Nu heb ik een goed werkende website : http://music4ever.servemp3.com/
Alleen is mijn vraag, hoe koppel ik nu als een user ingelogged is, dit aan het onderstaande members online script?
Inlogscript :
<?php
$user_hostname = "localhost";
$user_username = "db";
$user_password = "db";
$user_database = "db_db";
$connect = mysql_connect("$user_hostname", "$user_username", "$user_password");
mysql_select_db("$user_database", $connect);
session_start();
if(!isset($username)) {
echo "<form method=\"POST\" action=$PHP_SELF>
<table>
<tr>
<td>Username:</td>
<td><input type=\"text\" name=\"username\" size=\"10\"></td>
</tr>
<tr>
<td>Password:</td>
<td><input type=\"password\" name=\"password\" size=\"10\"></td>
</tr>
<tr>
<td colspan=\"8\">
<p align=\"center\"><input type=\"submit\" value=\"Submit\" name=\"submit\"></td>
</tr>
</table>
</form>";
exit;
session_register("username");
session_register("password");
$sql = "SELECT * FROM users WHERE username = \"$username\" AND password = \"$password\"";
$result = @mysql_query($sql) or die("No.");
if(mysql_num_rows($result) == "0") {
session_unregister("username");
session_unregister("password");
echo "
<br><br>Dit is de verkeerde username of password,
<br>Klik <a href=url>hier</a> om opnieuw in te loggen\n";
exit;
if(isset($username)) {
<SCRIPT>
function redirect()
window.location = "url.php"
setTimeout("redirect();", 1)
</SCRIPT>
Members online script :
function doUsersOnline() {
global $REMOTE_ADDR;
$db = new db;
$auth = new authenticate;
$now = time();
$expire = $now - 600;
$query = "DELETE FROM useronline WHERE timestamp < $expire";
$db->db_query($query);
if($auth->checkLogin()) {
$username = $auth->getName();
} else {
$username = "-1";
$query = "SELECT ip,username FROM useronline WHERE ip='$REMOTE_ADDR'";
$result = $db->db_query($query);
if(($db->db_numrows($result)) == 0) {
$query = "INSERT useronline (timestamp,ip,username) VALUES ($now,'$REMOTE_ADDR','$username')";
} else {
$row = $db->db_fetch_array($result);
if ($row['username'] != $username) {
$query = "UPDATE useronline SET username='".$username."' WHERE ip='".$REMOTE_ADDR."'";
$db->db_query($query);}
$query = "SELECT timestamp FROM useronline WHERE username='-1'";
$guests = $db->db_numrows($result);
$query = "SELECT username FROM useronline WHERE username <> '-1'";
$members = $db->db_numrows($result);
for($i=0;$i < $members;$i++) {
$membernames[$i] = $row['username'];
$returnarray = array($guests,$members,$membernames);
return $returnarray;
#####sql table schema
CREATE TABLE useronline (
timestamp int(11) NOT NULL default '0',
ip varchar(40) NOT NULL default '',
username varchar(30) NOT NULL default '',
PRIMARY KEY (timestamp,ip),
KEY timestamp (timestamp),
KEY ip (ip)
) TYPE=MyISAM;
Inlogscript :
<?php
session_start();
<table>
<tr>
<td>Username:</td>
</tr>
<tr>
<td>Password:</td>
</tr>
<tr>
<td colspan=\"8\">
</tr>
</table>
</form>";
exit;
echo "
exit;
<SCRIPT>
function redirect()
</SCRIPT>
$db = new db;
$now = time();
} else {
$username = "-1";
} else {
KEY ip (ip)
) TYPE=MyISAM;
