Ik heb thuis Phptriad draaien en heb net php4.3.3 erop gezet. (phptriad heeft niet de laatste php versie). Maar nu wil ik xml gebruiken. Daarvoor zou je een extensie moeten "toevoegen".
hoe ziet mijn install dir eruit?:
c:/apache/php
c:/apache/extention
c:/apache/mysql
ect.
ect.
het kan zijn dat extention in de php map zit.
Nou staat in c:/apache/php/php.ini de link naar :
; Directory in which the loadable extensions (modules) reside.
extension_dir = "./"
en de extensions eronder:
; Dynamic Extensions ;
; If you wish to have an extension loaded automatically, use the following
; syntax:
; extension=modulename.extension
; For example, on Windows:
; extension=msql.dll
; ... or under UNIX:
; extension=msql.so
; Note that it should be the name of the module only; no directory information
; needs to go here. Specify the location of the extension with the
; extension_dir directive above.
;Windows Extensions
;Note that MySQL and ODBC support is now built in, so no dll is needed for it.
;extension=php_bz2.dll
;extension=php_cpdf.dll
;extension=php_crack.dll
;extension=php_curl.dll
;extension=php_db.dll
;extension=php_dba.dll
;extension=php_dbase.dll
;extension=php_dbx.dll
;extension=php_exif.dll
;extension=php_fdf.dll
;extension=php_filepro.dll
;extension=php_gd2.dll
;extension=php_gettext.dll
;extension=php_hyperwave.dll
;extension=php_iconv.dll
;extension=php_ifx.dll
;extension=php_iisfunc.dll
;extension=php_imap.dll
;extension=php_interbase.dll
;extension=php_java.dll
;extension=php_ldap.dll
;extension=php_mbstring.dll
;extension=php_mcrypt.dll
;extension=php_mhash.dll
;extension=php_mime_magic.dll
;extension=php_ming.dll
;extension=php_mssql.dll
;extension=php_msql.dll
;extension=php_mysql.dll
;extension=php_oci8.dll
;extension=php_openssl.dll
;extension=php_oracle.dll
;extension=php_pdf.dll
;extension=php_pgsql.dll
;extension=php_printer.dll
;extension=php_shmop.dll
;extension=php_snmp.dll
;extension=php_sockets.dll
;extension=php_sybase_ct.dll
;extension=php_w32api.dll
;extension=php_xmlrpc.dll
;extension=php_xsl.dll
;extension=php_yaz.dll
;extension=php_zip.dll
Laad hij nu op deze manier alle dll's in, in mijn phpinfo.php zie ik bijvoorbeeld geen extra functies staan zoals xml.
c:/apache/php
c:/apache/extention
c:/apache/mysql
ect.
ect.
; syntax:
; extension=msql.so
;Windows Extensions
