Hallo allemaal,
Enkele dagen geleden kreeg ik de opdracht om een Word Macro aan te passen die draaide onde Word 2002 UK versie maar constant vast slaat onder de nederlandse versie.
De code loopt iedere keer vast op 1 regel die ik aangegeven heb in de onderstaande 2 stukken code:
Private Sub UpdateHeader(pgSetup As PageSetup, _
hdr As HeaderFooter, _
runHeadText As String, _
numType As Integer, _
numStyle As Integer, _
isRestartNums As Boolean)
Dim hdrTabs As TabStops
Dim hdrRng As Range
Dim rightEdge As Single, centerPt As Single
Dim fld As field
Dim pgNums As PageNumbers
rightEdge = pgSetup.PageWidth - pgSetup.LeftMargin - pgSetup.RightMargin
centerPt = rightEdge / 2#
'Initialize the header
hdr.LinkToPrevious = False
Set hdrRng = hdr.Range
With hdrRng
.Text = ""
.Style = "Header" <== Deze regel
For Each fld In .Fields
fld.Delete
Next fld
Set hdrTabs = .ParagraphFormat.TabStops
End With
hdrTabs.ClearAll
hdrTabs.Add Position:=rightEdge, Alignment:=wdAlignTabRight
Set pgNums = hdr.PageNumbers
If isRestartNums Then
pgNums.RestartNumberingAtSection = True
pgNums.StartingNumber = 1
Else
pgNums.RestartNumberingAtSection = False
End If
Select Case numType
Case ePageNumberBottomCenter
hdrRng.Text = vbTab & runHeadText
pgNums.NumberStyle = numStyle
Case ePageNumberTopCenter
hdrTabs.Add Position:=centerPt, Alignment:=wdAlignTabCenter
With hdrRng
.Text = vbTab
.Collapse wdCollapseEnd
ActiveDocument.Fields.Add Range:=hdrRng, Type:=wdFieldPage
.MoveEnd
.InsertAfter vbTab & runHeadText
End With
Case ePageNumberTopRight
hdrTabs.Add Position:=rightEdge - 36, Alignment:=wdAlignTabRight
With hdrRng
.Text = vbTab & runHeadText & vbTab
End With
Case Else 'numtype = none
End Select
End Sub
En in dit stuk code:
Private Sub UpdateFooter(pgSetup As PageSetup, _
ftr As HeaderFooter, _
Dim ftrRng As Range
Dim fld As field
Dim ftrTabs As TabStops
Dim theCenter As Single
theCenter = (pgSetup.PageWidth - pgSetup.LeftMargin - pgSetup.RightMargin) / 2#
'Initialize the footer
ftr.LinkToPrevious = False
Set ftrRng = ftr.Range
With ftrRng
.Text = "Footer Text"
.Style = "Header" <== Deze regel ook
End With
For Each fld In ftrRng.Fields
fld.Delete
Next fld
Set ftrTabs = ftrRng.ParagraphFormat.TabStops
With ftrTabs
.ClearAll
.Add Position:=theCenter, Alignment:=wdAlignTabCenter
End With
Set pgNums = ftr.PageNumbers
With pgNums
Else
End If
End With
'Bottom center page numbering
If numType = ePageNumberBottomCenter Then
With ftrRng
.Text = vbTab
.Fields.Add Range:=ftrRng, Type:=wdFieldPage
End With
End If
End Sub
Wanneer de regels uitgecomment slaat de applicatie niet meer vast maar functioneert de pagina nummering niet zoals het moet.
Het probleem zit dus in de Header en Footer.
Kan iemand mij enig inzicht geven in de oorzaak van het problem.
Dat zou een hele opluchting zijn.
Dim hdrRng As Range
Dim fld As field
With hdrRng
.Text = ""
fld.Delete
Next fld
End With
hdrTabs.ClearAll
Else
End If
Select Case numType
With hdrRng
.Text = vbTab
.MoveEnd
End With
With hdrRng
End With
End Select
End Sub
Dim ftrRng As Range
Dim fld As field
With ftrRng
End With
fld.Delete
Next fld
With ftrTabs
.ClearAll
End With
With pgNums
Else
End If
End With
With ftrRng
.Text = vbTab
End With
End If
End Sub
