hoi, ik heb zo juist 7 e-mails van msn ontvangen die mij zeggen dat ik msn moet updaten. hebben jullie dit ook ontvangen want ik vind het wel een beetje raar deze mail.
ik gebruik MSN6, en heb ook windows messenger (xp).
Maar nu vraag ik me ook af hoe ze erachter zijn gekomen dat ik msn gebruik ?
ATTENTION: IMMEDIATE ACTION REQUIRED FOR MSN AND WINDOWS MESSENGER USERS.
You are receiving this e-mail because you are a MSN Messenger or Windows
Messenger Service user.
As part of Microsoft's Trustworthy Computing initiative, Microsoft is
updating the .NET Messenger Service and providing you with an important
MSN Messenger or Windows Messenger security update.
If you are using MSN Messenger 5.0, Windows Messenger 4.7.2000, or MSN
Messenger for Mac 3.5, or any versions higher than these, you do NOT need
this security update. To find out which version you have, select the
'Help' menu in Messenger, then select 'About'. If you are using an older
version, or are not sure, please visit:
http://messenger.msn.com/Help/Upgrades.aspx
for an update.
NOTICE: If you are not using an updated version, you will be unable to
continue using your MSN Messenger or Windows Messenger Service.
Thank you for helping Microsoft further its commitment to helping you
protect your privacy and security online.
You can view the .NET Messenger Statement of Privacy at:
http://messenger.msn.com/Help/Privacy.aspx
and the .NET Messenger Service Terms of Use and Notices at:
http://messenger.msn.com/Help/Terms.aspx.
for an update.
