Gigabyte-UD4P - X4 955 - 74 gb Raptor - Nvidia GTX 275 - Logitech Z5500
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
| Usage: _______________ | list available| --listdrives | drives | |_______________| | obtain drive | --driveinfo --drivename <name> | info | |_______________| | obtain cd info| --cdinfo --drivename <name> |_______________| | write | --write --drivename <name> [--real] [--tao] | iso/audio cd | [--artist <artist>] [--title <title>] [--speed <speed>] | | [--audio] <audio file> ... [--cdextra] [--iso <volumename>] | | [--iso-no-joliet] [--iso-mode2] [--speedtest] | | [--enable_abort] [--close_session] [--detect_non_empty_cdrw] | | [--cd_text] [--underrun_prot] [--import_rockridge] | | [--import_udf] [--import_iso_only] [--prefer_rockridge] | | [--use_rockridge] [--create_iso_fs] [--create_udf_fs] | | [--disable_eject] [--verify] [--dvd] <disk file> ... | | [--force_erase_cdrw] [--nero_log_timestamp] | | [--output_image <filename>] | | | | NOTE: At least one audio file or one disk file needs to be | | specified! |_______________| | write video | --write --drivename <name> [--real] [--tao] | cd | --videocd [--speed <speed>] [--speedtest] [--enable_abort] | | [--close_session] <video file> ... [--iso <volumename>] | | [--iso-no-joliet] [--iso-mode2] [--speedtest] | | [--enable_abort] [--close_session] [--detect_non_empty_cdrw] | | [--underrun_prot] [--disable_eject] <disk file> ... | | [--force_erase_cdrw] [--nero_log_timestamp] | | [--temp_path <path>] [--output_image <filename>] |_______________| | write super | --write --drivename <name> [--real] [--tao] | video cd | --svideocd [--speed <speed>] [--speedtest] [--enable_abort] | | [--close_session] <video file> ... [--iso <volumename>] | | [--iso-no-joliet] [--iso-mode2] [--speedtest] | | [--enable_abort] [--close_session] [--detect_non_empty_cdrw] | | [--underrun_prot] [--disable_eject] <disk file> ... | | [--force_erase_cdrw] [--nero_log_timestamp] | | [--temp_path <path>] [--output_image <filename>] |_______________| | write image | --write --drivename <name> [--real] [--tao] | | --image <image filename> [--speed <speed>] [--speedtest] | | [--enable_abort] [--close_session] [--detect_non_empty_cdrw] | | [--underrun_prot] [--disable_eject] | | [--force_erase_cdrw] [--nero_log_timestamp] | | [--output_image <filename>] |_______________| | write | --write --drivename <name> [--real] [--tao] | freestyle cd | [--artist <artist>] [--title <title>] [--speed <speed>] | | [--cdextra] [--iso <volumename>] | | [--freestyle_mode1 <filename>] | | [--freestyle_mode2 <filename>] | | [--freestyle_audio <filename>] | | [--iso-no-joliet] [--iso-mode2] [--speedtest] | | [--enable_abort] [--close_session] [--detect_non_empty_cdrw] | | [--cd_text] [--underrun_prot] [--import_rockridge] | | [--import_udf] [--import_iso_only] [--prefer_rockridge] | | [--use_rockridge] [--create_iso_fs] [--create_udf_fs] | | [--disable_eject] [--verify] <disk file> ... | | [--force_erase_cdrw] [--nero_log_timestamp] | | [--output_image <filename>] | | | | NOTE: Any number of freestyle tracks can be specified up to | | 99 tracks.! |_______________| | read audio | --read --drivename <name> [--read_speed <speed>] | track(s) | --XY <filename> [-XY <filename> ...] |_______________| | list audio | --listformats | formats | |_______________| | erase CDRW | --erase [--entire] --drivename <name> |_______________| | eject CD | --eject --drivename <name> |_______________| | load CD | --load --drivename <name> |_______________| | version info | --version |_______________| Each command supports the following switches: [--no_error_log] [--error_log <log filename>], [--no_user_interaction] and [@parameter_file] _______________ | --write | burn CD |_______________| | --drivename | <name> is either the "full name" of the drive or drive | <name> | letter |_______________| | --real | forces the disk to be burned, if not specified the process | | is only simulated |_______________| | --tao | disk is burned in TAO mode, if not specified DAO is default |_______________| | --burnproof | obsolete option, use underrun_prot instead |_______________| | --artist | <aritst> is the name of the artist to put on the CD | <artist> | |_______________| | --title | <title> is the title to put on the CD | <title> | |_______________| | --read_speed | <speed> is speed at which the audio tracks will be read | <speed> | in x150kb/s |_______________| | --speed | <speed> is speed at which the CD will be burned in x150kb/s | <speed> | |_______________| | --speed_in_ | <speed> is speed at which the CD will be burned in KB/s | kbps <speed> | |_______________| | --audio | disk is burned with audio information |_______________| | <audio file> | <audio file> is a list of audio files (wav, mp3, wma, pcm) |_______________| | --cdextra | |_______________| | --iso | <volume name> is the volume name for the CD that is burned | <volume name> | |_______________| |--iso-no-joliet| do not use joliet format |_______________| | --iso-mode2 | burn CD using mode 2 |_______________| | --speedtest | test speed before burning |_______________| | --enable_abort| notify which operations can and which cannot be aborted |_______________| |--close_session| close session, not the whole disk |_______________| |--detect_non_ | detect if burning process it to take place on a non empty | empty_cdrw | cdrw and offer to take certain actions |_______________| | --cd_text | write cd text (if supported by device) |_______________| | --videocd | burn video cd |_______________| | --svideocd | burn super video cd |_______________| | <video file> | <video file> is a list of video files (mpeg, jpeg) |_______________| | --image | <filename> is the filename to the image file | <filename> | |_______________| | --read | read audio track(s) |_______________| | --XY | XY is the number of audio track that is to be saved into | <filename> | <filename> |_______________| | --erase | erase CDRW |_______________| | --entire | erase entire CDRW, the default is quick erase |_______________| | --eject | eject CD |_______________| | --load | load CD |_______________| | --version | print NeroAPI version information |_______________| | --underrun_ | protect from underrun condition | prot | |_______________| | --use_ | use rockridge format | rockridge | |_______________| | --create | create ISO filesystem | _iso_fs | |_______________| | --create | create UDF filesystem | _udf_fs | |_______________| | --dvdvideo | perform reallocation of files in VIDEO_TS | _realloc | directory |_______________| | --import | obsolete option, will be ignored | rockridge | |_______________| | --import_udf | import udf format |_______________| | --import | import ISO only | _iso_only | |_______________| | --import | import session number (if omitted, the last | [session #] | session is imported) |_______________| | --prefer | prefer rockridge format | _rockridge | |_______________| | --freestyle_ | burn the file in mode 1 | mode1 | |_______________| | --freestyle_ | burn the file in mode 2 | mode2 | |_______________| | --freestyle_ | burn the file in audio mode | audio | |_______________| | --disable_ | disables CD ejection after burn completion | eject | |_______________| | --verify | verify ISO filesystem after writing |_______________| | --dvd_high_ | used for better compatibility of burned DVDs | compatibility| as at least 1GB will be written |_______________| | --dvd | select DVD media type |_______________| | --recursive | do a recursive file search |_______________| | --force_erase_| delete CDRW without user interaction. | cdrw | requires --detect_non_empty_cdrw |_______________| | --nero_log_ | add a timestamp to the log filename | timestamp | |_______________| | --temp_path | specify a temporary path for video cd files |_______________| | --media_type | specify a media type (combine with +) | <type> | media_cd, media_ddcd, media_dvd_m, media_dvd_p, | | media_dvd_any, media_dvd_ram, media_ml, media_mrw, | | media_no_cdr, media_no_cdrw, media_cdrw, media_cdr | | media_dvd_rom, media_cdrom, media_no_dvd_m_rw, | | media_no_dvd_m_r, media_no_dvd_p_rw, | | media_no_dvd_p_r, media_dvd_m_r, media_dvd_m_rw, | | media_dvd_p_r, media_dvd_p_rw, media_fpacket, | | media_vpacket or media_packetw) |_______________| | --no_user_ | allow the whole process to take place with no user | interaction | interaction (no questions asked) |_______________| | --output_image| specify output image filename if image recorder is used | | to avoid prompting for filename |_______________| | @param_file | param_file contains command line arguments |_______________| |
Niks aan toe te voegen... volgende keer zelf eerst even goed zoeken en de help files raadpregen
