WinXP : wat is msblast.exe ??
  • 35 views sinds 30-01-2008
Weet iemand wat msblast.exe is en wat het doet, mijn pc reboote spontaan en mijn antivirusscanner was opeens gedisabled, na de reboot wou msblast.exe connectie maken met het internet. Elke keer als ik inlogte ging mijn pc weer rebooten (zon shutdown schermpje met 30 seconden) Nog nooit eerder gezien dat msblast.exe. Ik heb even op internet gezocht maar kan er niks over vinden ?
Edit : hij staat overigens in mijn system32 folder.
[ Voor 8% gewijzigd door Verwijderd op 11-08-2003 22:47 ]
  • Notna
  • Laatst online: 23:25
Notna
Where are you?®
Xbox Live ID:Notna8310
  • zzzBedmanzzz
  • Laatst online: 30-08 11:20
Security threat: beware MsBlast.exe
dwergs says:
D'z warned me about a hole in the MSN Messenger protocol that has lately been taken advantage of. It's the first thing I hear about it, but according to him "several people have already been hit by exploiters, gaining too much access".
To find out whether you're infected, press Ctrl+Alt+Del and verify if the process 'MsBlast.exe' is running. If it is, consider following the instructions below, but since there is no official security bulletin released on this topic yet... you are on your own.
- Kill the process MsBlast.exe from the task manager you just checked.
- Next, execute regedit.exe and search for the registry key:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\Windows Auto Update
If it mentions MSBLAST in the path, remove that.
- Final step: delete msblast.exe from either the windows system or and system32 folders.
More on this as the story unfolds...
  • F_J_K
F_J_K
Moderator CSA/PB/AI
Front verplichte underscores
*** LEZEN - RPC crash/ windows shutdown *** dus. Lijkt me genoeg info :)
Succes & have fun :P
