[mandrake] probleem met tvout
  • 63 views sinds 30-01-2008
  • peligro2k
  • Laatst online: 22:02
hallo, ik heb mijn xfree config file geedit zodat ik mn tvout kan gebruiken, maar nu als ik opstart gaat mn monitor uit, en heb ik ook geen beeld op de tv.
Hier is mijn config:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
# Refer to the XF86Config(4/5) man page for details about the format of
# this file.
Section "Files"
    RgbPath     "/usr/X11R6/lib/X11/rgb"
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, Mandrake 6.0 and later now use a font server independent of
# the X server to render fonts.
    FontPath   "unix/:-1"
EndSection
# Server flags section.
Section "ServerFlags"
    # Uncomment this to cause a core dump at the spot where a signal is
    # received.  This may leave the console in an unusable state, but may
    # provide a better stack trace in the core dump to aid in debugging
    #NoTrapSignals
    # Uncomment this to disable the <Crtl><Alt><BS> server abort sequence
    # This allows clients to receive this key event.
    #DontZap
    # Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching
    # sequences.  This allows clients to receive these key events.
    #DontZoom
    # This  allows  the  server  to start up even if the
    # mouse device can't be opened/initialised.
    AllowMouseOpenFail
EndSection
# Input devices
# Keyboard section
Section "InputDevice"
    Identifier "Keyboard1"
    Driver "Keyboard"
    Option "XkbModel" "pc105"
    Option "XkbLayout" "us_intl"
    Option "XkbCompat" ""
    Option "XkbOptions" ""
EndSection
# Pointer section
    Identifier "Mouse1"
    Driver "mouse"
    Option "Protocol" "Microsoft"
    Option "Device" "/dev/ttyS0"
EndSection
Section "Module"
# This loads the DBE extension module.
    Load        "dbe"
    Load        "glx"
    Load        "v4l"
#   Load        "xv"
# This loads the miscellaneous extensions module, and disables
# initialisation of the XFree86-DGA extension within that module.
#    SubSection "extmod"
        #Option "omit xfree86-dga"
#    EndSubSection
   Load        "extmod"
# This loads the Type1 and FreeType font modules
    Load        "type1"
    Load        "freetype"
EndSection
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
    Identifier "monitor1"
    VendorName "Generic"
    ModelName "1024x768 @ 70 Hz"
    HorizSync 31.5-57.0
    VertRefresh 50-70
    # Sony Vaio C1(X,XS,VE,VN)?
    # 1024x480 @ 85.6 Hz, 48 kHz hsync
    ModeLine "1024x480"    65.00 1024 1032 1176 1344   480  488  494  563 -hsync -vsync
    # TV fullscreen mode or DVD fullscreen output.
    # 768x576 @ 79 Hz, 50 kHz hsync
    ModeLine "768x576"     50.00  768  832  846 1000   576  590  595  630
    # 768x576 @ 100 Hz, 61.6 kHz hsync
    ModeLine "768x576"     63.07  768  800  960 1024   576  578  590  616
EndSection
Section "Monitor"
    Identifier "TV"
    VendorName "Philips"
    ModelName  "Unknown"
    HorizSync   30-50.0
    VertRefresh 60
EndSection
# Graphics device section
Section "Device"
Identifier "Card1"
Driver      "nvidia"
VendorName  "nVidia Corporation"
BoardName   "[GeForce5200]"
BusID       "PCI:1:0:0"
Option "NvAGP" "3"
Option "CursorShadow" "1"
Option "CursorShadowAlpha" "64"
Option "CursorShadowYOffset" "2"
Option "CursorShadowXOffset" "4"
Option "NoLogo" "0"
Option "DigitalVibrance" "100"
Option "TwinView" "1"
Option "SecondMonitorHorizSync" "30-69"
Option "SecondMonitorVertRefresh" "50-120"
Option "TwinViewOrientation" "RightOf"
Option "ConnectedMonitor" "crt,tv"
Option "TVOutFormat" "COMPOSITE"
Option "TVStandard" "PAL-B"
Option "MetaModes" "1280x1024@1280x1024,1280x1024@1280x1024;800x600@800x600,x@x"
EndSection
# Screen sections
Section "Screen"
    Device "Card1"
    Monitor "monitor1"
    DefaultColorDepth 24
    Subsection "Display"
        Depth 8
        Modes "1024x768" "800x600" "640x480"
    EndSubsection
        Depth 15
    EndSubsection
        Depth 16
    EndSubsection
        Depth 24
    EndSubsection
EndSection
Section "Screen"
    Identifier "TV"
    Device      "Card1"
    Monitor     "TV"
    DefaultColorDepth 16
        Depth       16
        Modes       "640x480"
        ViewPort    0 0
    EndSubsection
EndSection
Section "ServerLayout"
        Identifier "All"
        Screen "monitor1"
        Screen "TV" Leftof "monitor1"
    InputDevice "Mouse1" "CorePointer"
        InputDevice "Keyboard1" "CoreKeyboard"
EndSection
  • peligro2k
mn xfree log:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
527
528
529
530
531
532
533
534
535
536
537
538
539
540
541
542
543
544
545
546
547
548
549
550
551
552
553
554
555
556
557
558
559
560
561
562
563
564
565
566
567
568
569
570
571
572
573
574
575
576
577
578
579
580
581
582
583
584
585
586
587
588
589
590
591
592
593
594
595
596
597
598
599
600
601
602
603
604
605
606
607
608
609
610
611
612
613
614
615
616
617
618
619
620
621
XFree86 Version 4.3.0
Release Date: 27 February 2003
X Protocol Version 11, Revision 0, Release 6.6
Build Operating System: Linux 2.4.21-0.13mdksmp i686 [ELF]
Build Date: 12 March 2003
    Before reporting problems, check http://www.XFree86.Org/
    to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
         (++) from command line, (!!) notice, (II) informational,
         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/XFree86.0.log", Time: Thu Oct 16 16:21:32 2003
(==) Using config file: "/etc/X11/XF86Config-4"
(==) ServerLayout "All"
(**) |-->Screen "monitor1" (0)
(**) |   |-->Monitor "monitor1"
(**) |   |-->Device "Card1"
(**) |-->Screen "TV" (1)
(**) |   |-->Monitor "TV"
(**) |-->Input Device "Mouse1"
(**) |-->Input Device "Keyboard1"
(WW) Option "XkbCompat" requires an string value
(**) Option "XkbModel" "pc105"
(**) XKB: model: "pc105"
(**) Option "XkbLayout" "us_intl"
(**) XKB: layout: "us_intl"
(WW) Option "XkbOptions" requires an string value
(==) Keyboard: CustomKeycode disabled
(**) FontPath set to "unix/:-1"
(**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(**) Option "AllowMouseOpenFail"
Using vt 7
(--) using VT number 7
(II) Open APM successful
(II) Module ABI versions:
    XFree86 ANSI C Emulation: 0.2
    XFree86 Video Driver: 0.6
    XFree86 XInput driver : 0.4
    XFree86 Server Extension : 0.2
    XFree86 Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
    compiled for 4.3.0, module version = 1.0.0
    Module class: XFree86 Font Renderer
    ABI class: XFree86 Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
    ABI class: XFree86 Video Driver, version 0.6
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x80003c50, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1106,0305 card 1458,0000 rev 03 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 1106,8305 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:07:0: chip 1106,0686 card 1106,0686 rev 40 class 06,01,00 hdr 80
(II) PCI: 00:07:1: chip 1106,0571 card 1106,0571 rev 06 class 01,01,8a hdr 00
(II) PCI: 00:07:2: chip 1106,3038 card 0925,1234 rev 1a class 0c,03,00 hdr 00
(II) PCI: 00:07:3: chip 1106,3038 card 0925,1234 rev 1a class 0c,03,00 hdr 00
(II) PCI: 00:07:4: chip 1106,3057 card 1458,0000 rev 40 class 0c,05,00 hdr 00
(II) PCI: 00:07:5: chip 1106,3058 card 1458,a002 rev 50 class 04,01,00 hdr 00
(II) PCI: 00:0c:0: chip 1131,7134 card 1461,a70b rev 01 class 04,80,00 hdr 00
(II) PCI: 00:0d:0: chip 10ec,8029 card 10ec,8029 rev 00 class 02,00,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0253 card 17f2,8007 rev a2 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
    [0] -1  0   0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
    [0] -1  0   0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 1 I/O range:
    [0] -1  0   0x00009000 - 0x00009fff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
    [0] -1  0   0xdde00000 - 0xdfefffff (0x2100000) MX[B]
(II) Bus 1 prefetchable memory range:
    [0] -1  0   0xcdb00000 - 0xddcfffff (0x10200000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:7:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) nVidia Corporation NV25 [GeForce4 Ti 4200] rev 162, Mem @ 0xde000000/24, 0xd0000000/27, 0xddc80000/19, BIOS @ 0xdfee0000/17
(II) Addressable bus resource ranges are
    [1] -1  0   0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
    [0] -1  0   0xffe00000 - 0xffffffff (0x200000) MX[B](B)
    [1] -1  0   0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
    [2] -1  0   0x000f0000 - 0x000fffff (0x10000) MX[B]
    [3] -1  0   0x000c0000 - 0x000effff (0x30000) MX[B]
    [4] -1  0   0x00000000 - 0x0009ffff (0xa0000) MX[B]
    [5] -1  0   0x0000ffff - 0x0000ffff (0x1) IX[B]
    [6] -1  0   0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xe0000000 from 0xe3ffffff to 0xdfffffff
(II) Active PCI resource ranges:
    [0] -1  0   0xdffffc00 - 0xdfffffff (0x400) MX[B]
    [1] -1  0   0xe0000000 - 0xdfffffff (0x0) MX[B]O
    [2] -1  0   0xdfee0000 - 0xdfefffff (0x20000) MX[B](B)
    [3] -1  0   0xddc80000 - 0xddcfffff (0x80000) MX[B](B)
    [4] -1  0   0xd0000000 - 0xd7ffffff (0x8000000) MX[B](B)
    [5] -1  0   0xde000000 - 0xdeffffff (0x1000000) MX[B](B)
    [6] -1  0   0x0000c800 - 0x0000c81f (0x20) IX[B]
    [7] -1  0   0x0000d400 - 0x0000d403 (0x4) IX[B]
    [8] -1  0   0x0000d800 - 0x0000d803 (0x4) IX[B]
    [9] -1  0   0x0000dc00 - 0x0000dcff (0x100) IX[B]
    [10] -1 0   0x0000d000 - 0x0000d01f (0x20) IX[B]
    [11] -1 0   0x0000cc00 - 0x0000cc1f (0x20) IX[B]
    [12] -1 0   0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
    [5] -1  0   0xdffffc00 - 0xdfffffff (0x400) MX[B]
    [6] -1  0   0xe0000000 - 0xdfffffff (0x0) MX[B]O
    [7] -1  0   0xdfee0000 - 0xdfefffff (0x20000) MX[B](B)
    [8] -1  0   0xddc80000 - 0xddcfffff (0x80000) MX[B](B)
    [9] -1  0   0xd0000000 - 0xd7ffffff (0x8000000) MX[B](B)
    [10] -1 0   0xde000000 - 0xdeffffff (0x1000000) MX[B](B)
    [11] -1 0   0x0000ffff - 0x0000ffff (0x1) IX[B]
    [12] -1 0   0x00000000 - 0x000000ff (0x100) IX[B]
    [13] -1 0   0x0000c800 - 0x0000c81f (0x20) IX[B]
    [14] -1 0   0x0000d400 - 0x0000d403 (0x4) IX[B]
    [15] -1 0   0x0000d800 - 0x0000d803 (0x4) IX[B]
    [16] -1 0   0x0000dc00 - 0x0000dcff (0x100) IX[B]
    [17] -1 0   0x0000d000 - 0x0000d01f (0x20) IX[B]
    [18] -1 0   0x0000cc00 - 0x0000cc1f (0x20) IX[B]
    [19] -1 0   0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
    Module class: XFree86 Server Extension
    ABI class: XFree86 Server Extension, version 0.2
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "glx"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
    compiled for 4.0.2, module version = 1.0.4496
    ABI class: XFree86 Server Extension, version 0.1
(II) Loading extension GLX
(II) LoadModule: "v4l"
(II) Loading /usr/X11R6/lib/modules/drivers/linux/v4l_drv.o
(II) Module v4l: vendor="The XFree86 Project"
    compiled for 4.3.0, module version = 0.0.1
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension FontCache
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
    compiled for 4.3.0, module version = 1.0.2
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
    compiled for 4.3.0, module version = 2.0.2
(II) Loading font FreeType
(II) LoadModule: "nvidia"
(II) Loading /usr/X11R6/lib/modules/drivers/nvidia_drv.o
(II) Module nvidia: vendor="NVIDIA Corporation"
    Module class: XFree86 Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
    Module class: XFree86 XInput Driver
    ABI class: XFree86 XInput driver, version 0.4
(II) v4l driver for Video4Linux
(II) NVIDIA XFree86 Driver  1.0-4496  Wed Jul 16 19:06:03 PDT 2003
(II) NVIDIA Unified Driver for all NVIDIA GPUs
(II) Primary Device is: PCI 01:00:0
(WW) NVIDIA: More than one matching Device section for instances
    (BusID: PCI:1:0:0) found: Card1
(--) Chipset NVIDIA GPU found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
    [11] 0  0   0x000a0000 - 0x000affff (0x10000) MS[B]
    [12] 0  0   0x000b0000 - 0x000b7fff (0x8000) MS[B]
    [13] 0  0   0x000b8000 - 0x000bffff (0x8000) MS[B]
    [14] -1 0   0x0000ffff - 0x0000ffff (0x1) IX[B]
    [15] -1 0   0x00000000 - 0x000000ff (0x100) IX[B]
    [16] -1 0   0x0000c800 - 0x0000c81f (0x20) IX[B]
    [17] -1 0   0x0000d400 - 0x0000d403 (0x4) IX[B]
    [18] -1 0   0x0000d800 - 0x0000d803 (0x4) IX[B]
    [19] -1 0   0x0000dc00 - 0x0000dcff (0x100) IX[B]
    [20] -1 0   0x0000d000 - 0x0000d01f (0x20) IX[B]
    [21] -1 0   0x0000cc00 - 0x0000cc1f (0x20) IX[B]
    [22] -1 0   0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
    [23] 0  0   0x000003b0 - 0x000003bb (0xc) IS[B]
    [24] 0  0   0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/X11R6/lib/modules/libvgahw.a
(II) Module vgahw: vendor="The XFree86 Project"
    compiled for 4.3.0, module version = 0.1.0
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Option "DigitalVibrance" "100"
(**) NVIDIA(0): Option "NoLogo" "0"
(**) NVIDIA(0): Option "NvAGP" "3"
(**) NVIDIA(0): Option "ConnectedMonitor" "crt,tv"
(**) NVIDIA(0): Option "TVStandard" "PAL-B"
(**) NVIDIA(0): Option "TVOutFormat" "COMPOSITE"
(**) NVIDIA(0): Option "CursorShadow" "1"
(**) NVIDIA(0): Option "CursorShadowAlpha" "64"
(**) NVIDIA(0): Option "CursorShadowXOffset" "4"
(**) NVIDIA(0): Option "CursorShadowYOffset" "2"
(**) NVIDIA(0): Option "TwinView" "1"
(**) NVIDIA(0): Option "TwinViewOrientation" "RightOf"
(**) NVIDIA(0): Option "SecondMonitorHorizSync" "30-69"
(**) NVIDIA(0): Option "SecondMonitorVertRefresh" "50-120"
(**) NVIDIA(0): Option "MetaModes" "1280x1024@1280x1024,1280x1024@1280x1024;800x600@800x600,x@x"
(**) NVIDIA(0): Forcing COMPOSITE video output
(**) NVIDIA(0): Enabling cursor shadow
(**) NVIDIA(0): Cursor shadow alpha = 64
(**) NVIDIA(0): Cursor shadow offset = 4
(**) NVIDIA(0): Cursor shadow offset = 2
(**) NVIDIA(0): Use of any AGP requested (try AGPGART, then try NVIDIA's AGP)
(**) NVIDIA(0): ConnectedMonitor string: "crt,tv"
(**) NVIDIA(0): TV Standard string: "PAL-B"
(**) NVIDIA(0): TwinView enabled
(--) NVIDIA(0): Linear framebuffer at 0xD0000000
(--) NVIDIA(0): MMIO registers at 0xDE000000
(II) NVIDIA(0): NVIDIA GPU detected as: GeForce4 Ti 4200
(--) NVIDIA(0): VideoBIOS: 04.25.00.30.00
(--) NVIDIA(0): VideoRAM: 131072 kBytes
(II) NVIDIA(0): Using ConnectedMonitor string "CRT-0, TV-0"
(--) NVIDIA(0): Detected TV Encoder: Brooktree 871
(--) NVIDIA(0): Display device CRT-0: maximum pixel clock at  8 bpp: 350 MHz
(--) NVIDIA(0): Display device CRT-0: maximum pixel clock at 16 bpp: 350 MHz
(--) NVIDIA(0): Display device CRT-0: maximum pixel clock at 32 bpp: 350 MHz
(--) NVIDIA(0): Display device TV-0: maximum pixel clock at  8 bpp: 350 MHz
(--) NVIDIA(0): Display device TV-0: maximum pixel clock at 16 bpp: 350 MHz
(--) NVIDIA(0): Display device TV-0: maximum pixel clock at 32 bpp: 350 MHz
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="The XFree86 Project"
(WW) NVIDIA(0): Failure reading EDID parameters for display device CRT-0
(WW) NVIDIA(0): Failure reading EDID parameters for display device TV-0
(**) NVIDIA(0): Digital Vibrance for display 0 set to 100
(**) NVIDIA(0): Digital Vibrance for display 1 set to 100
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/X11R6/lib/modules/linux/libint10.a
(II) Module int10: vendor="The XFree86 Project"
(II) NVIDIA(0): Primary V_BIOS segment is: 0xc000
(WW) NVIDIA(0): Error while parsing panning domain in mode description "x@x"
(II) NVIDIA(0): monitor1: Using hsync range of 31.50-57.00 kHz
(II) NVIDIA(0): monitor1: Using vrefresh range of 50.00-70.00 Hz
(II) NVIDIA(0): Clock range:  12.00 to 350.00 MHz
(II) NVIDIA(0): Not using mode "1024x480" (vrefresh out of range)
(II) NVIDIA(0): Not using mode "768x576" (vrefresh out of range)
(II) NVIDIA(0): Not using mode "768x576" (hsync out of range)
(II) NVIDIA(0): Not using default mode "640x350" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "320x175" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "640x400" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "320x200" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "720x400" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "360x200" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "640x480" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "320x240" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "800x600" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "400x300" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "1024x768" (bad mode clock/interlace/doublescan)
(II) NVIDIA(0): Not using default mode "512x384" (bad mode clock/interlace/doublescan)
(II) NVIDIA(0): Not using default mode "1024x768" (hsync out of range)
(II) NVIDIA(0): Not using default mode "512x384" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1152x864" (hsync out of range)
(II) NVIDIA(0): Not using default mode "576x432" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1280x960" (hsync out of range)
(II) NVIDIA(0): Not using default mode "640x480" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1280x1024" (hsync out of range)
(II) NVIDIA(0): Not using default mode "640x512" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1600x1200" (hsync out of range)
(II) NVIDIA(0): Not using default mode "800x600" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1792x1344" (hsync out of range)
(II) NVIDIA(0): Not using default mode "896x672" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1856x1392" (hsync out of range)
(II) NVIDIA(0): Not using default mode "928x696" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1920x1440" (hsync out of range)
(II) NVIDIA(0): Not using default mode "960x720" (hsync out of range)
(II) NVIDIA(0): Not using default mode "832x624" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "416x312" (vrefresh out of range)
(II) NVIDIA(0): Not using default mode "1400x1050" (hsync out of range)
(II) NVIDIA(0): Not using default mode "700x525" (hsync out of range)
(II) NVIDIA(0): Not using default mode "1600x1024" (hsync out of range)
(II) NVIDIA(0): Not using default mode "800x512" (hsync out of range)
(II) NVIDIA(0): Not using default mode "2048x1536" (hsync out of range)
(II) NVIDIA(0): Not using default mode "2048x1536" (bad mode clock/interlace/doublescan)
(II) NVIDIA(0): Not using mode "1280x1024" (no mode of this name)
(II) NVIDIA(0): Not using default mode "1152x768" (width too large for virtual size)
(II) NVIDIA(0): Not using default mode "1024x768" (width too large for virtual size)
(WW) NVIDIA(0): Not using mode "576x384":
(WW) NVIDIA(0):   horizontal sync start (589) not a multiple of 8
(**) NVIDIA(0): Validated modes for display device CRT-0:
(**) NVIDIA(0):      Default mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
(**) NVIDIA(0):      Default mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz
(**) NVIDIA(0):      Default mode "640x480": 25.2 MHz, 31.5 kHz, 60.0 Hz
(**) NVIDIA(0):      Default mode "512x384": 37.5 MHz, 56.5 kHz, 70.1 Hz (D)
(**) NVIDIA(0):      Default mode "512x384": 32.5 MHz, 48.4 kHz, 60.0 Hz (D)
(**) NVIDIA(0):      Default mode "400x300": 20.0 MHz, 37.9 kHz, 60.3 Hz (D)
(**) NVIDIA(0):      Default mode "400x300": 18.0 MHz, 35.2 kHz, 56.3 Hz (D)
(**) NVIDIA(0):      Default mode "320x240": 12.6 MHz, 31.5 kHz, 60.1 Hz (D)
(II) NVIDIA(0): monitor1: Using hsync range of 30.00-69.00 kHz
(II) NVIDIA(0): monitor1: Using vrefresh range of 50.00-120.00 Hz
(II) NVIDIA(0): Not using default mode "1400x1050" (width too large for virtual size)
(WW) NVIDIA(0): Not using mode "1280x1024" (not a valid TV mode)
(WW) NVIDIA(0): Not using mode "1280x960" (not a valid TV mode)
(WW) NVIDIA(0): Not using mode "1152x864" (not a valid TV mode)
(WW) NVIDIA(0): Not using mode "1152x768" (not a valid TV mode)
(WW) NVIDIA(0): Not using mode "832x624" (not a valid TV mode)
(WW) NVIDIA(0): Not using mode "1024x480" (not a valid TV mode)
(WW) NVIDIA(0): Not using mode "768x576" (not a valid TV mode)
(WW) NVIDIA(0): Not using mode "700x525" (not a valid TV mode)
(WW) NVIDIA(0): Not using mode "640x512" (not a valid TV mode)
(WW) NVIDIA(0): Not using mode "720x400" (not a valid TV mode)
(WW) NVIDIA(0): Not using mode "576x432" (not a valid TV mode)
(WW) NVIDIA(0): Not using mode "640x350" (not a valid TV mode)
(WW) NVIDIA(0): Not using mode "576x384" (not a valid TV mode)
(WW) NVIDIA(0): Not using mode "416x312" (not a valid TV mode)
(WW) NVIDIA(0): Not using mode "360x200" (not a valid TV mode)
(WW) NVIDIA(0): Not using mode "320x175" (not a valid TV mode)
(**) NVIDIA(0): Validated modes for display device TV-0:
(**) NVIDIA(0):      Default mode "1024x768": 94.5 MHz, 68.7 kHz, 85.0 Hz
(**) NVIDIA(0):      Default mode "1024x768": 78.8 MHz, 60.1 kHz, 75.1 Hz
(**) NVIDIA(0):      Default mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz
(**) NVIDIA(0):      Default mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz
(**) NVIDIA(0):      Default mode "800x600": 56.3 MHz, 53.7 kHz, 85.1 Hz
(**) NVIDIA(0):      Default mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
(**) NVIDIA(0):      Default mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
(**) NVIDIA(0):      Default mode "640x480": 36.0 MHz, 43.3 kHz, 85.0 Hz
(**) NVIDIA(0):      Default mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
(**) NVIDIA(0):      Default mode "640x480": 31.5 MHz, 37.9 kHz, 72.8 Hz
(**) NVIDIA(0):      Default mode "640x480": 54.0 MHz, 60.0 kHz, 60.0 Hz (D)
(**) NVIDIA(0):      Default mode "640x400": 31.5 MHz, 37.9 kHz, 85.1 Hz
(**) NVIDIA(0):      Default mode "512x384": 47.2 MHz, 68.7 kHz, 85.0 Hz (D)
(**) NVIDIA(0):      Default mode "512x384": 39.4 MHz, 60.1 kHz, 75.1 Hz (D)
(**) NVIDIA(0):      Default mode "400x300": 28.1 MHz, 53.7 kHz, 85.3 Hz (D)
(**) NVIDIA(0):      Default mode "400x300": 24.8 MHz, 46.9 kHz, 75.1 Hz (D)
(**) NVIDIA(0):      Default mode "400x300": 25.0 MHz, 48.1 kHz, 72.2 Hz (D)
(**) NVIDIA(0):      Default mode "320x240": 18.0 MHz, 43.3 kHz, 85.2 Hz (D)
(**) NVIDIA(0):      Default mode "320x240": 15.8 MHz, 37.5 kHz, 75.0 Hz (D)
(**) NVIDIA(0):      Default mode "320x240": 15.8 MHz, 37.9 kHz, 72.8 Hz (D)
(**) NVIDIA(0):      Default mode "320x200": 15.8 MHz, 37.9 kHz, 85.3 Hz (D)
(WW) NVIDIA(0): Unable to find mode "1280x1024" for display device 0 in
(WW) NVIDIA(0):      MetaMode "1280x1024@1280x1024,1280x1024@1280x1024"
(WW) NVIDIA(0): Unable to find mode "1280x1024" for display device 1 in
(II) NVIDIA(0): Virtual screen size determined to be 800 x 600
(==) NVIDIA(0): DPI set to (75, 75)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/X11R6/lib/modules/libfb.a
(II) Module fb: vendor="The XFree86 Project"
    ABI class: XFree86 ANSI C Emulation, version 0.2
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/X11R6/lib/modules/libramdac.a
(II) Module ramdac: vendor="The XFree86 Project"
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC?  No, I don't.
(II) resource ranges after preInit:
    [0] 0   0   0xddc80000 - 0xddcfffff (0x80000) MX[B]
    [1] 0   0   0xd0000000 - 0xd7ffffff (0x8000000) MX[B]
    [2] 0   0   0xde000000 - 0xdeffffff (0x1000000) MX[B]
    [3] -1  0   0xffe00000 - 0xffffffff (0x200000) MX[B](B)
    [4] -1  0   0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
    [5] -1  0   0x000f0000 - 0x000fffff (0x10000) MX[B]
    [6] -1  0   0x000c0000 - 0x000effff (0x30000) MX[B]
    [7] -1  0   0x00000000 - 0x0009ffff (0xa0000) MX[B]
    [8] -1  0   0xdffffc00 - 0xdfffffff (0x400) MX[B]
    [9] -1  0   0xe0000000 - 0xdfffffff (0x0) MX[B]O
    [10] -1 0   0xdfee0000 - 0xdfefffff (0x20000) MX[B](B)
    [11] -1 0   0xddc80000 - 0xddcfffff (0x80000) MX[B](B)
    [12] -1 0   0xd0000000 - 0xd7ffffff (0x8000000) MX[B](B)
    [13] -1 0   0xde000000 - 0xdeffffff (0x1000000) MX[B](B)
    [14] 0  0   0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
    [15] 0  0   0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
    [16] 0  0   0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
    [17] -1 0   0x0000ffff - 0x0000ffff (0x1) IX[B]
    [18] -1 0   0x00000000 - 0x000000ff (0x100) IX[B]
    [19] -1 0   0x0000c800 - 0x0000c81f (0x20) IX[B]
    [20] -1 0   0x0000d400 - 0x0000d403 (0x4) IX[B]
    [21] -1 0   0x0000d800 - 0x0000d803 (0x4) IX[B]
    [22] -1 0   0x0000dc00 - 0x0000dcff (0x100) IX[B]
    [23] -1 0   0x0000d000 - 0x0000d01f (0x20) IX[B]
    [24] -1 0   0x0000cc00 - 0x0000cc1f (0x20) IX[B]
    [25] -1 0   0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
    [26] 0  0   0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
    [27] 0  0   0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(II) NVIDIA(0): AGP 4X successfully initialized
(II) NVIDIA(0): Setting mode "800x600@800x600,x@x"
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(II) Loading extension NV-GLX
(II) Loading extension NV-CONTROL
(II) Loading extension XINERAMA
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) [GLX]: Initializing GLX extension
(**) Option "Protocol" "Microsoft"
(**) Mouse1: Protocol: "Microsoft"
(**) Option "CorePointer"
(**) Mouse1: Core Pointer
(**) Option "Device" "/dev/ttyS0"
(**) Option "BaudRate" "1200"
(**) Option "StopBits" "1"
(**) Option "DataBits" "7"
(**) Option "Parity" "None"
(**) Option "Vmin" "1"
(**) Option "Vtime" "0"
(**) Option "FlowControl" "None"
(**) Mouse1: Emulate3Buttons, Emulate3Timeout: 50
(==) Mouse1: Buttons: 3
(**) Mouse1: BaudRate: 1200
(II) Keyboard "Keyboard1" handled by legacy driver
(II) XINPUT: Adding extended input device "Mouse1" (type: MOUSE)
(II) XINPUT: Adding extended input device "NVIDIA Event Handler" (type: Other)
  • blaataaps
Voor problemen met nvidia verwijs ik u gaarne naar Het grote 'me nVidia drivers doent nie!' topic , een schat van informatie, en daar kun je eventueel de vraag opnieuw stellen, succes :)
