Specs monitor
  • 45 views sinds 30-01-2008
  • nowell
  • Laatst online: 24-03-2024
nowell
Que Pasa!?
Ik zoek de specs van de volgende monitor:
Digital (=merk) 21". type: PCXAV-WZ
Zoeken met google en dit forum heeft me weinig resultaten geboekt. Weet iemand hier meer over te vertellen (max resolutie, refresh rates enz)
Thnx
  • Glashelder
Glashelder
Anti Android
SN PCXAV-WZ/WY:
21" (19,6" viewable image size) proffesional series auto scanninf color-monitor. Diamondtron CRT, 0,25 mm aperture grill pitch, VGA to 1600 x 1200 at 75 Hz NI, TCO 98, Energy star, includes a 1,8 meter video cable. [...]
[ Voor 5% gewijzigd door Glashelder op 08-09-2003 23:32 ]
  • nowell
nowell
Que Pasa!?
Mag ik U danken!!
  • Glashelder
Glashelder
Anti Android
tuurlijk mag dat :*)
  • nowell
nowell
Que Pasa!?
Dank U!!!
  • kwiebus
  • Laatst online: 05:59
Toch net iets andere specs:
Manufacturer Sku: FR-PCXAV-WZ
Brand: Compaq
Product Line: Digital
Model: 120P
Operating System Compatibility: Unix
BizRate Product ID: 5124231
Also Known As: Fr-Pcxav-Wz
Maximum Resolution: 1600 x 1200 Pixels
Dot Pitch: 0.28 Mm
Screen Type: CRT
Diagonal Screen Size: 21 in
Now you can enjoy sharp, distortion-free quality with this TCO '95 compliant low-emission aperture grill monitor. This model features .28mm stripe pitch, aperture grill tube, high-efficiency anti-glare screen coating for true color reproduction, and advanced ergonomics. It supports extra-high resolutions up to 1600 x 1200 noninterlaced, as well as lower-resolution video standards including VGA and 8514/XGA, and refresh rates from 50Hz to 152Hz. Advanced auto-scan ensures compatibility with most high-resolution video controllers - and the ergonomically designed control panel and On-Screen Display (OSD) menu system provide easy access to the monitor's configuration parameters. This monitor has 12 factory-preset timing modes with 16 user-definable settings available. It is also fully compliant with Energy Star, the most stringent TCO '95 emissions standards and MPR-2. The color temperature control ensures true color translation from desktop publishing to your color printout.
http://tomshardware.bizra...416,prod_id--5124231.html
  • nowell
nowell
Que Pasa!?
ow......ok
bedankt allebei
  • Pollewob
Dicht maar.. aangezien anderen het ook kunnen vinden had je met een beetje moeite het ook wel zelf kunnen vinden :Y)
