Beginnen met ASP.NET, krijgt foutmelding Server Error in '/'
  • 34 views sinds 30-01-2008
  • DJ-B
  • Laatst online: 20-08 15:17
Nadat ik een domeinnaam besteld heb met ASP.NET hosting ben ik begonnen met een simpele asp pagina. Echter krijg ik nu de foutmelding zoals je hier kunt zien (http://www.brams.nl/sut/default.aspx). Ik heb gezocht in andere topics en daar kwam uit dat ik een web.config file moest plaatsen, dit heb ik gedaan in de root en in de submap "sut" echter blijft het resultaat het zelfde.
(inhoud web.config)
<?xml version="1.0" encoding="utf-8" ?>
<configuration>
<system.web>
<!-- DYNAMIC DEBUG COMPILATION
Set compilation debug="true" to insert debugging symbols (.pdb information)
into the compiled page. Because this creates a larger file that executes
more slowly, you should set this value to true only when debugging and to
false at all other times. For more information, refer to the documentation about
debugging ASP.NET files.
<compilation defaultLanguage="vb" debug="true" />
<!-- CUSTOM ERROR MESSAGES
Set customErrors mode="On" or "RemoteOnly" to enable custom error messages, "Off" to disable.
Add <error> tags for each of the errors you want to handle.
<customErrors mode="Off"/>
<!-- AUTHENTICATION
This section sets the authentication policies of the application. Possible modes are "Windows",
"Forms", "Passport" and "None"
<authentication mode="Windows" />
<!-- AUTHORIZATION
This section sets the authorization policies of the application. You can allow or deny access
to application resources by user or role. Wildcards: "*" mean everyone, "?" means anonymous
(unauthenticated) users.
<authorization>
<allow users="*" /> <!-- Allow all users -->
<!-- <allow users="[comma separated list of users]"
roles="[comma separated list of roles]"/>
<deny users="[comma separated list of users]"
</authorization>
<!-- APPLICATION-LEVEL TRACE LOGGING
Application-level tracing enables trace log output for every page within an application.
Set trace enabled="true" to enable application trace logging. If pageOutput="true", the
trace information will be displayed at the bottom of each page. Otherwise, you can view the
application trace log by browsing the "trace.axd" page from your web application
root.
<trace enabled="false" requestLimit="10" pageOutput="false" traceMode="SortByTime" localOnly="true" />
<!-- SESSION STATE SETTINGS
By default ASP.NET uses cookies to identify which requests belong to a particular session.
If cookies are not available, a session can be tracked by adding a session identifier to the URL.
To disable cookies, set sessionState cookieless="true".
<sessionState
mode="InProc"
stateConnectionString="tcpip=127.0.0.1:42424"
sqlConnectionString="data source=127.0.0.1;user id=sa;password="
cookieless="false"
timeout="20"
<!-- GLOBALIZATION
This section sets the globalization settings of the application.
<globalization requestEncoding="utf-8" responseEncoding="utf-8" />
</system.web>
</configuration>
Hoe moet het verder? Ik heb echt geen flauw idee, ligt de fout bij mij of bij de Hosting Provider?
Dank u
  • gorgi_19
  • Laatst online: 20-08 11:40
gorgi_19
Kruimeltjes zijn weer op :9
[ Voor 228% gewijzigd door gorgi_19 op 05-10-2003 13:31 ]
Digitaal onderwijsmateriaal, leermateriaal voor hbo
  • DJ-B
Ik heb de web.config file ge-upload met deze inhoud:
<!-- Web.Config Configuration File -->
<configuration>
<system.web>
</system.web>
</configuration>
maar het resultaat blijft hetzelfde
  • gorgi_19
gorgi_19
DJ-B schreef op 05 October 2003 @ 13:31:
<configuration>
<system.web>
</system.web>
</configuration>
Is die folder uberhaupt als application gedefinieerd in IIS? Het enige wat ik voor zover weet, is dat er iig ook wat fouts zin in je web.config. :P
[ Voor 18% gewijzigd door gorgi_19 op 05-10-2003 13:33 ]
  • DJ-B
Geen idee,
ik weet niet eens of ik dat zelf zou kunnen regelen?
Het beste is om toch maar eens de hosting provider te waarschuwen?
  • gorgi_19
gorgi_19
DJ-B schreef op 05 October 2003 @ 13:33:
Geen idee,
Ik heb geen idee of sut een aparte applicatie is of niet; zo ja, dan moet deze iig als application gedefinieerd zijn in IIS.
Ik heb verder je web.config net getest bij mij; bij mij deed die het gewoon goed.
Idd lijkt me dit iets voor je hoster om op te lossen.
[ Voor 7% gewijzigd door gorgi_19 op 05-10-2003 13:40 ]
  • DJ-B
gorgi_19 schreef op 05 October 2003 @ 13:37:
Oke bedankt, dan ga ik daar klagen ;)
  • whoami
  • Laatst online: 22:54
Ok dan. ;)
https://fgheysels.github.io/
