CRC errors
  • 80 views sinds 30-01-2008
Mijn broer en ik hebben erg veel last van CRC errors van groote bestanden rar en andere " zip - exe etc " bestanden.
bv Americas army ik heb em al 4 x gedownload steets andere download plek en steets maar errors.
Chello+ friesland
pc spec's
AMD Athlon™ XP 2400+
512MB RAM
NVIDIA GeForce4 Ti 4400
Windows XP Professional, Service Pack 1
! D:\Visualboy Advance\ArmyOps190.exe: CRC failed in program files\Army Operations\Animations\A-charactersMil.ukx. The file is corrupt
! D:\Visualboy Advance\ArmyOps190.exe: CRC failed in program files\Army Operations\Animations\A-WeaponsUS.ukx. The file is corrupt
! D:\Visualboy Advance\ArmyOps190.exe: CRC failed in program files\Army Operations\ArcadeInstallARMYOPS11c.EXE. The file is corrupt
! D:\Visualboy Advance\ArmyOps190.exe: CRC failed in program files\Army Operations\Maps\MOUT_McKenna.aao. The file is corrupt
! D:\Visualboy Advance\ArmyOps190.exe: CRC failed in program files\Army Operations\Maps\Obstacle.aao. The file is corrupt
! D:\Visualboy Advance\ArmyOps190.exe: CRC failed in program files\Army Operations\Maps\Swamp_Raid.aao. The file is corrupt
! D:\Visualboy Advance\ArmyOps190.exe: CRC failed in program files\Army Operations\Maps\Tunnel.aao. The file is corrupt
! D:\Visualboy Advance\ArmyOps190.exe: CRC failed in program files\Army Operations\Maps\Weapons_Cache.aao. The file is corrupt
! D:\Visualboy Advance\ArmyOps190.exe: CRC failed in program files\Army Operations\Sounds\S-Ambient.uax. The file is corrupt
! D:\Visualboy Advance\ArmyOps190.exe: CRC failed in program files\Army Operations\Sounds\S-BCT_RifleRange.uax. The file is corrupt
! D:\Visualboy Advance\ArmyOps190.exe: CRC failed in program files\Army Operations\Sounds\S-Foley.uax. The file is corrupt
! D:\Visualboy Advance\ArmyOps190.exe: CRC failed in program files\Army Operations\Sounds\S-Jumpschool.uax. The file is corrupt
! D:\Visualboy Advance\ArmyOps190.exe: CRC failed in program files\Army Operations\Sounds\S-Medic.uax. The file is corrupt
! D:\Visualboy Advance\ArmyOps190.exe: CRC failed in program files\Army Operations\Sounds\S-MedicField.uax. The file is corrupt
! D:\Visualboy Advance\ArmyOps190.exe: CRC failed in program files\Army Operations\Sounds\S-MedicTraining.uax. The file is corrupt
! D:\Visualboy Advance\ArmyOps190.exe: CRC failed in program files\Army Operations\Textures\T2-EQUIPMENT.utx. The file is corrupt
plaatje van download http://members1.chello.nl/~f.h.dijkstra/apart.JPG
die kleine "tikkjes" er door heen:?
Move: SA > SPV. Games horen niet in SA.
[ Voor 55% gewijzigd door Verwijderd op 15-08-2003 09:57 ]
  • bl33d
  • Laatst online: 18-10 16:36
bl33d
I love the smell of Napalm..
Ik heb hier ook problemen met mijn kt133a boardje als ik grote bestanden wil uitpakken dat deze CRC errors geeft.
Mijn oplossing is zo weinig mogelijk processen op de achtergrond draaien om ervoor te zorgen dat de southbridge chipset niet corrupt raakt. Wat tevens ook hielp is de VIA Latency patch van George. (http://www.georgebreese.com/net/software/#PCI)
Weet niet of dit in jouw geval ook opgaat dat de southbridge corrupt raakt. Maar probeer het is. Ik maak van jouw bericht op dat je vooral CRC errors krijgt met grote bestanden uitpakken / copyeren.
Succes ;)
  • Crash
  • Laatst online: 11:16
kans dat je geheugen rot is
ik had hier bij grote bestanden downloaden ook steeds last van corrupte files,
uiteindelijk bleek het door mijn geheugen te komen
draai memtest eens om er zeker van te zijn
Ik heb hetzelfde probleem, ook met bestanden die ik voordat ik ging formatteren op een andere partitie heb gezet. Met WinRAR kon ik de bestanden niet repareren.
Voordat ik Windows opnieuw geïnstalleerd had deden de bestanden het wel nog.
Die VIA Latency patch hoef je toch alleen te installeren als je een VIA chipset hebt? Ik heb een Intel i865P/PE/G/i848P chipset.
Ik heb Memtest-86 v3.0 gedraaid, maar die crashte steeds bij test #4 ("Moving inv, 32 bit pattern, cached).
HELP! :?
  • White Dust
  • Laatst online: 22-09 10:04
White Dust
PlaneScape: Torment
Ik doe dit topic op slot... Zo te zien heeft het niet met games te maken maar met ingepakte bestanden, is dus meer iets voor Software Algemeen, maar aangezien het een oud topic is is het beter om hem op slot te doen en een nieuwe openen in SA...
Enneh, Sander Dijkhuis, probeer eerst eens een ander geheugen reepje... zo te zien kan die het wel eens hebben begeven ;)
