xlib glx probleem
  • 37 views sinds 30-01-2008
Ik heb een gf4200 ti met ia32 Nvidiadrivers geinstalleerd. Ik gebruik distro redhat 9, maar ik krijg steeds de foutmelding bij het draaien van heavy 3d apps zoals tuxracer
Xlib: extension "GLX" missing on display ":0.0".
load "glx" staat in mijn XF86 config. en als ik in de terminal glxinfo invoer dan krijg ik de foutmelding:
[insider@localhost insider]$ glxinfo
name of display: :0.0
Error: couldn't find RGB GLX visual
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x21 24 tc 1 0 0 c . . 0 0 0 0 0 0 0 0 0 0 0 0 0 None
0x22 24 dc 1 0 0 c . . 0 0 0 0 0 0 0 0 0 0 0 0 0 None
Wie kan mij helpen?
PS: Mijn vorige topic was gesloten
Hier mijn XF86config
# XFree86 4 configuration created by pyxf86config
Section "ServerLayout"
Identifier "Default Layout"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "DevInputMice" "AlwaysCore"
EndSection
Section "Files"
# RgbPath is the location of the RGB database. Note, this is the name of the
# file minus the extension (like ".txt" or ".db"). There is normally
# no need to change the default.
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, Red Hat 6.0 and later now use a font server independent of
# the X server to render fonts.
RgbPath "/usr/X11R6/lib/X11/rgb"
FontPath "unix/:7100"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "fbdevhw"
Load "glx"
Load "record"
Load "freetype"
Load "type1"
Load "dri"
EndSection
Section "InputDevice"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
# Option "Xleds" "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
# Option "XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults). For example, for a non-U.S.
# keyboard, you will probably want to use:
# Option "XkbModel" "pc102"
# If you have a US Microsoft Natural keyboard, you can use:
# Option "XkbModel" "microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
# Option "XkbLayout" "de"
# or:
# Option "XkbVariant" "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
# Option "XkbOptions" "ctrl:swapcaps"
# Or if you just want both to be control, use:
# Option "XkbOptions" "ctrl:nocaps"
Identifier "Keyboard0"
Driver "keyboard"
Option "XkbRules" "xfree86"
Option "XkbModel" "pc105"
Option "XkbLayout" "us"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "IMPS/2"
Option "Device" "/dev/psaux"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "no"
EndSection
# If the normal CorePointer mouse is not a USB mouse then
# this input device can be used in AlwaysCore mode to let you
# also use USB mice at the same time.
Identifier "DevInputMice"
Driver "mouse"
Option "Device" "/dev/input/mice"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Iiyama Vision Master MF-8617"
HorizSync 23.6 - 86.0
VertRefresh 50.0 - 120.0
Option "dpms"
EndSection
Section "Device"
Identifier "Videocard0"
Driver "nv"
VendorName "Videocard vendor"
BoardName "NVIDIA GeForce 4 (generic)"
VideoRam 131072
EndSection
Section "Screen"
Identifier "Screen0"
Device "Videocard0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes "1024x768" "800x600" "640x480"
EndSubSection
EndSection
Section "DRI"
Group 0
Mode 0666
EndSection
Wie kan mij helpen?
  • blaataaps
Verwijderd schreef op 13 October 2003 @ 15:03:
En met een reden, zoals je in de sluitpost van Wilke kunt lezen, is er voor problemen met nvidia-videokaarten Het grote 'me nVidia drivers doent nie!' topic , die kun je doornemen, en evt daar je vraag stellen. Verder bevordert het gebruik van
of quote tags om je config heen de leesbaarheid, zodat men kan zien wat je config is, en wat je eigen tekst.
