Acer TM803LCi of Toshiba Satellite M30 ???
  • 171 views sinds 30-01-2008
  • frederick684
  • Laatst online: 21-11-2022
Prijs maakt me niet uit(verschillen toch beiden niet veel) maar qua specifikaties toch nog enkele verschillen...
Satellite M30:
Intel Pentium M - 1.4 GHz, 1 MB cache, 400 MHz PSB
512 (2x256) - 2048 MB DDR RAM
40 GB HDD
15.4" TFT (1280x800, WXGA 16:10) colour screen
nVidia GeForce FX Go5200 with 64 MB DDR
Integrated DVD-R/RW, optional USB FDD
DVD-R/RW compatibility: CD-ROM, CD-R/RW, DVD-ROM, DVD-R/RW
Up to 3:51 hr (Li-Ion)
56 kbps modem (V.90)
Touchpad, 1 x PC Card (CB)
Harmon-Kardon Stereo Sound System
3*USB 2.0, TV-out (S-video), parallel, iLink, SD, 1x FIR, no serial, no PS/2
Integrated 10/100 ethernet LAN (RJ45)
360 x 270 x 25/36 mm, 2.8 kg, sleek silver
Integrated Intel PRO/Wireless 2100 (802.11b)
Windows® XP Home Edition triple language (UK, NL, FR)
ConfigFree, Intervideo WinDVD, Drag 'n Drop
2 years pickup & return warranty
ik vraag me vooral af wat de verschillen zijn in videokaart, en ook met dat 15.4inch scherm van de toshiba...is dat goed/tof/merkbaar ???
alvast bedankt voor enige reacties!!!
Acer TravelMate 803LCib Centrino 1,6Ghz 40GB 512MB DVD/CDRW 15"TFT W-LAN Bluetooth WXP Prof
Intel® Centrino™ mobile technology
Intel® Mobile Pentium® 4-M processor 1,6Ghz
1024KB L2 Cache, integrated on chip
Intel® 855PM chipset
400 Mhz Front Side Bus
15" TFT color display
Max. resolution 1400x1050 16.7M colors
ATI® Mobility Radeon 9000® , dedicated 64MB DDR video memory (TM634)
Simultaneous LCD & CRT display, DualView support
512 MB DDR-266 SDRAM (2* 256MB)
40GB HDD
max. 2048 MB on Dual soDIMM sockets
Internal DVD&CDRW combo
External USB FDD or AcerMedia bay FDD (both optional)
Smart Card Reader incl. 2x smartcard
Internal 56 Kbps modem, Ethernet 10/100 LAN
Integrated Acer Invilink wireless solution 802.11a+b dual band & Bluetooth
SoundBlaster-Pro and MS DirectSound-compatible with 3D audio system with two speakers
S-video out, Firewire (IEEE-1394), 1x PC Card slot, 4x USB 2.0,
1x FIR, 1x parallel EPP/ECP complient, 1x 100pin docking port
Ergonomic keyboard with EURO-key
ACPI 2.0 compliant
Li-ion batt.pack; 70Watt AC adapter
Norton AntiVirus™ (90Days trail), CyberLink® PowerDVD
Acer Notebook Manager, NTI® CD Maker™
Operating system: Microsoft® Windows XP Professional NL version
Dimensions: 33,0 (b) x 27,2 (d) x 2,95 (h) cm
Weight 2.69Kg 15" LCD
Optional: EasyDock portreplicator or I/O replicator serial cable
  • TERW_DAN
TERW_DAN
Met een hamer past alles.
Welke notebook voor jou het beste is moet je toch zelf bepalen. (zie ook de FAQ)
iig een paar hints.
dat 15.4" scherm is breedbeeld. Op zich best leuk (tenzij er iemand als Pollewob in de buurt is :+)
Verder zou je even moeten kijken hoe het zit met het videogeheugen, die acer heeft het iig dedicated, maar bij die andere staat het niet bij.
die Acer heeft ook een portreplicator, kan makkelijk zijn als je dit verwacht nodig te gaan hebben.
  • frederick684
Ennuh... wat mag een portreplicator dan wel zijn??? :s:s:S
  • squaddie
  • Laatst online: 18:37
frederick schreef op 23 oktober 2003 @ 14:33:
Die repliceert je poorten ;) Grof gezegt een ander woord voor dockingstation.
Samenvattend dan hoef je niet telkens je randapparatuur zoals muis, toetsenbord, beeldscherm en printer in je laptop te pluggen want die zitten aan dat kastje geknoopt en met een klik is de laptop aangesloten.
There are never enough hours in a day, but always too many days before saturday.
  • Delerium
Delerium
Mythology
frederick schreef op 23 October 2003 @ 14:33:
Een uitbreiding die in het wild nog nooit is waargenomen.
De Acer heeft een snellere CPU en GPU en is 100 gram lichter (boejuh ei'k). Ook qua afmetingen is de Acer net ff iets gunstiger. Aangezien de Acer zo'n hit lijkt te zijn, zou ik persoonlijk de Acer meenemen.
  • Pollewob
Je hebt de specs, zoek een review en weeg af welke punten jij belangrijk vind. Aan de hand daarvan kan je voor jezelf bepalen welke laptop de beste keus voor jou is :)
