Ik gebruik het scriptje 14all.cgi om icm. mrtg en rrd grafieken te maken. Om mijn vraag te beantwoorden heb je geen verstand nodig van mrtg en rrd dus lees nog ff verder
In het cgi filetje staat een functie dat een PNG image genereerd als de functie uitgevoerd word. dit is die functie:
[perl]
sub errorpng()
return (
137,80,78,71,13,10,26,10,0,0,0,13,73,72,68,82,0,0,0,187,0,0,0,29,4,3,0,
0,0,0,251,0,170,0,0,0,4,103,65,77,65,0,0,177,143,11,252,97,5,0,0,0,30,80,
76,84,69,255,0,0,255,93,93,255,128,128,255,155,155,255,176,176,255,195,
195,255,212,212,255,227,227,255,241,241,255,255,255,17,191,146,253,0,0,
0,56,116,69,88,116,83,111,102,116,119,97,114,101,0,88,86,32,86,101,114,
115,105,111,110,32,51,46,49,48,97,32,32,82,101,118,58,32,49,50,47,50,57,
47,57,52,32,40,80,78,71,32,112,97,116,99,104,32,49,46,50,41,221,21,46,73,
0,0,2,40,73,68,65,84,120,218,237,147,177,107,219,64,20,198,159,34,233,92,
109,130,180,132,108,55,180,78,189,169,113,8,220,166,80,106,208,230,102,
48,237,118,56,246,153,219,28,7,2,183,165,77,23,109,142,101,157,244,254,
219,62,73,198,113,106,211,150,144,108,254,166,143,167,79,63,221,125,167,
3,216,107,175,189,94,65,136,56,223,26,58,166,224,207,71,6,114,3,175,148,
220,10,136,66,47,183,134,44,254,115,114,48,252,55,126,87,192,92,248,24,
254,237,173,70,110,246,95,120,182,184,17,231,242,4,103,160,79,34,213,12,
117,148,224,204,205,211,159,96,205,18,24,254,162,26,105,189,198,66,29,149,
96,80,10,172,29,64,154,91,55,83,30,22,92,124,43,33,152,60,86,75,229,196,
172,204,68,42,83,85,114,157,70,4,97,182,218,121,121,150,187,56,41,0,111,
75,254,253,54,141,197,13,64,203,154,184,138,78,114,223,158,47,222,229,156,
28,128,95,104,235,150,182,115,159,244,133,53,211,160,208,215,27,71,43,153,
253,36,238,223,23,96,250,250,42,84,43,188,55,58,180,174,117,16,202,208,
156,166,97,114,87,237,185,211,239,72,138,230,78,217,30,126,200,220,204,
35,199,225,227,67,139,240,167,189,11,33,197,244,120,17,60,180,178,39,229,
60,128,136,217,156,74,211,117,227,53,30,18,164,29,211,115,11,186,155,1,
155,87,120,93,157,123,204,104,77,145,65,194,215,14,68,228,90,119,9,30,173,
148,108,22,72,246,20,63,167,4,91,64,71,234,213,48,116,204,89,193,31,241,
57,28,173,240,46,167,104,214,237,30,229,135,21,158,92,8,162,239,85,209,
100,22,72,17,251,187,241,94,93,14,64,151,6,250,171,143,108,225,173,241,
235,114,146,233,177,172,162,142,13,174,91,85,57,228,160,41,39,3,205,147,
166,156,77,60,98,86,227,65,163,13,117,243,189,35,196,31,30,150,107,124,
36,176,228,111,170,67,71,12,235,232,172,133,101,118,128,146,28,253,160,
77,52,193,84,138,20,227,77,188,82,106,232,73,104,115,120,171,46,160,71,
3,26,58,131,49,135,193,229,136,238,141,130,17,244,184,171,46,193,165,39,
78,239,170,142,142,67,71,125,30,194,32,38,71,249,193,200,82,212,31,183,
99,241,101,76,247,207,219,125,223,158,41,49,111,126,134,202,70,47,9,110,
228,151,230,238,21,241,123,237,245,162,250,13,181,158,203,16,233,3,210,
153,0,0,0,7,116,73,77,69,7,208,1,19,13,28,15,223,54,180,209,0,0,0,0,73,
69,78,68,174,66,96,130
[/perl]
Deze nummers vormen dus een plaatje. Ik heb geen idee hoe deze techniek heet of hoe ik een plaatje converteer naar een combinatie van nummers zodat ik deze functie mijn eigen plaatje kan laten uitpoepen. Ik heb dus ook nog niet in goolge gezocht om dat ik geen idee heb waarna ik moet zoeken
Wie kan mij verder helpen, een handvat aanreiken?
[perl]
sub errorpng()
return (
[/perl]
[ Voor 6% gewijzigd door Verwijderd op 22-09-2003 16:50 . Reden: te vroeg op post gedrukt ]
