ipv6 over ipv4 over NAT
  • 123 views sinds 30-01-2008
Beste tweakers, ik heb al de search gebruikt en google,
dit is het probleem.
ik heb een router NAT, ik heb windows XP, met ipv6 support en dat werkt allemaal
nu zit ik achter een vage NAT router, ik zag op de site van:
Router using access-list to protect network must have special rules to allow protocol number 41 and TCP port 3653 between Freenet6 and end-users' network. Look in the configuration file (tspc.conf) to know the tunnel server address.
1. NAT gateway handles static NAT addressing and the network administrator could map one Internet unicast globally unique IP address to the end-user host behind the NAT. This means the local network administrator controls and authorises this special configuration for end-users.
aangezien ik een static host heb
volgens windows
netsh interface ipv6>show address
Interface 5: Local Area Connection 4
Addr Type DAD State Valid Life Pref. Life Address
Link Preferred 4294967295 4294967295 fe80::220:18ff:feb8:1fee
Interface 4: Wireless Network Connection 4
Link Preferred 4294967295 4294967295 fe80::240:5ff:fe2a:2809
Interface 2: Automatic Tunneling Pseudo-Interface
Link Preferred 4294967295 4294967295 fe80::5efe:192.168.123.103
Manual Preferred 4294967295 4294967295 3ffe:bc0:8000::15a1
Link Preferred 4294967295 4294967295 fe80::5efe:192.168.0.1
Interface 1: Loopback
Loopback Preferred 4294967295 4294967295 ::1
Link Preferred 4294967295 4294967295 fe80::1
pingen naar mezelf
C:\freenet6\freenet6-client-1.0>ping6 fe80::240:5ff:fe2a:2809
Pinging fe80::240:5ff:fe2a:2809
from fe80::240:5ff:fe2a:2809%4 with 32 bytes of data:
Reply from fe80::240:5ff:fe2a:2809%4: bytes=32 time<1ms
Ping statistics for fe80::240:5ff:fe2a:2809:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
maar wat zie ik als ik dat tspc run:
C:\freenet6\freenet6-client-1.0>tspc
Testing IPv6 presence
Pinging ::1
Reply from ::1: bytes=32 time<1ms
Ping statistics for ::1:
Packets: Sent = 1, Received = 1, Lost = 0 (0% loss),
Success ! Now, you're ready to use IPv6 connectivity to Internet IPv6
Your host is configured to use this IPv6 address : 3ffe:0bc0:8000:0000:0000:0000
:0000:11dd
End of the script
probleem:
1. ik kom nergens dat tegen, vond et al vaag met zoveel nullen
2. ik connect via Xchat en windows naar: osiris.v6.parse.nl, en dat werkt natuurlijk niet
C:\freenet6\freenet6-client-1.0>ping6 2001:9a8:1290::3:0:10
Pinging 2001:9a8:1290::3:0:10
from 3ffe:bc0:8000::11dd with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 2001:9a8:1290::3:0:10:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
en dat is die server,
nu vind ik het best wel raar, ik heb port 41 en 3653 geforward naar mijn pc etc
ik snap het nu iig niet meer
even meer info:
ipv4
Ethernet adapter Wireless Network Connection 4:
Connection-specific DNS Suffix . :
IP Address. . . . . . . . . . . . : 192.168.123.103
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.123.254
yep die had ik nodig
edit: OS: Windows XP Prof
ik zie wel dat ik een routing table heb.. geen idee wat ik er mee moet.. ik weet ook niet of ik het in kan stellen
Afbeeldingslocatie: http://asmooh.op.het.net/routingtable.PNG
[ Voor 11% gewijzigd door Verwijderd op 15-10-2003 18:22 ]
  • TGEN
  • Laatst online: 15:37
TGEN
Hmmmx_
tis protocol 41, niet poort 41. IPv6 over IP staat op hetzelfde niveau als TCP en UDP en ICMP enzo, het draait niet over TCP of UDP. Teredo IPv6 tunneling wel, maar dat is niet wat jij gebruikt denk ik. Je router heeft zoals je in t begin al zei DMZ functionaliteit. Dat houd in dat ie alle protocollen over IP wat ie niet kent (alles behalve TCP en UDP dus) doorstuurt naar de gespecificeerde bak op jouw lan. dit kun je instellen in de webconfig van je router.
Het effect daarvan is dat alle Proto41 packets op die pc op je lan binnenkomen. Daar zet je vervolgens een tunnelendpoint op die proto41 uitpakt, en het werkt. Faq's daarvoor kan je wel op de freenet6 webzijde vinden, maar ik raad je aan over te stappen op SixXS (www.ipv4.sixxs.net).
Pixilated NetphreaX
Dronkenschap is Meesterschap
DragonFly
