apt-get apache hangt
  • ge-flopt
  • Laatst online: 11:48
Hoi Allen,
Ik heb het weer voor elkaar. Ik ben bezig met apache (package 1.3.27.1-3) te installeren, maar nu blijft apt-get "hangen" tijdens het configureren van apache. Ik krijg nog te zien:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
Your config files will not be modified until you select Y at "save changes."
The ServerAdmin is set to webmaster@debian.
The DocumentRoot is set to /var/www.
Leaving existing site /var/www/index.html untouched.
Finding DSO mods......................................found.
# LoadModule vhost_alias_module /usr/lib/apache/1.3/mod_vhost_alias.so
# LoadModule env_module /usr/lib/apache/1.3/mod_env.so
LoadModule config_log_module /usr/lib/apache/1.3/mod_log_config.so
LoadModule mime_magic_module /usr/lib/apache/1.3/mod_mime_magic.so
LoadModule mime_module /usr/lib/apache/1.3/mod_mime.so
LoadModule negotiation_module /usr/lib/apache/1.3/mod_negotiation.so
LoadModule status_module /usr/lib/apache/1.3/mod_status.so
# LoadModule info_module /usr/lib/apache/1.3/mod_info.so
# LoadModule includes_module /usr/lib/apache/1.3/mod_include.so
LoadModule autoindex_module /usr/lib/apache/1.3/mod_autoindex.so
LoadModule dir_module /usr/lib/apache/1.3/mod_dir.so
LoadModule cgi_module /usr/lib/apache/1.3/mod_cgi.so
# LoadModule asis_module /usr/lib/apache/1.3/mod_asis.so
# LoadModule imap_module /usr/lib/apache/1.3/mod_imap.so
# LoadModule action_module /usr/lib/apache/1.3/mod_actions.so
# LoadModule speling_module /usr/lib/apache/1.3/mod_speling.so
LoadModule userdir_module /usr/lib/apache/1.3/mod_userdir.so
LoadModule alias_module /usr/lib/apache/1.3/mod_alias.so
LoadModule rewrite_module /usr/lib/apache/1.3/mod_rewrite.so
LoadModule access_module /usr/lib/apache/1.3/mod_access.so
LoadModule auth_module /usr/lib/apache/1.3/mod_auth.so
# LoadModule anon_auth_module /usr/lib/apache/1.3/mod_auth_anon.so
# LoadModule dbm_auth_module /usr/lib/apache/1.3/mod_auth_dbm.so
# LoadModule db_auth_module /usr/lib/apache/1.3/mod_auth_db.so
# LoadModule proxy_module /usr/lib/apache/1.3/libproxy.so
# LoadModule digest_module /usr/lib/apache/1.3/mod_digest.so
# LoadModule cern_meta_module /usr/lib/apache/1.3/mod_cern_meta.so
LoadModule expires_module /usr/lib/apache/1.3/mod_expires.so
# LoadModule headers_module /usr/lib/apache/1.3/mod_headers.so
# LoadModule usertrack_module /usr/lib/apache/1.3/mod_usertrack.so
LoadModule unique_id_module /usr/lib/apache/1.3/mod_unique_id.so
LoadModule setenvif_module /usr/lib/apache/1.3/mod_setenvif.so
# LoadModule sys_auth_module /usr/lib/apache/1.3/mod_auth_sys.so
# LoadModule put_module /usr/lib/apache/1.3/mod_put.so
# LoadModule allowdev_module /usr/lib/apache/1.3/mod_allowdev.so
# LoadModule eaccess_module /usr/lib/apache/1.3/mod_eaccess.so
# LoadModule roaming_module /usr/lib/apache/1.3/mod_roaming.so
Pondering...................................... done.
Save these changes to the configuration files? [Y/n] y
Vervolgens maakt het niet uit of ik op y of op N druk (gevolgd door een enter)
en dan blijft hij hangen. Heb net ff getest (ben in bad geweest een complete oorlog met DoD gespeeld en hij staat nog iets te doen (wat kan ik niet sien)
Druk ik uiteindelijk op CTRL+C dan krijg ik de melding:
dpkg: error processing apache (--configure):
 subprocess post-installation script killed by signal (Interrupt)
Errors were encountered while processing:
 apache
E: Sub-process /usr/bin/dpkg returned an error code (1)
Ik heb vanalles al geprobeerd. Packages verwijderen, opnieuw laten downloaden. Alle packages verwijderd en opnieuw geinstalleerd. Ik snap het niet. Ik heb gezocht op internet en op GoT, maar kan nergens een vraag vinden die uberhaubt bij mijn probleem in de buurt komt, laat staan het antwoord
Kan iemand mij zeggen wat ik verkeerd doe?
  • XTerm
  • Laatst online: 10-06-2025
Is je hardware wel fris ? Doe eens een hdcheck met badblocks en test je ram eens ?
Een aantal dingen:
- draai eens een top op een andere terminal en kijk of er een proces hangt.
- mocht je in bovenstaande output niets vinden, hang strace dan eens aan het dpkg proces en kijk wat het doet.
  • ge-flopt
3 processen worden er gestart: dpkg, apt-get en apacheconfig en alle drie doen ze niets nadat ik op y gedrukt heb.
Ik denk dat ik nu iets gevonden heb. strace laat keurig alles zien, op het PID van dpkg. Op het moment dat ik op y (of n moet drukken) dan staat er alleen: read (0, en daarna gebeurd er niets. Het lijkt er dus op dat het in het config script zelf zit.
Zou ik de configuratie van apache ook met de hand kunnen doen?
PS. Hardware lijkt me niet. Heb net strace als package geinstalleerd en dat ging goed.
[ Voor 19% gewijzigd door ge-flopt op 15-09-2003 23:47 ]
Yup, gewoon alle bovenstaande LoadModule statements in je httpd.conf zetten, apache herstarten en het gaat werken (al is het wel een smerige oplossing). Welke debian draai je?
  • ge-flopt
debian 3.0 (unstable), maar dan heb ik nog een probleem. Daarnet strace keurig geinstalleerd en aan het eind gaat hij gewoon de configuratie van apache doorvoeren. Dus dat moet ik op 1 of andere manier wel uit kunnen zetten.
:? er is geen probleem (nu iig niet meer), want je apache doet normaal installen.
  • _JGC_
je kunt je packagemanager voor de gek houden door ergens in /var/lib/dpkg/status ofzo een bestand aan te passen. Er staat daar een heel groot bestand met daarin alle geinstalleerde pakketjes en de status erbij. zoek daar apache op en verander de status ervan alsof ie al geinstalleerd zou zijn.
  • ge-flopt
Verwijderd schreef op 15 september 2003 @ 23:56:
Hij installeert wel normaal... Maar de laatste stap, het configureren gaat hij op zijn muil. Ik snap al waar je de mist in gaat. Die opmerking was ivm de hardware. Andere package kan ik wel installeren, maar als hij met die package klaar is gaat hij beginnen met configureren van apache
[ Voor 26% gewijzigd door ge-flopt op 16-09-2003 00:10 ]
  • ge-flopt
Ik zit dus even verder te kijken dan mijn neus lang is en zie dat hij wel die files heeft aangemaakt... :?
  • ge-flopt
_JGC_ doe ik zoals jij het zegt dan krijg ik de volgende melding
asterix:/var/lib/dpkg# apt-get install webmin-apache
Reading Package Lists... Done
Building Dependency Tree... Done
webmin-apache is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0B of archives.
After unpacking 0B of additional disk space will be used.
dpkg: parse error, in file `/var/lib/dpkg/status' near line 5194 package `apache':
 Configured-Version for package with inappropriate Status
E: Sub-process /usr/bin/dpkg returned an error code (2)
Heb wel naar de lijn gekeken van anderen en het ook zo exact overgenomen:
Status: install ok installed
[ Voor 9% gewijzigd door ge-flopt op 16-09-2003 00:22 ]
