Simcity 4 Cheats Niet Werkend (Spoil)
  • 139 views sinds 30-01-2008
  • MrCaleb
  • Laatst online: 11-01-2022
Hey Everyone,
Ik weet dat dit een beetje Lame is, cheaten enzo, maar ben al zown tijd bezig wil het wat leuker maken, probleem is die cheats werken niet, of ik krijg ze niet aan de praat.
Weet niet of iemand toevallig Simcity 4 heeft, en heeft geprobeert te cheaten, deze cheats komen van Cheatplanet:
Various Cheats
Press Ctrl + X during gameplay and you will bring up the Console. Now enter a code below in bold and press ENTER
hellomynameis <mayorname> - Change the mayor name to a name you supply. Replace the bracketed entry with your entry
you don't deserve it - Get all rewards free
sizeof <1-100> - Make magnification 1-100. Replace the bracketed entry with your entry of 1-100
stopwatch - Stop/start the clock
whatimeizit <time> - set the time of the day follow with a space and the time you wish to set. Replace the bracketed entry with your time entry
whererufrom <cityname> - change city name follow with new name you want to apply. Replace the bracketed entry with your entry
weaknesspays - Get 1,000 added to treasury
fightthepower - No power requirements for buildings
zoneria - Empty zone color hidden
tastyzots - toggles zots.
howdryiam - Water requirements for buildings removed
Zoneria - Hide Empty zone color
DollyLlama - causes all the advisors heads to swap to llama heads.
Barstuck - ?
WatchMeMove - ?
FPS <number> - framerate
RP - ?
Flora - ?
RenderProp - ?
TerrainQuery - ?
RenderProp - ?
Effect - ?
GOL - ? (Green Plasma Effect On Map)
Recorder - Start Recorder
NOTE: Entering invalid cheat codes will make the console and text
remain indiferent, whereas entering a valid cheat code
will close the console.
All God Options when you are a Mayor
When you are in the Mayor mode, you can't use all of the God Options. If you want to use them, Press Ctrl+Alt+Shift at the same time, when still holding, click with your left mouse button on "God Options" And you will have them all.
Info submitted by Oscar van der Sluijs on Tuesday, January 21, 2003 at 07:56:02
faster money
Type=weaknesspays but before you press enter press and hold shift witch will keep the cheat box open after pressing enter then press the up arrow on your keyboard witch will bring up the previous code(weaknesspays) a repeat to hearts desire
Info submitted by Beau on Monday, January 20, 2003 at 12:45:08
Probleem is dat hele console komt niet tevoorschijn...Enige ideeën?
Bedankt alvast
  • MrCaleb
Sorry Nevermind, hij werkt al, pakte hem blijkbaar eerste keer niet, heb en gereboot nu werkt het, LoCk it :P sorry for the space taking..
