[Memory] OCZ PC4000
  • 58 views sinds 30-01-2008
  • nvidia
  • Laatst online: 04-07 18:35
Ikzelf ben van plan om PC te kopen en daar hoort nu eenmaal DDR Ram-geheugen bij en daarbij dacht ik aan 2 x OCZ Memory 256 MB Gold PC4000. Is dit een goede keuze of niet, hieronder staat enkele specificaties vermeld:
ULN Technology: (U)ltra (L)ow (N)oise shielded PCB
Lifetime Warranty
512MB (2x256) and 1024MB (2x512) kits based on OCZ brand EL DDR IC
Gold Heatspreader
Featuring OCZ HyperSpeed® technology for outrageous top end speeds*
Optimized for High Speed applications on Intel i865/i875 chipsets
500Mhz CL 2.5-4-4-7*
2.8 volts
EVP®(Extended Voltage Protection) Technology allowing up to 3.0 volts VDIMM while maintaining full warranty **
184 Pin Dimm
Unbuffered
Description:
OCZ EL DDR PC-4000 / 500mhz / Gold Edition / Dual Channel
OCZ Gold Edition PC-4000 memory using state of the art HyperSpeed® technology is capable of achieving outrageous speeds of up to 500 MHz at CL 2.5-4-4-7*. OCZ Gold Edition PC4000 Dual Channel features OCZ EVP® Extended Voltage Protection**, a circuit protection feature designed to allow performance enthusiasts to tweak their systems without the worry of invalidating the warranty.
* * OCZ HyperSpeed® technology denotes specific OCZ EL DDR ICs built and selected for their ability to run at the highest possible frequency. HyperSpeed® enabled modules contain firmware and are built on a PCB that is optimized for the highest possible frequency and due to these optimizations the PC4000 Gold modules may not allow latency faster than 2.5-4-4-5, regardless of the module frequency.
** OCZ Extended Voltage Protection® circuit protection allows modules to handle higher voltages through a novel voltage protection circuit. OCZ EVP® protected modules tolerate VDIMM voltages of up to 3.0 volts +/- 5% and are covered by the OCZ lifetime warranty if overvolted within EVP® tolerances.
OCZ Gold modules have been designed and optimized for use with the Intel i865/i875 chipsets and work best on these platforms. If you are using a non-i875 based mainboard, we suggest purchasing either OCZ Platinum Edition or OCZ EL DDR modules.
Partners: AV-Solutio | Mutrox | B&W | Trinnov
  • BalusC
BalusC
Carpe diem
nvidia schreef op 22 augustus 2003 @ 11:05:
Dat kun jij zélf het beste uitmaken :)
Zie de FAQ van dit subforum welke geheugen je het beste moet nemen B)
