[Debian] KDE3 install, broken packages.
  • MIT
  • Laatst online: 12-08 09:29
MIT
KerMIT
Op een Debian systeem heb ik geprobeerd KDE3 te installeren. Na het verwijderen van KDE2 en het apt-get'ten van een kde3.1.3 mirror wilde de nog niet lukken. Ik heb op basis van een vorige toppics de volgende handelingen vericht, tot op heden draait KDE3.1.3 nog niet.
KDE2.2 verwijderd door
apt-get remove --purge kde*
dpkg -l | grep kde
geeft
rc kdebase-data 3.1.3-woody1 KDE Base (shared data)
ii kdelibs-data 3.1.3-woody1 KDE core shared data
apt-get install kdebase
geeft
29
30
31
Sorry, but the following packages have unmet dependencies:
  kdebase: Depends: kaddressbook (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: kappfinder (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: kate (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: kcontrol (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: kdcop (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: kdebase-bin (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: kdebugdialog (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: kdeprint (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: kdesktop (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: kfind (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: khelpcenter (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: khotkeys (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: kicker (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: kioslave (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: klipper (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: kmenuedit (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: konqueror-nsplugins (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: konqueror (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: konsole (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: kpager (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: kpersonalizer (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: kscreensaver (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: ksmserver (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: ksplash (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: ksysguard (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: ktip (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: kwin (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: kxkb (>= 4:3.1.3-1woody1) but it is not going to be installed
           Depends: libkonq4 (>= 4:3.1.3-1woody1) but it is not going to be installed
E: Sorry, broken packages
Het probleem is bekend (iig onder een aantal GoT'ers) weet iemand wat ik verder nog kan proberen.
No Signature
  • The Third Man
  • Laatst online: 15:57
The Third Man
The Third Jellyfish
Misschien wat flauw, maar kan je niet al die pakketnamen ook tegelijk installeren? Wordt wel wat typewerk, maar misschien werkt het wel.
  • MIT
MIT
KerMIT
Ja, kan wel normaal gesproken, maar ook bij de andere packetten die je apt-get krijg je dependencie fouten.
r3bOOt, was deze topicstart wel goed ?
No Signature
  • The Third Man
The Third Man
The Third Jellyfish
Mmm, probeer eens deze dingetjes:
1. Check of alle sources in sources.list kloppen. Dus geen andere releases/versies ernaast. Alleen woody of stable.
2. apt-get install --fix-broken kdebase
3. apt-get clean
4. Doe eens kdebase3 i.p.v. kdebase...
  • MIT
MIT
KerMIT
sources.list roept alleen ftp://ftp.eu.uu.net/pub/kde/stable/3.1.3/Debian woody main aan. Hierboven geplaatste opmerking #2 geeft de zelfde Error als m'n eerste post. #3 returnt verder niets. #4 kdebase3 bestaat niet.
[ Voor 16% gewijzigd door MIT op 28-08-2003 19:33 . Reden: Vergat 3 en 4 ]
No Signature
  • The Third Man
The Third Man
The Third Jellyfish
Ik denk dat ik eruit ben: ik denk dat die source niet alle pakketten bevat waar kdebase op depends. Namelijk die waar hij om zeurt "is not going to be installed". Want als ik een beetje rondsurf op die source, zie ik bijvoorbeeld kaddressbook er niet bij staan in pool/main.
Ik denk dat als je ook een normale woody source toevoegt ónder je huidige source in sources.list, dan hij vanzelf de kdebase van 3.1.3 gebruikt omdat die de nieuwste is, en vervolgens voor de andere pakketten die van de normale source.
  • MIT
MIT
KerMIT
Terwijl jij zat te tikken was ik nog bezig met dingen proberen. kdcop kdebugdialog khotkeys kioslave kxkb hoorden niet bij de melding, (de melding had ik gecopy'ed). MAAAARRRR!!! Het lijkt er op dat je gelijk hebt.... Ik heb nu ftp://ftp.eu.uu.net/pub/kde/stable/3.1.3/Debian en ftp.nl.debian.org /debian/ aan staan. Uit de proces list lijk ik op te kunnen maken dat het werkt. Nog een paar minuten....
No Signature
  • MIT
MIT
KerMIT
Ben even gaten in m'n plafond aan het springen!!!
Meneer Kwal, u bent geweldig. Het werkt inderdaad, apt-get gebruikt packadges van zowel de Debian ftp, als van de KDE ftp. Ik zal even een samenvattingkje posten van wat ik gedaan heb.
No Signature
  • The Third Man
The Third Man
The Third Jellyfish
Graag gedaan hoor ;)
Ik vind dat apt heel handig, maar het blijft soms puzzelen, vooral doordat niet alle foutmelding even handig zijn (en hij ook alles tegenhoudt als er 1 pakketje niet goed is geïnstalleerd). Maar als je het vergelijkt met andere distro's is het een hele prettige feature :)
  • MIT
MIT
KerMIT
#1 nog geen ftp toevoegen buiten de Debian ftp
#2 apt-get remove --purge kde*
#3 KDE ftp toevoegen aan /etc/apt/ source.list (ftp://ftp.eu.uu.net/pub/kde/stable/3.1.3/Debian stable main)
Let Op! Debian ftp NIET weghalen.
#4 apt-get update
#5 apt-get install kdebase
No Signature
  • MIT
MIT
KerMIT
Lekkere Kwal schreef op 28 August 2003 @ 20:13:
Helemaal mee eens!
No Signature
  • Infern0
  • Laatst online: 20-08 13:36
Infern0
Hou die ontzettende rust!!
heb je ook alle arts packages weg gehaald?
http://www.bsdfreaks.nl Home site: http://rob.lensen.nu /me was RobL
