MicroATX voeding PFC????
  • PvP
  • Laatst online: 12-10 20:54
Onlangs is de voeding van een computer overleden.
Het betreft een MicroATX voeding van het merk Newton Power Ltd.
Via de volgende website staat beschreven dat mocht een nieuwe voeding in gebruik genomen worden er wel rekening mee gehouden moet worden dat er een PFC voeding gebruikt wordt.
https://www.usereasy.com/components/sfx-2115a.htm
Kan iemand mij vertellen wat dit precies inhoudt, en of dit wel echt nodig is?
Alvast vriendelijk bedankt
PvP
  • OnTracK
  • Laatst online: 15:40
wat ik tot nu toe gevonden heb:
Power factor correction. This originally referred to the fact that an inductive load, where the current and the voltage are not totally in phase, draws instantaneous power of the instantaneous current times the instantaneous voltage. However, it has been extended to mean any distortion or phase shift in the power drawn from the mains. An AC power supply must use some method to control the power coming from the mains. Usually this is done with some kind of pulsing. There are also components in the power supply that cannot draw current until the voltage gets high enough, or draw current only at the peak of the sine wave. Drawing power from different parts of the sine wave can distort what is left for everybody else to use and the utilities have to compensate for it. In Europe, where the utilities are mostly owned by the government the governments are tempted to use the power of the law to benefit their industries, and have required an increasingly onerous set of PFC values over the years, now requiring PFC for power supplies as low as 75 watts. In the USA the utilities are at the mercy of their customers and PFC requirements have lagged behind Europe.
maar volgens mij heeft iedere voeding tegenwoordig PFC
Not everybody wins, and certainly not everybody wins all the time.
But once you get into your boat, push off and tie into your shoes.
Then you have indeed won far more than those who have never tried.
  • itsalex
Dat is niet zo. Sinds een korte tijd wel maar vroeger hadden m-atx het niet. De goedkope kasten hebben geen pfc. Vooral de goedkopere voedingen hebben het ook niet.
I hit the CTRL key, but I'm still not in control!
  • Shuriken
  • Laatst online: 15:25
Shuriken
Life is all about priorities
PFC is tegenwoordig in Europa verplicht. Dus als het goed is hebben alle voedingen dit.
Er zijn echter verschillende varianten. Active en Passive PFC. Active schijnt toch iets beter te zijn.
I rather have a bottle in front of me, then a frontal lobotomie
ik heb hier nog een micro ATX voeding liggen btw.
een Bestec 150 Watt. als je hem wilt moet je t zeggen.
