http://204.245.113.76 /
Kyle:
OK, for any of you guys that hosed your boards yesterday, first off sorry. I should have tried it myself before posting. I should have learned by now not to trust folks. ARGH!!!
This was sent in by Kyle:
Hey,
I tried that trick and it ass rapped my bios! well luckily I still had my bp6 manual :-) I guess the bp6 (I don’t know bout other ABIT boards) allow you to flash the bios from a floppy disk, so I tried it and it worked(well if it didn’t I wouldn’t be emailing you this..) but in order to do this you need to do the following(you should probably post this fix incase it works on other ABIT mobo's)
1. Get a formatted floppy disk ready.
2. Include the following system files on the floppy disk: Command.com , msdos.sys , io.sys
3. copy awdflash.exe from the abit cd onto the disk.
4. The old clean bios ".bin" file.
5. Make an Autoexec.bat batch file with the following in it.
a:\awdflash NAME_OF_THE_NEW_BIOS /PY /SN /CC /CD
6. Put her in a startup, should reboot by itself.
Thanks,
Kyle Landrith
AKA "Toad_007"
Our homeboy OSKAR over at ABIT FAE took care of us today with an "exclusive" BIOS that I am sure everyone else will have shortly!
Here is what ABIT had to say about it!! And we will be testing today. HERE IS THE BIOS.
The attached file is the latest BE6-II/BF6 beta bios ... This beta add one more fancy SOFTMENU III feature , which has huge effect when FSB > 125 MHz. I tested this new feature and found it's really effective with my own Diamond VIPER V770 Ultra straight up to 150 MHz FSB !!!
Just FYI, it did NOT work to well for me but we are trying again. It seems as if it did not like my first flash attempt...
Epox8RDA+ XPThorton2000+@3200+ Radeon9800SE@Pro Plextor 12/10/32A 80GB 7200 8MB XPpro
