Etech router ADSL verbinding eruit.
Sinds enkele dagen klapt mijn ADSL verbinding er continue uit. Omdat ik auto-reconnect aan heb staan wordt er wel weer een verbinding opgezet alleen al mijn connecties worden natuurlijk even afgesloten.
Specs:
Win XP Prof
E-tech modem/router v2 (dat blauwe kreng)
MxStream XS4ALL
De log zag er als volgt uit:
29
30
31
32
33
34
35
36
37
38
39
40
41
8/13/2003 18:35:34> PPP1 Session is up.
8/13/2003 18:35:33> NAPT: many-to-one default session is up.
8/13/2003 18:35:33> Initialized NAT Virtual Servers.
8/13/2003 18:35:33> NAT/NAPT Session Start: interface ppp1, WAN IP is 213.x.x.x
8/13/2003 18:35:33> PPP1: DNS Secondary IP address is 194.109.6.66
8/13/2003 18:35:33> PPP1: DNS Primary IP address is 194.109.104.104
8/13/2003 18:35:33> PPP1: PPP Gateway IP address is 195.190.241.65
8/13/2003 18:35:33> PPP1: PPP IP address is 213.x.x.x
8/13/2003 18:35:33> PPP PAP Authentication success
8/13/2003 18:35:25> PPP1 PPPoA Connected
8/13/2003 18:35:25> ADSL connected
8/13/2003 18:35:25> ATM layer is up, cell delineation achieved
8/13/2003 18:35:25> ATM Connected
8/13/2003 18:35:18> ADSL detected
8/13/2003 18:35:7> NAT/NAPT: default session is down.
8/13/2003 18:35:7> NAT/NAPT Session Stop: interface ppp1
8/13/2003 18:35:7> PPP1 Session is down.
8/13/2003 18:35:6> ADSL disconnected
8/13/2003 18:35:6> ATM Disconnected
8/13/2003 18:32:1> Received time from Time Server 129.6.15.29
1/1/1970 0:0:20> PPP1 Session is up.
1/1/1970 0:0:20> NAPT: many-to-one default session is up.
1/1/1970 0:0:20> Initialized NAT Virtual Servers.
1/1/1970 0:0:20> NAT/NAPT Session Start: interface ppp1, WAN IP is 213.x.x.x
1/1/1970 0:0:20> PPP1: DNS Secondary IP address is 194.109.6.66
1/1/1970 0:0:20> PPP1: DNS Primary IP address is 194.109.104.104
1/1/1970 0:0:20> PPP1: PPP Gateway IP address is 195.190.241.65
1/1/1970 0:0:20> PPP1: PPP IP address is 213.x.x.x
1/1/1970 0:0:19> PPP PAP Authentication success
1/1/1970 0:0:18> WAN auto connection attempt.
1/1/1970 0:0:15> PPP1 PPPoA Connected
1/1/1970 0:0:15> ADSL connected
1/1/1970 0:0:15> ATM layer is up, cell delineation achieved
1/1/1970 0:0:15> ATM Connected
1/1/1970 0:0:0> CfgMgr: 'Shtm.dlz' module loaded.
1/1/1970 0:0:0> Initialized NAPT.
1/1/1970 0:0:0> NAPT is enabled
1/1/1970 0:0:0> ATM: Setting up vcc0, VPI=8, VCI=48
1/1/1970 0:0:0> ATM: Detected
1/1/1970 0:0:0> Ethernet Device 0 Detected
Ik dacht laat ik eens terug zetten naar 'factory defaults' maar dat mocht ook niet baten. Sterker nog nu krijg ik niet eens (tijdelijk) een verbinding. Hij blijft nu op onderstaand hangen.
1/1/1970 0:0:14> ADSL connected
1/1/1970 0:0:14> ATM layer is up, cell delineation achieved
1/1/1970 0:0:14> ATM Connected
ADSL wordt dus waarschijnlijk nog wel over mijn lijntje aangeboden (lampje brand ook continue op de router) maar vermoedelijk krijg ik geen IP adres meer?
Iemand enig idee?
  • mrsar
  • Laatst online: 13:40
mrsar
waar een sar is,is een wodka
ik heb dit thuis soms ook (1x per 1 a 2 maanden),ik krijg dan idd geen ip adres.
wat ik dan doe ik save&reset of alleen de reset van de modem,dit helpt altijd wel,ben er nog nie achter waarom het gebeurd
zit btw bij telebyte
steam: mr_sar1 / Battle.net : mrsar#2189 / xbox : mrsar1
Ik heb precies hetzelfde, ook zoals mrsar 1 a 2 keer per maand. Ik haal dan ff de power uit de router steek hem er weer in en het werkt weer. Ook geen id wat het kan zijn.
Heb ook mxstream xs4all
  • Tooms
  • Laatst online: 22-01-2025
Het zou hardware matig probleem kunnen zijn. Ook schijnen er problemen te zijn met firmware versies van deze blauwe router (heb hem zelf ook en totaal geen problemen mee).
DHCP server aanzetten?
suc7
Power uit. Factory Defaults. DHCP werkt allemaal niet. Ik had eerst v1 van dit kreng (met mislukt powerknopje) maar goedkoop is in dit geval weer duurkoop :( |:(
Kunnen jullie DHCP Client wel aanvinken? Want ik kan vinken wat ik wil maar het vinkje gaat altijd vanzelf weer uit.
Verwijderd schreef op 15 augustus 2003 @ 16:33:
Ook als je deze aanvinkt en daarna op save settings klikt?
Jep.
aanvinken -> Submit -> Save settings
aanvinken -> Save Settings
aanvinken -> Submit -> Save configuration (links in menu)
aanvinken -> Save configuration
jahaha begin al redelijk wanhopig te worden 8)7 ;)
  • Master Chieftec
  • Laatst online: 16-08 17:49
Hey,
Daar heb ik nou ook last van.
Ik heb hetzelfde E-Tech modem (provider Telebyte).
Als ik die modem in Bridge modus zet (dus router functie uit), dan knalt mijn internet verbinding eruit. Een reset naar factory default, stekker in en uit helpt allemaal niet.
Volgens Telebyte is de lijn dan vastgelopen en moet BBned de lijn weer resettten.
Dit is behoorlijk irritant, ik hoorde altijd dat ADSL signaal zo stabiel was.
Jaja, net zo stabiel als mijn reet tijdens diarree.
BBned heeft mij alweer 3 keer online gegooid. 1 keer trok ik alleen de stekker uit de telefoon wandcontact doos en weer viel de ADSL signaal eruit.
Inmiddels heeft Telebyte een nieuwe modem naar mij toegestuurd en ik krijg hem als het goed is Maandag binnen. Denk niet dat het veel gaat helpen.
Denk eerder dat de lijn erg zwak is, alhowel als het internet het doet is het wel erg snel.
790 kb down / 50 kb up bij speedtest, centrale ligt geeneens 100 meter van mijn huis. Raarrrr .....
Om zeker te weten dat het aan de modem/router ligt en niet aan KPN MXStream of mij XS4ALL account heb ik effe de modem aangesloten bij een vriend. Ook daar geen succes... en zijn alcatel bak werkte bij mij ook goed (op mijn account) dus het lijkt mij uitgesloten dat het aan het adsl signaal of account ligt.
Volgende stap: Terugsturen dat blauwe monster... dat wordt nr 3...
  • -DarkShadow-
probleem heb ik ook gehad, is bekend probleem bij e-tech routers. Gewoon garantie claimen, zit niet voor niks 5 jaar garantie op.
Specialist in:
Soldeerstations
Oscilloscoop
Net gebeld voor RMA. De leverancier wist me te vertellen dat ongeveer 1 op de 10 etech bakken terug komt in verhouding met 1 op de 200 alcatel...
Hmmm dat de verbinding er de hele tijd uit vloog lag was een echte fout... dat ik na het terugzetten naar factory defaults geen verbinding kreeg lag dus aan PPPoA VC-Mux ipv PPPoE VC-Mux.....
Ik dacht ik zeg het effe mocht ooit iemand per ongeluk de search gebruiken wanneer ze dit probleem ook aantreffen ;)
