Problemen Sony brander cd-rw CRX210E
  • 102 views sinds 30-01-2008
Mijn brander laat heel wat steekjes vallen. Nu zijn er 4 tot 5 keer achterelkaar cd's mislukt.
Dit is met Win xp home met service pack 1.
Iemand een idee???
Mijn logfile van nero:
Windows XP 5.1
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 14-8-2002 15:03:36
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.50, size=131072 bytes, created 25-6-2002 16:34:54
Nero Version: 5.5.9.14
Recorder: <SONY CD-RW CRX210E1> Version: 2YS1 - HA 3 TA 0 - 5.5.9.14
Adapter driver: <atapi> HA 3
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <JLMS DVD-ROM LTD-165H>Version: CH0U - HA 2 TA 1 - 5.5.9.14
Adapter driver: <atapi> HA 2
=== Scsi-Device-Map ===
DiskPeripheral : ST3120023A atapi Port 2 ID 0 DMA: On
CdRomPeripheral : JLMS DVD-ROM LTD-165H atapi Port 2 ID 1 DMA: Off
CdRomPeripheral : SONY CD-RW CRX210E1 atapi Port 3 ID 0 DMA: On
CdRomPeripheral : AXV CD/DVD-ROM 2.2a axwhisky Port 4 ID 0 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 61865984 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 215MB (220452kB)
Memory in use : 57 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: Off
10.10.2003
CD-ROM (ISO)
21:23:42 #1 Text 0 File Isodoc.cpp, Line 6887
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
21:23:42 #2 Phase 96 File dlgbrnst.cpp, Line 1571
Buffer underrun error protection activated
21:23:42 #3 Text 0 File Reader.cpp, Line 118
Reader running
21:23:42 #4 Text 0 File Writer.cpp, Line 127
Writer SONY CD-RW CRX210E1 running
21:23:42 #5 ISO9660GEN -11 File geniso.cpp, Line 4484
First writeable address = 0 (0x00000000)
21:23:43 #6 Text 0 File Burncd.cpp, Line 3588
Turn on Disc-At-Once, using CD-R/RW media
21:23:43 #7 Text 0 File ThreadedTransferInterface.cpp, Line 660
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 358804 (358804) = #358804/79:44.4
relocatable, CD pos for caching/writing not required/required, no patch infos
21:23:43 #8 Text 0 File DlgWaitCD.cpp, Line 203
Last possible write address on media: 359848 (79:59.73)
Last address to be written: 358803 (79:46.03)
21:23:43 #9 Text 0 File DlgWaitCD.cpp, Line 208
Write in overburning mode: FALSE
21:23:43 #10 Text 0 File DlgWaitCD.cpp, Line 1420
Recorder: SONY CD-RW CRX210E1;
CDRW code: 00 97 15 05; OSJ entry from: TDK Corporation
ATIP Data: ?
21:23:43 #11 Text 0 File ThreadedTransferInterface.cpp, Line 812
Prepare recorder SONY CD-RW CRX210E1 for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Close CD
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 735137792
21:23:43 #12 Text 0 File ThreadedTransferInterface.cpp, Line 660
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 358804 blocks [SONY CD-RW CRX210E1 ]
21:23:43 #13 Phase 24 File dlgbrnst.cpp, Line 1571
Caching of files started
21:23:43 #14 Phase 25 File dlgbrnst.cpp, Line 1571
Caching of files completed
21:23:43 #15 Phase 36 File dlgbrnst.cpp, Line 1571
Burn process started at 40x (6.000 kB/sec)
21:23:43 #16 Text 0 File ThreadedTransferInterface.cpp, Line 1948
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
21:23:43 #17 Text 0 File Mmc.cpp, Line 12622
StartDAO : CD-Text - Off
21:23:43 #18 Text 0 File Mmc.cpp, Line 17168
Set BUFE: Buffer under-run error protection -> ON , SMART-BURN : ON
21:23:43 #19 Text 0 File Mmc.cpp, Line 12880
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 10 00 00 00 00
41 01 01 10 00 00 02 00
41 aa 01 14 00 4f 2e 04
21:24:11 #20 SCSI -1135 File Cdrdrv.cpp, Line 1381
SCSI Exec, HA 3, TA 0, LUN 0, buffer 0x02660000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x16 0xA5 0x00 0x00 0x1F 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
21:24:11 #21 MMC -1135 File Writer.cpp, Line 335
Write error
21:24:11 #22 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
21:24:11 #23 Text 0 File ThreadedTransfer.cpp, Line 216
conversion idle, stopping reader
21:24:11 #24 Phase 38 File dlgbrnst.cpp, Line 1571
Burn process failed at 40x (6.000 kB/sec)
21:24:11 #25 Text 0 File Scsicmd.cpp, Line 402
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created 14-8-2002 15:03:36
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29-8-2002 2:27:50 (Adapter driver for rec)
Registry Keys:
HKLM\Software\CPUCooL (Power saving: CPUCooL)
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
