• gitaarwerk
gitaarwerk
Plays piano,…
http://www.mobileplanet.c...pt_id=5120&pf_id=MP580207
Afbeeldingslocatie: http://www.mobileplanet.com/assets/product_images/MP580207.gif
specs:
Size:
24 x 40 x 2.1 mm
Weight:
4 g
Power Typical:
50 mA
Certification:
FCC: Part 15, Class B
Industry Canada
Bluetooth 1.1
ETS 300 328
ETS 300 826
TELEC
OS Support:
Windows CE 3.0 for Pocket PC
Radio Range:
Up to 30 ft (10 m)
Mfr #: BL4800-392
Description
Please Note: Works on the iPAQ 3950 and 3955 with the latest ROM update. You can download the ROM update from HP's website or click here. http://www.mobileplanet.com/ipaq3900romupdate
The Bluetooth Connection Kit features Socket's new SDIO card and the Get Connected! Setup wizard. The software runs on any Pocket PC that has a Secure Digital (SD) I/O slot and is running BSQUARE Corporation s SDIO Now! software. The phones listed below have been tested and are compatible with the Kit.
Ericsson: R520, T39, T68
Motorola: 270C
Nokia: 3650, 6210, 6310, 6310i, 7650, 8910
NTT DoCoMo: PALDIO 633S
Sony: C413S
SDIO Type B card with integrated antenna is the smallest available for a Pocket PC.
Use the standard Windows CE dial-up networking (DUN) software to initiate a data call with your phone
Bluetooth Profiles supported in Windows CE: General Access, Service Discovery, Serial Port, Dial-up Networking, LAN via PPP, Generic Object Exchange, Object Push, File Transfer and Fax.
The card is designed to be Mobility Friendly and energy efficient to minimize the battery consumption of your Pocket PC.
With Socket's Dialer software you can tap contact and let your Pocket PC dial your phone.
Print to a Bluetooth-enabled printer with the Bluetooth SDIO Connection Kit and PrintPocketCE software.
NOTE: This card will not work with the Toshiba e740. Even though the Toshiba e740 Pocket PC has a Secure Digital (SD) I/O slot, the SDIO Now! software is not included on the device.
[ Voor 4% gewijzigd door gitaarwerk op 19-08-2003 13:37 ]
Ontwikkelaar van NPM library Gleamy
  • j0ck0z
  • Laatst online: 06-02-2025
Is erg handig :) Overigens wel een beetje duur.
Maar is er nog een vraag oid :?
PB 3.2
  • gitaarwerk
gitaarwerk
Plays piano,…
ehmz.. niet echt.. ik dacht, net als die wifi kaart, dat ik even het nieuws post dat er een bluetooth kaart is voor pocket pc's (tja, als ik nieuwsposter was zat het op de frontpage :P )
coor de toshiba's zijn er weer andere...
