Ik ga toch ff de lay-out vernueken
Ik kan wel via OWA een mailtje lezen met als subject 'test.' Dit is mijn urlscan.ini:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
| [options]
UseAllowVerbs=1 ; if 1, use [AllowVerbs] section, else use [DenyVerbs] section
UseAllowExtensions=0 ; if 1, use [AllowExtensions] section, else use [DenyExtensions] section
NormalizeUrlBeforeScan=1 ; if 1, canonicalize URL before processing
VerifyNormalization=1 ; if 1, canonicalize URL twice and reject request if a change occurs
AllowHighBitCharacters=1 ; if 1, allow high bit (ie. UTF8 or MBCS) characters in URL
AllowDotInPath=1 ; if 1, allow dots that are not file extensions
RemoveServerHeader=0 ; if 1, remove "Server" header from response
EnableLogging=1 ; if 1, log UrlScan activity
PerProcessLogging=0 ; if 1, the UrlScan.log filename will contain a PID (ie. UrlScan.123.log)
AllowLateScanning=0 ; if 1, then UrlScan will load as a low priority filter.
PerDayLogging=1 ; if 1, UrlScan will produce a new log each day with activity in the form UrlScan.010101.log
RejectResponseUrl= ; UrlScan will send rejected requests to the URL specified here. Default is /<Rejected-by-UrlScan>
UseFastPathReject=0 ; If 1, then UrlScan will not use the RejectResponseUrl or allow IIS to log the request
; If RemoveServerHeader is 0, then AlternateServerName can be
; used to specify a replacement for IIS's built in 'Server' header
AlternateServerName=
[AllowVerbs]
; Note that these entries are effective if "UseAllowVerbs=1"
; is set in the [Options] section above.
GET
HEAD
POST
OPTIONS
SEARCH
POLL
PROPFIND
BMOVE
BCOPY
SUBSCRIBE
MOVE
PROPPATCH
BPROPPATCH
DELETE
BDELETE
MKCOL
UNSUBSCRIBE
SUBSCRIPTIONS
COPY
LOCK
UNLOCK
PUT
ACL
NOTIFY
[DenyVerbs]
; Note that these entries are effective if "UseAllowVerbs=0"
[DenyHeaders]
; Request headers listed in this section will cause UrlScan to
; reject any request in which they are present.
; Headers should be listed in the form
; Header-Name:
[AllowExtensions]
; Extensions listed here are commonly used on a typical IIS server.
; Note that these entries are effective if "UseAllowExtensions=1"
.asp
.cer
.cdx
.asa
.htm
.html
.txt
.jpg
.jpeg
.gif
;.idq
;.htw
;.ida
;.idc
;.shtm
;.shtml
;.stm
;.htr
;.printer
[DenyExtensions]
; Extensions listed here either run code directly on the server,
; are processed as scripts, or are static files that are
; generally not intended to be served out.
; Note that these entries are effective if "UseAllowExtensions=0"
; Deny executables that could run on the server
;.exe
;.bat
.cmd
;.com
; Deny infrequently used scripts
.htw ; Maps to webhits.dll, part of Index Server
.ida ; Maps to idq.dll, part of Index Server
.idq ; Maps to idq.dll, part of Index Server
.htr ; Maps to ism.dll, a legacy administrative tool
.idc ; Maps to httpodbc.dll, a legacy database access tool
.shtm ; Maps to ssinc.dll, for Server Side Includes
.shtml ; Maps to ssinc.dll, for Server Side Includes
.stm ; Maps to ssinc.dll, for Server Side Includes
.printer ; Maps to msw3prt.dll, for Internet Printing Services
; Deny various static files
;.ini ; Configuration files
;.log ; Log files
;.pol ; Policy files
;.dat ; Configuration files
;.asp
;.cer
;.cdx
;.asa
[DenyUrlSequences]
;.. ; Don't allow directory traversals
./ ; Don't allow trailing dot on a directory name
\ ; Don't allow backslashes in URL
;% ; Don't allow escaping after normalization
;& ; Don't allow multiple CGI processes to run on a single request |
Maar hou er wel rekening mee dat ik alleen SSL heb draaien, zonder anonymous login, je moet inloggen bij mij. Ik heb allerlei shit geremd omdat er toch geen virussen via SSL zich bij mij aan gaan melden en me certificaat accepteren. Let dus wel een beetje op dat je URLScan niet waardeloos wordt.
Sowieso zou ik OWA alleen over een SSL verbinding laten lopen. Als je wil heb ik wel een howto voor OWA (is gewoon bij MS te vinden, zoeken op OWA SSL IIS ofzo)
Succes!
