FXP niet mogelijk met proftpd?
  • 149 views sinds 30-01-2008
Ik probeer al 2 dagen mijn ftp server te configureren dat er fxp transfers mogelijk zijn. Na taloze keren mijn config vern**kt te hebben toch maar even hier vragen, :)
Heb de regels "AllowForeignAddress on" en omdat het achter een router is "PassivePorts 62000 64000" al toegevoegd. Iemand enige idee wat ik fout doe?
Gewoon ftp werkt wel overigens. En ja de poorten zijn allemaal geforward. ;)
Is trouwens een debian machine. Hieronder mijn config.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
# This is a basic ProFTPD configuration file.
# It establishes a single server and a single anonymous login.
# It assumes that you have a user/group "nobody" and "ftp"
# for normal/anonymous operation.
ServerName          "Neo-X FTP"
ServerType          standalone
#ServerType         inetd
DefaultServer           on
# Port 21 is the standard FTP port.
Port                21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask               022
# To prevent DoS attacks, set the maximum number of child processes
# to 30.  If you need to allow more than 30 concurrent connections
# at once, simply increase this value.  Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances            30
# Even een beetje FXP ;)
# Set the user and group that the server normally runs at.
User                nobody
Group               nogroup
# This next option is required for NIS or NIS+ to work properly:
#PersistentPasswd off
SystemLog           /var/log/proftpd.log
TransferLog         /var/log/xferlog
# Normally, we want files to be overwriteable.
<Directory /*>
  AllowOverwrite        on
</Directory>
DefaultRoot             ~
RequireValidShell       off
# A basic anonymous FTP server configuration.
# To enable this, remove the user ftp from /etc/ftpusers.
<Anonymous ~>
  User              ftp
  Group             ftp
  # We want clients to be able to login with "anonymous" as well as "ftp"
  UserAlias         anonymous ftp
  # Mmh, hier ook moar eem 'n beetie fxp dan!!!
  # Limit the maximum number of anonymous logins
  MaxClients            50
  # We want 'welcome.msg' displayed at login, and '.message' displayed
  # in each newly chdired directory.
  DisplayLogin          welcome.msg
  DisplayFirstChdir     .message
  # Limit WRITE everywhere in the anonymous chroot
  <Limit WRITE>
    DenyAll
  </Limit>
  # An upload directory that allows storing files but not retrieving
  # or creating directories.
#  <Directory incoming/*>
#    <Limit READ>
#      DenyAll
#    </Limit>
#    <Limit STOR>
#      AllowAll
#    </Limit>
#  </Directory>
</Anonymous>
  • scorpie
  • Laatst online: 21:13
scorpie
Supra Addict
"FTP Bounce" Attacks and AllowForeignAddress
So, what does this mean for ProFTPD? By default, ProFTPD does not allow such site-to-site transfers, for by allowing them, the server also allows a type of attack known as the "FTP bounce" attack:
http://www.cert.org/advisories/CA-1997-27.html
The protection against this attack is to enforce the requirement that, from the server's point of view, the remote address of a control connection matches the remote address of a data connection. If the addresses do not match, the data connection is treated as from a foreign client, and thus rejected.
However, some site administrators do want to allow their servers to support site-to-site transfers. ProFTPD must be explicitly configured to allow these by using the AllowForeignAddress configuration directive.
http://www.proftpd.org/do..._AllowForeignAddress.html
quote heb ik van:
http://www.castaglia.org/...oFTPD-mini-HOWTO-FXP.html
als ik op deze pagina kijk:
http://www.linuxathome.net/programs3.php
dan zou je alleen maar dit moeten toevoegen:
AllowStoreRestart on
AllowRetrieveRestart on
maargoed, dat had je al... 8)7
[ Voor 14% gewijzigd door scorpie op 01-10-2003 18:19 ]
wil een Toyota Supra mkIV!!!!! | wil een Yamaha YZF-R{1,6} | wil stiekem ook een Ducati
"Security is just a state of mind"
PSN: scorpie | Diablo 3: scorpie#2470
Dat is toch dat "AllowForeignAddress on"?
Dat heb ik er al in staan. Maar het werkt gewoon niet. :(
misschien ligt het aan de client en nie taan de server ?
  • zork
  • Laatst online: 04-08 12:43
Of misschien ligt het niet aan jouw server, maar aan de andere server ;) Zet in je netwerk eens gewoon een windows bak met serv-u neer en probeer dan te fxp'en, wanneer dat werkt weet je dat het niet aan je linux bak ligt. Vervolgens probeer je dit met een server waarvan je 100% zeker weet dat het kan fxp'en, maar dan over internet. Wanneer dit niet werkt, ligt het dus aan je router ofzo :)
Mocht allemaal niet werken. :(
Ik probeer de hele tijd al van een server te transferen waarvan ik zeker weet dat die het kan.
Ben nu al de hele dag aan het kloten met glftpd, werkt ook niet. Heb hem nu zo ver dat hij de directory's aanmaakt. En dan krijg ik een stor command failed. Iemand een idee waar dit aan kan liggen? Lijkt me een veel voorkomend probleem.
  • SinergyX
  • Laatst online: 23:27
SinergyX
____(>^^(>0o)>____
zoals zork zegt, serv-u op een windows bak werkt 100% achter een router (* SinergyX heb er eentje draaien :P). Maar kan je nu dus al wel inloggen e.d via de fxp? staan je rechten voor schrijven dan wel goed?
Ik kan gewoon schrijven als die user, uploaden werkt ook proma maar FXP gaat niet.
Totdat ik m'n poorten allemaal los gezet had zojuist.
Nu gaat het wel. Krijg nu alleen na een paar MB
FXP  INFO : FXP: Transfer request accepted.
FXP  INFO : FXP: Directories created.
LOCAL INF : Detecting leiplogs.tar.gz TYPE ...
LOCAL CMD : TYPE I
HOST  RPL : 200 Type set to I.
LOCAL CMD : PORT 213,84,76,103,6,127
HOST  RPL : 200 PORT command successful
LOCAL CMD : RETR leiplogs.tar.gz
HOST  RPL : 150 Opening BINARY mode data connection for leiplogs.tar.gz (32122803 bytes)
LOCAL DBG : TIMEOUT (socket read).
LOCAL DBG : Unable to get host  reply.
FXP  INFO : FXP: server end.
LOCAL DBG : Lost connection to 195.169.60.164
LOCAL INF : Disconnected.
Deze error, dan heeftie dus al 2-10 MB overgestuurd (met +/- 60 kb/sec) .
Snap er niks van. :(
  • terrapin
Tja, ik weet niks van proftpd, maar pure-ftpd is tamelijk vergelijkbaar, snel, zeer veilig, en....
FXP werkt!!!
Anders zou je ook eens kunnen kijken of het misschien een vaag probleem is met passive en/of active, daar heb ik al heel wat rare ftp problemen mee opgelost..
[ Voor 42% gewijzigd door terrapin op 03-10-2003 11:29 ]
The higher that the monkey can climb, The more he shows his tail
