Misschien helpt dit. (als je windows 2000 hebt). Anders moet er volgens de MCafee site ook een Home Networking Wizard in Firewall 4 zitten.
How to configure McAfee Firewall on an ICS network with a Windows 2000 gateway (CR 12711)
Product Versions
McAfee Firewall 4
NOTE: For users with McAfee Firewall versions 4.00 and 4.01, you must upgrade to at least version 4.02.6000 before using this workaround.
Operating Systems
Windows 2000 Professional Edition
System Information
This only applies to networks configured to use Internet Connection Sharing (ICS) where the operating system of the gateway machine is Windows 2000 Professional.
Description
If you set up an ICS network where the gateway machine uses the Windows 2000 operating system, you will need to enable ICS recognition on the gateway to allow the client computers to communicate to the Internet. To enable ICS recognition, you will need to edit the registry settings of the gateway.
Workaround
CAUTION: Incorrectly editing the registry may severely damage your system. Before making changes to the registry, you should back up any valued data on your computer. Before you edit the registry, make sure you understand how to restore it if a problem occurs. For information about how to do this, view the 'Restoring the Registry' Help topic in Regedit.exe or the 'Restoring a Registry Key' Help topic in Regedt32.exe.
1. Click Start, and click Run.
2. In the Open box, type regedit, and click OK.
3. Locate and click (highlight) the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\McAfee\McAfee Firewall
4. Create a new DWORD Value named Win2KICS.
5. On the File menu, click Exit to quit Registry Editor.
6. Restart the computer.
7. Start the Firewall Home page.
8. Under Advanced Tasks, click Set up home networking and follow the on-screen instructions to allow computers in your network to communicate through the gateway.
Voor 7% gewijzigd door
s441558 op 29-08-2003 21:04
Nefit EnviLine IDU Monoblock E 7 E-S, Boiler 200 L, Buffervat 50L. BQQKees
