[CD-RW CRW4850 ] aopen brander wil niet.
  • 911 views sinds 30-01-2008
  • Bware81
  • Laatst online: 24-01-2022
goede dag mensen..
volgende probleem:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
Windows 98 4.10
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10-9-99 12:06:00
Nero Version: 5.5.9.0
Recorder:             <AOPEN CD-RW CRW4850>     Version: 1.00 - HA 1 TA 0 - 5.5.9.0
 Adapter driver:      <ESDI_506>                HA 1
 Drive buffer  :      2048kB
 Bus Type      :      default (0) -> ATAPI
CD-ROM:               <E-IDE CD -952E/AKV>      Version: A76  - HA 0 TA 1 - 5.5.9.0
 Adapter driver:      <ESDI_506>                HA 0
E-IDE CD -952E/AKV (Target 1, D:): Autoinsert Off, DMA On, Disconnect Off, SyncDataXfer Off
AOPEN CD-RW CRW4850 (Target 0, E:): Autoinsert Off, DMA On, Disconnect Off, SyncDataXfer Off
Excluded drive IDs:
CmdQueuing     : 1
CmdNotification: 2
WriteBufferSize: 34603008 (0) Byte
ShowDrvBufStat : 0
EraseSpeed     : 0
BUFE           : 0
Physical memory     : 255MB (261572kB)
Free physical memory: 20MB (21096kB)
Memory in use       : 67 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry    : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: Off
CD-Image
14.10.2003
13:05:32    #1 Phase 75 File dlgbrnst.cpp, Line 1560
    JustLink activated
13:05:33    #2 Text 0 File Reader.cpp, Line 118
    Reader running
13:05:33    #3 Text 0 File Writer.cpp, Line 129
    Writer AOPEN    CD-RW CRW4850    running
13:05:33    #4 Text 0 File Burncd.cpp, Line 3474
    Turn on Disc-At-Once, using CD-R/RW media
13:05:33    #5 IMAGEGEN -10 File ImageGen.cpp, Line 354
    Image was written as DAO.
    DAOI:
    MediaCatalogNumber=''
    TocType=0x00
    Finalized=0x01
    FirstTrack=0x01
    LastTrack=0x01
        ISRC=''
        Blocksize=2048:
        TrackMode='TRM_DATA_MODE1'
        TrackConfig=0x00:
        FirstIndex=00:
        LastIndex=01:
        Index0FilePos=0 Index1FilePos=307200 NextTrackFilePos=16867328
    CUES:
    000: Ctrl=0x41 Trk=  0 (0x00) Index=00 RecDep=0x00 Start=954437:08.46 (     -150)
    001: Ctrl=0x41 Trk=  1 (0x01) Index=00 RecDep=0x00 Start=954437:08.46 (     -150)
    002: Ctrl=0x41 Trk=  1 (0x01) Index=01 RecDep=0x00 Start=00:00.00 (        0)
    003: Ctrl=0x41 Trk=110 (0xAA) Index=01 RecDep=0x00 Start=01:47.61 (     8086)
13:05:33    #6 Text 0 File ThreadedTransferInterface.cpp, Line 685
    Setup items (original item values)
     0: TRM_DATA_MODE1 (CD-ROM Mode1)
        2 indices, index0 (150) provided
        original CD pos #0 + 8086 (8086) = #8086/1:47.61
        relocatable, CD pos for caching/writing not required/not required, patch infos
13:05:34    #7 Text 0 File DlgWaitCD.cpp, Line 198
    Last possible write address on media:   359848 (79:59.73)
    Last address to be written:               8085 ( 1:49.60)
13:05:34    #8 Text 0 File DlgWaitCD.cpp, Line 1393
    Recorder:  AOPEN CD-RW CRW4850;
       CDR code: 00 97 23 61; OSJ entry from: Customer Pressing Oosterhout
       ATIP Data:
         Special    Info [hex] 1: D0 00 98, 2: 61 17 3D (LI 97:23.61), 3: 4F 3B 4A (LO 79:59.74)
         Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
13:05:34    #9 Text 0 File ThreadedTransferInterface.cpp, Line 835
    Prepare recorder AOPEN    CD-RW CRW4850    for write in cue-sheet-DAO
    DAO infos:
    MCN:
    TOCTYPE: 0x0   Close Session
    Tracks 1 to 1:
       TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 16867328
13:05:34    #10 Text 0 File ThreadedTransferInterface.cpp, Line 685
    Setup items (after recorder preparation)
        -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 8086 blocks [AOPEN    CD-RW CRW4850   ]
13:05:34    #11 Phase 36 File dlgbrnst.cpp, Line 1560
    Burn process started at 12x (1.800 KB/s)
13:05:34    #12 Text 0 File ThreadedTransferInterface.cpp, Line 1967
    Verifying CD position of item 0 (relocatable, no CD pos, patch infos, orig at #0): write at #0
13:05:34    #13 Text 0 File Mmc.cpp, Line 11793
    StartDAO : CD-Text - Off
13:05:34    #14 Text 0 File Mmc.cpp, Line 16205
    Set BUFE: JustLink -> ON , JustSpeed : ON
13:05:34    #15 Text 0 File Mmc.cpp, Line 12039
    CueData, Len=32
    41 00 00 14 00 00 00 00
    41 01 00 10 00 00 00 00
    41 01 01 10 00 00 02 00
    41 aa 01 14 00 01 31 3d
13:05:37    #16 SCSI -1106 File Cdrdrv.cpp, Line 1202
    SCSI Exec, HA 1, TA 0, LUN 0
    Status:     0x04 (0x01, SCSI_ERR)
    HA-Status   0x00 (0x00, OK)
    TA-Status   0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key:  0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x73
    Sense Qual: 0x03
    CDB Data:   0x54 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0C
                0x00 0x00 0x00 0x00 0x73 0x03
13:08:26    #17 SCSI -1106 File Cdrdrv.cpp, Line 1406
    SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x02260000
    Sense Code: 0x73
    Sense Qual: 0x03
    CDB Data:   0x2A 0x00 0x00 0x00 0x0C 0x5A 0x00 0x00 0x1F 0x00 0x00 0x00
13:08:26    #18 MMC -1106 File Writer.cpp, Line 330
    Power calibration error
13:08:26    #19 Text 0 File ThreadedTransfer.cpp, Line 222
    all writers idle, stopping conversion
13:08:26    #20 Phase 38 File dlgbrnst.cpp, Line 1560
    Burn process failed at 12x (1.800 KB/s)
13:08:26    #21 Text 0 File Scsicmd.cpp, Line 383
    SCSI not using temporary buffers
    20 out of 20 temporary buffers allocated
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.10.1998, size=19270 bytes, created 5-5-99 22:22:00
File 'IoSubsys\NEROCD95.VXD': Ver=4, 5, 0, 12, size=37811 bytes, created 10-10-03 16:15:02
File 'IoSubsys\CDFS.VXD': Ver=4.10.1998, size=59133 bytes, created 5-5-99 22:22:00
File 'IoSubsys\ESDI_506.PDR': Ver=4.10.2222, size=24406 bytes, created 5-5-99 22:22:00
File '..\System\Vmm32\Ios.vxd': Ver=4.10.2222, size=69574 bytes, created 5-5-99 22:22:00
File 'IoSubsys\Disktsd.vxd': Ver=4.10.2222, size=18809 bytes, created 5-5-99 22:22:00
en ik heb al nieuwe aspi drivers geprobeerd en de nieuwe via chip zet dirvers geinstalleerd maar hij wil echt niet branden.. :(
gisteren een cdr/w gebrand hij zei dat hij voltooid was maar helaas op geen een andere pc kan hij deze cd lezen..
wat kan het probleem nog zijn?
AMD64 XP3000+, 1024MB Kingston, ASUS K8V deluxe SE, ATI Radeon 9800 pro Realtek8139 Nic, ITE RAID contr, 2x 80GB Maxtor,2x 160GB sataMaxtor, NEC1300a DVD-r, Samsung DVD/CD-r combo. 21inch crt Compaq
Power calibration error....
Dacht dat dit nog wel eens te verhelpen is met een firmware update van je brander.
  • Bware81
Verwijderd schreef op 14 oktober 2003 @ 19:24:
zo ik heb dus nu een firmware update gedaan... en wat denk je?
hijs helemaal ver(*^@.
de bios en/of windows herkent de speler niet meer... en als je het schuifje van de cd-rom dicht doet dan schiet hij na 3 sec weer open... (in meerdere pc's gesjeckt dus kan geen virus zijn)
ik heb de firmware gebruikt die in de meuktracker stond hier op tweakers...
de: 4850_f104.exe
maar nu wil ik dus een andere versie erop gaan zette maar... de branden word niet meer herkent dus hoe kan ik dit nu doen..?
want de firmware's zijn allemaal voor in windows en een dos versie van de firmware kan ik niet vinden.?
iemand een idee?
DOS-versie: http://www.cendyne.com/downloads/firmware/4850104.zip
Je had je cd er toch uit gehaald voor je begon zekers???
[ Voor 32% gewijzigd door Verwijderd op 24-11-2003 11:31 ]
  • Bware81
Verwijderd schreef op 24 november 2003 @ 11:23:
welke cd?
er zat geen cd in...
gewoon een cd, het kan mislukken als er een cd inzit.
Is het met de dos-versie gelukt?
  • biobak
  • Registratie: Augustus 1999
  • Laatst online: 06:49
Bware81 schreef op 24 november 2003 @ 09:46:
iemand een idee?
Toevallig geflashed met Intel Application Accellerator (of andere niet-standaard Windows driver) geinstalleerd en nu krijg je iets van "Ricoh Firmwareloader2"? Ik heb dat probleem ook gehad. Weet alleen niet meer hoe ik het gefixt heb. Ik dacht het flashprogramma 2x openen en met de laatst geopende echt flashen. Sindsdien flash ik mijn cdrw in veilige modus (kun je ook nog proberen).
Op het Aopen Eforum staan meer van dit soort problemen. Forum is te bereiken via http://club.aopen.com.tw
[ Voor 7% gewijzigd door biobak op 24-11-2003 17:57 ]
