[Javascript] Script aanpassen om datum anders te tonen
  • 45 views sinds 30-01-2008
Beste tweakers, ik wil het script hieronder gebruiken op mijn website maar ik wil de output een beetje aanpassen. In plaats van wat ik nu heb:
Hoi Jacob, je laatste bezoek was op Aug 31
Wil ik graag het volgende bereiken:
Hoi Jacob, je laatste bezoek was op 31 augustus 2003.
Hoe ga ik dit doen? Kan iemand me helpen?
Dank u!
<SCRIPT LANGUAGE="JavaScript">
<!-- Original: Mattias Sjoberg -->
<!-- This script and many more are available free online at -->
<!-- The JavaScript Source!! http://javascript.internet.com -->
<!-- Begin
var expDays = 30;
var exp = new Date();
exp.setTime(exp.getTime() + (expDays*24*60*60*1000));
function Who(info){
var VisitorName = GetCookie('VisitorName')
if (VisitorName == null) {
VisitorName = prompt("Who are you?");
SetCookie ('VisitorName', VisitorName, exp);
return VisitorName;
function When(info){
var rightNow = new Date()
var WWHTime = 0;
WWHTime = GetCookie('WWhenH')
WWHTime = WWHTime * 1
var lastHereFormatting = new Date(WWHTime);
var intLastVisit = (lastHereFormatting.getYear() * 10000)+(lastHereFormatting.getMonth() * 100) + lastHereFormatting.getDate()
var lastHereInDateFormat = "" + lastHereFormatting;
var dayOfWeek = lastHereInDateFormat.substring(0,3)
var dateMonth = lastHereInDateFormat.substring(4,11)
var timeOfDay = lastHereInDateFormat.substring(11,16)
var year = lastHereInDateFormat.substring(23,25)
var WWHText = dayOfWeek + ", " + dateMonth + " at " + timeOfDay
SetCookie ("WWhenH", rightNow.getTime(), exp)
return WWHText
function Count(info){
var WWHCount = GetCookie('WWHCount')
if (WWHCount == null) {
WWHCount = 0;
else{
WWHCount++;
SetCookie ('WWHCount', WWHCount, exp);
return WWHCount;
function set(){
SetCookie ('WWHCount', 0, exp);
SetCookie ('WWhenH', 0, exp);
function getCookieVal (offset) {
var endstr = document.cookie.indexOf (";", offset);
if (endstr == -1)
endstr = document.cookie.length;
return unescape(document.cookie.substring(offset, endstr));
function GetCookie (name) {
var arg = name + "=";
var alen = arg.length;
var clen = document.cookie.length;
var i = 0;
while (i < clen) {
var j = i + alen;
if (document.cookie.substring(i, j) == arg)
return getCookieVal (j);
i = document.cookie.indexOf(" ", i) + 1;
if (i == 0) break;
return null;
function SetCookie (name, value) {
var argv = SetCookie.arguments;
var argc = SetCookie.arguments.length;
var expires = (argc > 2) ? argv[2] : null;
var path = (argc > 3) ? argv[3] : null;
var domain = (argc > 4) ? argv[4] : null;
var secure = (argc > 5) ? argv[5] : false;
document.cookie = name + "=" + escape (value) +
((expires == null) ? "" : ("; expires=" + expires.toGMTString())) +
((path == null) ? "" : ("; path=" + path)) +
((domain == null) ? "" : ("; domain=" + domain)) +
((secure == true) ? "; secure" : "");
function DeleteCookie (name) {
exp.setTime (exp.getTime() - 1);
var cval = GetCookie (name);
document.cookie = name + "=" + cval + "; expires=" + exp.toGMTString();
// End -->
</SCRIPT>
<BODY>
<CENTER>
document.write("Hello " + Who() + ". You've been here " + Count() + " time(s). Last time was " + When() +".");
</SCRIPT>
</CENTER>
  • gorgi_19
  • Laatst online: 20-08 11:40
gorgi_19
Kruimeltjes zijn weer op :9
Op een of andere manier klopt jouw output die jij geeft niet met de output die het script mogelijk kan geven.. Script geeft namelijk Engelse output; jij Nederlands.
Wat heb je zelf al geprobeerd? Wat lukt je niet? Welke foutmeldingen krijg je?
[ Voor 24% gewijzigd door curry684 op 31-08-2003 18:33 ]
Digitaal onderwijsmateriaal, leermateriaal voor hbo
  • curry684
  • Laatst online: 13-08 16:46
curry684
left part of the evil twins
"Hoi ik heb een auto gejat maar hij moet nog even overgespoten worden. Kan iemand dat even voor me regelen?"
Oftewel: gejatte scripts op verzoek modifien doen we hier niet. Toedels :)
gejat == geleend == gedownload == niet van jezelf
[ Voor 15% gewijzigd door curry684 op 31-08-2003 18:34 ]
Professionele website nodig?
  • curry684
curry684
ps. deze heb je duidelijk nog nooit gelezen: P&W FAQ - De "quickstart"
Doe d'r eens wat aan :+
Zie na een paar uur ook nog dat het javascript was, dat hoort bij Webdesign & Graphics fyi :z
[ Voor 29% gewijzigd door curry684 op 31-08-2003 23:53 ]
