MSN Servicemessage?
  • 31 views sinds 30-01-2008
Ik krijg zojuist dit bericht:
ATTENTION: IMMEDIATE ACTION REQUIRED FOR MSN AND WINDOWS MESSENGER USERS.
You are receiving this e-mail because you are a MSN Messenger or Windows
Messenger Service user.
As part of Microsoft's Trustworthy Computing initiative, Microsoft is
updating the .NET Messenger Service and providing you with an important
MSN Messenger or Windows Messenger security update.
If you are using MSN Messenger 5.0, Windows Messenger 4.7.2000, or MSN
Messenger for Mac 3.5, or any versions higher than these, you do NOT need
this security update. To find out which version you have, select the
'Help' menu in Messenger, then select 'About'. If you are using an older
version, or are not sure, please visit:
http://messenger.msn.com/Help/Upgrades.aspx
for an update.
NOTICE: If you are not using an updated version, you will be unable to
continue using your MSN Messenger or Windows Messenger Service.
Thank you for helping Microsoft further its commitment to helping you
protect your privacy and security online.
You can view the .NET Messenger Statement of Privacy at:
http://messenger.msn.com/Help/Privacy.aspx
and the .NET Messenger Service Terms of Use and Notices at:
http://messenger.msn.com/Help/Terms.aspx.
Dit is de afzender:
dot_net_msgr_svc@msgr.hotmail.com
nog meer mensen last hiervan?
Leuk als dit dus echt zo is, je kan mij namelijk niet vertellen dat dat lek nu pas gevonden is .. al die tijd werken met MSN 4.x .. lekker die lui :)
[ Voor 11% gewijzigd door Verwijderd op 27-08-2003 15:33 ]
  • Compubiter
  • Laatst online: 21-08-2023
Compubiter
Think again
