Wat zou ik nog allemaal moeten veranderen om mijn P4 2000 oc
  • 90 views sinds 30-01-2008
Wat zou ik nog allemaal moeten veranderen om mijn P4 2000 te overclocken
mijn 200 draair nu op 2300
cpu cooler: coolermaster Aero
PC Spefc:
SiSoftware Sandra
System
Processor
Model : Intel(R) Pentium(R) 4 CPU 2.00GHz
Speed : 2.30GHz
Performance Rating : PR2530 (estimated)
Type : Standard
L2 On-board Cache : 512kB ECC Synchronous ATC (8-way sectored, 64 byte line size)
Mainboard
Bus(es) : ISA AGP PCI USB i2c/SMBus
MP Support : No
MP APIC : No
System BIOS : Award Software International, Inc. 6.00 PG
Mainboard : MICRO-STAR INTERNATIONAL CO., LTD MS-6545
Total Memory : 511MB RDRAM
Chipset 1
Model : Intel Corporation 82850/E Host-Hub Interface Bridge Device
Front Side Bus Speed : 4x 115MHz (460MHz data rate)
Total Memory : 512MB RDRAM
Memory Bus Speed : 2x 460MHz (920MHz data rate)
Video System
Monitor/Panel : Philips 170B (17inch LCD MONITOR 170B4)
Adapter : NVIDIA GeForce3 Ti 200
Physical Storage Devices
Hard Disk : Maxtor 5T060H6
Hard Disk : Maxtor 6Y080L0
CD-ROM/DVD : IDE DVD-ROM 16X
CD-ROM/DVD : PLEXTOR CD-R PX-W1610A
CD-ROM/DVD : V386 STEALTH DVD SCSI CdRom Device
Logical Storage Devices
Hard Disk (C:) : 57.3GB (34.5GB, 60% Free) (NTFS)
Office11 (D:) : 196MB (0MB, 0% Free) (CDFS)
CD-ROM/DVD (E:) : N/A
Hard Disk (F:) : 76.3GB (9.2GB, 12% Free) (NTFS)
Nfh (G:) : 496MB (0MB, 0% Free) (CDFS)
Peripherals
Serial/Parallel Port(s) : 2 COM / 1 LPT
USB Controller/Hub : OPTi 82C861 PCI to USB Open Host Controller
USB Controller/Hub : Intel(r) 82801BA/BAM USB Universal Host Controller - 2442
USB Controller/Hub : Intel(r) 82801BA/BAM USB Universal Host Controller - 2444
USB Controller/Hub : USB Root Hub
Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Keyboard : HID Keyboard Device
Mouse : PS/2 Compatible Mouse
Human Interface : HID-compliant game controller
Human Interface : Microsoft SideWinder Strategic Commander HID Drivers
Human Interface : HID-compliant device
Human Interface : Microsoft SideWinder Virtual Keyboard
Human Interface : USB Human Interface Device
MultiMedia Device(s)
Device : MPU-401 Compatible MIDI Device
Device : Standard Game Port
Device : Hercules (R) Game Port
Operating System(s)
Windows System : Microsoft Windows XP/2002 Professional (Win32 x86) 5.01.2600 (Service Pack 1)
Network Services
Network Drivers Enabled : Yes
Adapter : Realtek RTL8139 Family PCI Fast Ethernet NIC #2
SiSoftware Sandra
Mainboard
Manufacturer : MICRO-STAR INTERNATIONAL CO., LTD
MP Support : No
Model : MS-6545
System Memory Controller
Error Correction Capability : ECC
Number of Memory Slots : 4
Maximum Installable Memory : 2GB
Bank0/1 - A0 : RIMM FPM CMOS RDRAM 256MB/16 @ 800Mt/s
Bank2/3 - A1 : RIMM FPM CMOS RDRAM 256MB/16 @ 800Mt/s
Bank4/5 - A2 : Empty
Bank6/7 - A3 : Empty
Chipset 1
Maximum FSB Speed / Max Memory Speed : 4x 133MHz / 2x 532MHz
Width : 64-bit
IO Queue Depth : 8 request(s)
Chipset 1 Hub Interface
Type : Hub-Interface
Version : 1.00
Number of Ports : 1
Width : 8-bit
Full Duplex : Yes
Multiplier : 1/1x
Logical/Chipset 1 Memory Banks
Bank 0 : 256MB RDRAM 8/9CL
Bank 1 : 256MB RDRAM 8/9CL
Channels : 2
Multiplier : 4/1x
Width : 16-bit
Refresh Rate : 1.95µs
Power Save Mode : No
Fixed Hole Present : No
Memory Module(s)
Memory Module 1 : Samsung MR16R 1628AF0-CK8 25233801 256MB/8 (256Mx16) RDRAM RIMM PC800-45 (CL2-2 up to 411MHz)
Memory Module 3 : Samsung MR16R 1628AF0-CK8 25273801 256MB/8 (256Mx16) RDRAM RIMM PC800-45 (CL2-2 up to 411MHz)
Environment Monitor 1
Model : Winbond W83627HF ISA
Version : 2.01
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 35.0°C / 95.0°F
CPU Temperature : 41.0°C / 105.8°F td
Cooling Device(s)
Auto Fan Speed Control : No
Chassis Fan Speed : 5819rpm
CPU Fan Speed : 4963rpm
Power / Aux Fan Speed : 3590rpm
Voltage Sensor(s)
CPU Voltage : 1.46V
Aux Voltage : 1.86V
+3.3V Voltage : 3.28V
+5V Voltage : 5.05V
+12V Voltage : 11.86V
-12V Voltage : -12.03V
-5V Voltage : -5.25V
Standby Voltage : 5.02V
Battery Voltage : 3.18V
AGP Bus(es) on Hub 1
Version : 2.00
Speed : 4x
Multiplier : 1/2x
Fast-Writes Enabled : Yes
Side Band Enabled : No
Side Band Support : Yes
Aperture Size : 64MB
PCI Bus(es) on Hub 1
Version : 2.20
Number of Bridges : 2
PCI Bus 0 : PCI (1x PCIClk)
PCI Bus 2 : PCI (1x PCIClk)
LPC Hub Controller 1
Model : Intel Corporation 82801BA LPC Interface (ICH2 B4 step)
ACPI Power Management Enabled : Yes
Random Number Generator Enabled : No
Random Number Generator Support : Yes
Delayed Transaction Enabled : Yes
USB Controller 1
Model : Intel Corporation 82801BA/BAM USB Controller #1 (ICH2/ICH2-M B4 step)
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled : No
USB Controller 2
Model : Intel Corporation 82801BA/BAM USB Controller #2 (ICH2/ICH2-M B4 step)
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 3
Model : OPTi Inc 82C861/2/3 FireLink USB Controller
Version : 1.00
Interface : OHCI
Channels : 2
System SMBus Controller 1
Model : Intel 801xx SMBus
Version : 0.04
Slave Device Enabled : Yes
Speed : 16kHz
Expansion Slot(s)
PCI (1h) : PCI 32-bit +5V +3.3V PME Full-Length Available (Intel Corporation 82850 AGP Bridge (A2-step))
PCI (2h) : PCI 32-bit +5V +3.3V PME Full-Length Used
PCI (3h) : PCI 32-bit +5V +3.3V PME Full-Length Used
PCI (4h) : PCI 32-bit +5V +3.3V PME Full-Length Used
PCI (5h) : PCI 32-bit +5V +3.3V PME Full-Length Used
AGP (8h) : AGP-4x 32-bit +5V +3.3V PME Full-Length Used
Port Connector
PRIMARY IDE : None - ATA / None
SECONDARY IDE : None - ATA / None
FDD : 8251 FIFO - Floppy Disk / None
COM1 : Serial Port 16550 - None / DB-9 pin male
COM2 : Serial Port 16550 - None / DB-9 pin male
LPT1 : Parallel Port ECP/EPP - None / DB-25 pin female
Keyboard : Keyboard - None / PS/2
PS/2 Mouse : Mouse - None / PS/2
USB : USB - None / USB
SiSoftware Sandra
General Information
Manufacturer : Award Software International, Inc.
Version : 6.00 PG
Date : 10/03/2002
Plug & Play Version : 1.00
SMBIOS/DMI Version : 2.30
(EE)PROM Size : 256kB (2Mbit)
General Capabilities
Can be Updated/Flashed : Yes
Can be Shadowed : Yes
Is Socketed : Yes
Supports Plug & Play : Yes
Supports ESCD : Yes
Supports Enhanced Disk Drive : Yes
NEC PC-98 Spec Compatible : No
Power Management Features
Supports APM : Yes
Supports ACPI : Yes
Supports Smart Battery : No
Boot Features
Supports Selective Booting : Yes
Supports CD/DVD Boot : Yes
Supports PCMCIA/CardBus Boot : No
Supports LS-120 Boot : Yes
Supports ZIP Boot : Yes
Supports i2o Boot : No
Supports FireWire/1394 Boot : No
Supports BIOS Boot Block : No
Supports Interactive Network Boot : No
  • Remy
  • Laatst online: 30-09 09:31
Remy
I usually get 100% accuracy
Gewoon een copy/paste van je system specs en een 1regelige vraag is niet de bedoeling hier in DOC. Lees de DOC faq en de algemene GoT faq inzake topicstarts, want hier schiet niemand wat mee op.
LinkedIn
Instagram
