powers
Agility(Required)
Mind
Constitution
Perception
Unarm
- Features the ultimate healing power
- Features the best debuff powers of both Attack Rating and Defense Rating
- A very technical stance, has also a mixed on a range of attacking powers
<Free for all>
Strength
Mind
Constitution
Balanced for both Agility and Perception
The Bow Stance
- Master of ranged attacks
- Powers with ranged attacks
- Has very powerful technical ranged attack powers.
Mind
Constitution
[ Voor 75% gewijzigd door Uhmmie op 25-10-2003 06:45 ]
Currently playing: MTG Arena (PC)
  • Uhmmie
Nou ik hoop dat ik zo een paar mede tweakers warm heb laten lopen voor deze game en dat het er net zo gezellig als in de lineage2 beta gaat worden :)..
Voor mijn gevoel gaat deze game het meeste richting DAoC, maar waarbij er veel beter is na gedacht over het magic systeem.. Door CC spells beter in elkaar te zetten (stun zorgt er bijvoorbeeld alleen maar voor dat je niet terug kan vechten, maar je kan nog wel gewoon naar vrienden terug rennen).. Daarnaast zijn je resistance gebaseerd op de ontwikkeling van je char zoals je hierboven kan zien.. Daarnaast kan je voor mij gevoel je character veel unieker in elkaar zetten.. But then again ik heb alle info van de officieële site en forums.. En ik ken er wel uren over door lullen maar ik wacht eerst wel even mijn eerste ervaringen af..
[ Voor 121% gewijzigd door Uhmmie op 25-10-2003 07:07 ]
  • intuliegend
  • Laatst online: 15-04-2024
intuliegend
Wist ik wel....
hmmmm heb net even op de site gekeken maar de graphics komen echt niet in de buurt van lineage 2...
beetje achterhaald zelfs..
kan natuurlijk niet oordelen over het spel zelf maar graphics vind ik toch wel belangrijk ...
specs: AMD 8 core+Cryorig Ultimate @ 5,2Ghz - 16GB - 2x R9 290 met wc - HyperX Fury SSD - 2x1TB Raid1
  • Loona35
  • Laatst online: 22-10 18:34
ik vind het er erg saai uitzien
/edit
is hier niet al eens een beta van geweest toevallig? ik heb al eens iets met Fung nog wat online zitten testen, dat was toen zwaar bagger.
[ Voor 82% gewijzigd door Loona35 op 25-10-2003 10:14 ]
  • White Dust
  • Laatst online: 22-09 10:04
White Dust
PlaneScape: Torment
Er is al een draadje over Fung Wan: [rml]Fung Wan Online [ MMORPG][/rml] ;)
Ga daar maar verder :)
