[html/jscript] probleem met tags
  • 44 views sinds 30-01-2008
  • Saicho
  • Laatst online: 19-09-2023
Saicho
CMDR Sai
Ben bezig om op mn website een mouseover textje in een layer te plakken.
Maar ik kan dus geen tags meegeven om de kleur/positie (center) te veranderen :/
Dit staat in mn header :
29
30
31
32
33
34
35
36
37
38
39
<script language="JavaScript" type="text/JavaScript">
function MM_reloadPage(init) {  //reloads the window if Nav4 resized
  if (init==true) with (navigator) {if ((appName=="Netscape")&&(parseInt(appVersion)==4)) {
    document.MM_pgW=innerWidth; document.MM_pgH=innerHeight; onresize=MM_reloadPage; }}
  else if (innerWidth!=document.MM_pgW || innerHeight!=document.MM_pgH) location.reload();
MM_reloadPage(true);
function MM_findObj(n, d) { //v4.01
  var p,i,x;  if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
    d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
  if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
  for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
  if(!x && d.getElementById) x=d.getElementById(n); return x;
function MM_setTextOfLayer(objName,x,newText) { //v4.01
  if ((obj=MM_findObj(objName))!=null) with (obj)
    if (document.layers) {document.write(unescape(newText)); document.close();}
    else innerHTML = unescape(newText);
function MM_preloadImages() { //v3.0
  var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
    var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
    if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
function MM_swapImgRestore() { //v3.0
  var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
function MM_swapImage() { //v3.0
  var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
   if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
Dit staat in mn body :
<div id="Layer1" style="position:absolute; left:35px; top:76px; width:291px; height:55px; z-index:1; layer-background-color: #FFFFFF; border: 1px none #000000;">
  <div align="center">
    <p><font color="#FFFFFF">Standaard<br>
      <br>
      Tekstje
          </font> </p>
  </div>
</div>
<map name="Map">
<area shape="rect" coords="148,4,185,26" onMouseOver="MM_setTextOfLayer('Layer1','','blaaablabla regel 1<br>blaat regel 2')">
</map>
(et voorbeeld hierboven werkt wel... de tags moeten er nu dus nog bij)
iemand een idee wat ik fout doe ? Of is et onmogelijk om op deze manier de kleur/positie te veranderen ?
E:D - CMDR Sai
  • André
  • Laatst online: 19-08 12:30
André
Analytics dude
De kleur en positie waarvan? Dit zijn van die standaard MM scripts en die ondersteunen dat waarschijnlijk niet.
Dit is ook wel heel veel code voor heel weinig functionaliteit.
  • CrashOne
CrashOne
oOoOoOoOoOoOoOoOoOo
En wij moeten nu de code die jij dreamweaver hebt laten makenm gaan fixen :?
Huur mij in als freelance SEO consultant!
  • Bosmonster
  • Laatst online: 19-08 22:14
Bosmonster
*zucht*
Misschien staat er iets over in de Dreamweaver tutorial.. wij kunnen in ieder geval niks met deze Macromedia-scripts.
Doe anders eens wat html/css/javascript tutorials op www.w3schools.com
  • crisp
  • Laatst online: 00:21
crisp
Devver
Pixelated
een layer:
HTML:
<div id="blaat" style="position: absolute; top: 0px; left: 0px;> </div>
textje erin zetten:
JavaScript:
document.getElementById('blaat').firstChild.nodeValue = 'textje';
kleurtje veranderen:
JavaScript:
document.getElementById('blaat').style.color = 'red';
positie veranderen:
JavaScript:
document.getElementById('blaat').style.top = '100px';
document.getElementById('blaat').style.left = '100px';
allemaal basic... :z
Intentionally left blank
